title: What is Rendering in Interior Design - A Helpful Overview
description: Learn the fundamentals of interior rendering. Explore key concepts, techniques, and best practices for creating photorealistic interior visuals.
image: https://blog.chaos.com/hubfs/Imported_Blog_Media/Architectural_interiors_thumb.jpg
[Chaos Logo](https://blog.chaos.com/)
- Products
    - [Enscape](https://www.chaos.com/enscape)
    - [V-Ray](https://www.chaos.com/vray)
    - [Corona](https://www.chaos.com/corona)
    - [Veras](https://chaos.com/veras)
    - [Cloud](https://chaos.com/credits)
    - [V-Ray Blender](https://www.chaos.com/vray/blender)
    - [Arena](https://www.chaos.com/arena)
- Industry solutions
    - [Education](https://www.chaos.com/education/educational-hub)
    - [Student](https://www.chaos.com/students)
    - [Educator](https://www.chaos.com/educators)
    - [Institutions](https://www.chaos.com/educational-institutions)
    - [Architectural design](https://www.chaos.com/architecture)
    - [Architectural visualization](https://www.chaos.com/architectural-visualization)
    - [Interior design](https://www.chaos.com/interior-design)
    - [Landscape rendering](https://www.chaos.com/landscape-architecture)
    - [Urban planning](https://www.chaos.com/urban-planning)
    - [Film and television VFX](https://www.chaos.com/film-vfx)
    - [Virtual production](https://www.chaos.com/virtual-production)
    - [Advertising](https://www.chaos.com/advertising)
    - [Automotive](https://www.chaos.com/automotive)
    - [Games](https://www.chaos.com/games)
    - [Product design](https://www.chaos.com/product-design)
    - [Software development](https://www.chaos.com/developers)
- Learning & Community
    - [Learning](https://chaos.com/learning)
    - [Chaos Academy](https://academy.chaos.com/)
    - [Blog](https://blog.chaos.com/)
    - [Case studies](https://blog.chaos.com/tag/case-studies)
    - [CGconnect](https://chaos.com/cgconnect)
    - [Gallery](https://chaos.com/gallery)
    - [Forum](https://forums.chaos.com/)
- Support
    - [Contact Support](https://chaos.com/contact-us)
    - [Help Center](https://support.chaos.com/hc/en-us)
    - [FAQ](https://support.chaos.com/hc/en-us/categories/360003671518-FAQ)
    - [Documentation](https://documentation.chaos.com/)
- [Pricing](https://www.chaos.com/pricing)
[Try](https://www.chaos.com/free-trial)
[Buy](https://www.chaos.com/pricing)
- Products
- Support
[Try](https://www.chaos.com/free-trial) [Buy](https://www.chaos.com/pricing)
[\< All Blog Posts](https://blog.chaos.com)
© Bendus Mihail
 Ricardo Ortiz
Last updated: June 11, 2026  •   4 min read
# What is rendering in interior design - a helpful overview
**Summary:**
- Interior rendering basics involve setting up a simple space with a single light source, similar to exterior rendering principles.
- Efficient 3D models are crucial; ensure geometries are clean and normals are correctly oriented for optimal rendering.
- Adjust camera lenses to widen the field of view without significant distortion, and use V-Ray's Composition Guides for layout.
- Lighting setup includes using a Sun and Sky System for realistic illumination and optimizing with dome lights for faster renders.
- V-Ray GPU is recommended for faster interior rendering due to its efficiency with ray-tracing on modern graphics cards.
Are you an architect or interior designer looking for information on how to get started with interior rendering quickly and accurately? Then this article is for you.
[Photorealistic interior renderings](http://chaos.com/interior-design) can be an exciting way to imagine where we live or work and examine how we light closed or semi-open spaces.
This is the second part about the basic principles of using [architectural rendering software](https://www.chaos.com/architectural-rendering). It is a good idea to read the [first installment about exteriors,](https://www.chaos.com/blog/architectural-rendering-basics-exteriors)as well as our back-to-basics guide on[how to do an architectural render](https://www.chaos.com/blog/how-to-do-an-architectural-rendering), to better understand this article. In this part, we will address the essential basic principles to work with interior rendering and complement additional aspects of the overall rendering process.
## **Getting started**
As beginners in rendering, we must establish the conditions of our first interior render; a simple interior space with a single light input from a medium or large window.
The process and steps covered in the first part with exteriors are largely similar in interior scenes, but I will cover some aspects and additional considerations that are important to consider in order to achieve great results.
## **3D models for rendering**
In terms of visualization, we have the flexibility to adjust the geometries however we want. Simple modeling doesn't take a lot of time. For example, if it's walls, we can create simple planes without thicknesses and it will work. However, we can also work with a complex BIM model if our piece comes from a specialized development platform such as Revit.
The most important thing in all cases is to ensure that the geometries are efficient and clean, with continuous and smooth curves. We have to make sure faces that don’t overlap and have correct normals. This last point is very important; if a wall is a simple plane its normal face must be in the direction of the camera, since many of the render engine modifiers, such as displacement or fur, work based on the normal of the polygons.
## **Set the cameras**
When placing our cameras indoors, sometimes the dimensions of the space will not allow us to show everything we want due to the camera's field of view.
A simple solution is to select our camera and change its lens to a smaller value (for example, from 35mm to 28mm). This will widen the field of view, but it will also slightly distort the image. Be careful not to create significant distortion that affects the interpretation scale of the space and the objects.
Finally, don’t forget to use the **Composition Guides layer** included in the **V-Ray Frame Buffer** to lay out your composition.
## **Lighting**
As in the first part, it is advisable to start with the most common lighting: daylight.
We create a [Sun and Sky System](https://docs.chaos.com/display/VMAX/VRaySky) and direct the sun to enter through the window. As the glass of the window is not visible in our render, you can hide the window geometry. This generates direct light into the interior space and consequently, this light will bounce throughout the space, creating global illumination. This process of direct and indirect light replicates the behavior of light in real life, ensuring an incredible level of realism.
The physical sky generates an ambient light that enters through the openings to the interior and gives us a more natural appearance.
To optimize all the necessary evaluations and obtain a better result, we must create a dome light and plug our Sky into the dome light texture. This is necessary in newer versions of V-Ray, and it helps speed up render times.
As in the case of exterior scenes, you can use image-based lighting with an HDRI texture. Remember to use the Chaos Cosmos library to download and try many different HDRIs.
## **Materials and 3D assets**
Again, we can use the [Chaos Cosmos library](http://chaos.com/cosmos) to download materials for our project. While we’re in Cosmos, we can also choose furniture and accessories that suit our project.
Read more on Cosmos:[Dogs, potted plants, and the kitchen sink: the most imported Chaos Cosmos assets in 2025](https://blog.chaos.com/most-used-cosmos-assets?hsLang=en)
## **Render time**
The default settings in V-Ray are designed to render any scene. However, something that we must take into account is that interior renderings generally take more time due to light bounces and the level of detail in the materials.
In cases of interior renderings, it is worth considering the production modes that V-Ray offers and finding the one that best suits your hardware: CPU, GPU, or [Chaos Cloud Rendering](https://www.chaos.com/cloud-rendering).
Today, many interior visualization artists have found the best option to speed up their render times is V-Ray GPU. Because the latest generation of graphics cards are designed to solve demanding parallel calculations, and specifically ray-tracing rendering processes, they are an excellent choice for rendering interiors. If you have an RTX graphics card, make use of it — you will not regret it.
## **Post-processing and composition**
We already know about our essential render elements and tools; **BackToBeauty**, **Cryptomatte**, **Denoiser,** and **LightMix**, remember, a final image always requires those extra touches that will make it even better.
## **More about interior renderings**
Want to know more about interior renders? I recently detailed my [top 10 tips for creating wow-factor interior design renders](https://blog.chaos.com/top-10-tips-for-creating-wow-factor-interior-design-renderings?hsLang=en). Check it out for a series of recommendations that will help you achieve incredible interior renderings. I'm sure it will complement your journey to rendering with V-Ray.
## **Let’s get to work**
If you have reached the end of this second part, you will have noticed how simple it can be to create exterior and interior renderings. This smooth methodology facilitates the technical work and gives us time and creative freedom to explore architectural design and interior spaces.
[Explore V-Ray](https://www.chaos.com/vray)
### Ready to try Chaos products?
Start your free trial today and explore all features.
[Start Free Trial](https://www.chaos.com/free-trial)
Share
<https://www.facebook.com/sharer/sharer.php?u=https://blog.chaos.com/architectural-rendering-basics-interiors&title=What%20is%20Rendering%20in%20Interior%20Design%20-%20A%20Helpful%20Overview&picture=https://blog.enscape3d.com/hubfs/Imported_Blog_Media/Architectural_interiors_thumb.jpg&description=Learn%20the%20fundamentals%20of%20interior%20rendering.%20Explore%20key%20concepts,%20techniques,%20and%20best%20practices%20for%20creating%20photorealistic%20interior%20visuals.>
<https://twitter.com/share?url=https://blog.chaos.com/architectural-rendering-basics-interiors&hashtags=>
<https://www.linkedin.com/shareArticle?mini=true&url=https://blog.chaos.com/architectural-rendering-basics-interiors&title=What%20is%20Rendering%20in%20Interior%20Design%20-%20A%20Helpful%20Overview&summary=Learn%20the%20fundamentals%20of%20interior%20rendering.%20Explore%20key%20concepts,%20techniques,%20and%20best%20practices%20for%20creating%20photorealistic%20interior%20visuals.>
[mailto:?subject=What%20is%20Rendering%20in%20Interior%20Design%20-%20A%20Helpful%20Overview&body=What%20is%20Rendering%20in%20Interior%20Design%20-%20A%20Helpful%20Overview%20https://blog.chaos.com/architectural-rendering-basics-interiors](mailto:?subject=What%20is%20Rendering%20in%20Interior%20Design%20-%20A%20Helpful%20Overview&body=What%20is%20Rendering%20in%20Interior%20Design%20-%20A%20Helpful%20Overview%20https://blog.chaos.com/architectural-rendering-basics-interiors)
[Materials](https://blog.chaos.com/tag/materials) [Lighting](https://blog.chaos.com/tag/lighting) [Interior design](https://blog.chaos.com/tag/interior-design) [Architecture](https://blog.chaos.com/tag/architecture) [V-Ray](https://blog.chaos.com/tag/v-ray) [Tips & tricks](https://blog.chaos.com/tag/tips-tricks) [how to](https://blog.chaos.com/tag/how-to) [camera](https://blog.chaos.com/tag/camera)
Ricardo Ortiz
As part of the Chaos team, Ricardo is responsible for growing and supporting our Spanish-speaking user community, including Hablamos Chaos, which has over 80K Facebook members. Ricardo is a V-Ray Certified Professional in V-Ray for 3ds Max, V-Ray for Maya, V-Ray for Rhino and V-Ray for SketchUp. He has worked as an instructor for over 10 years in industries including archviz, VFX ,and product design. Ricardo is also a university teacher in industrial design, architecture and digital animation.
## Related Articles
### [November 11, 2026 How 3D Rendering Works: From a 3D Scene to a Photorealistic Image Yoana Stoeva  •  13 min read Read more](https://blog.chaos.com/what-is-a-3d-render-how-computers-turn-geometry-into-photorealistic-images?hsLang=en)
### [November 10, 2026 How Arterra Interactive Used V-Ray to Visualize Australia's First New City in a Century Dinnie Muslihat  •  5 min read Read more](https://blog.chaos.com/arterra-interactive?hsLang=en)
### [November 9, 2026 Real-Time Rendering for Architects: How It Works and When to Use It Andreea Lipan  •  10 min read Read more](https://blog.chaos.com/real-time-rendering-for-architects?hsLang=en)
[Visit the blog for more articles](https://blog.chaos.com)
## Subscribe to Our Blog
<https://www.chaos.com/>
<https://www.chaos.com/enscape> <https://www.chaos.com/vray> <https://www.chaos.com/corona> <https://www.chaos.com/veras>
Chaos
- [About us](https://www.chaos.com/about)
- [Blog](https://blog.chaos.com)
- [Press](https://www.chaos.com/press)
- [Careers](https://www.chaos.com/careers)
- [Events](https://www.chaos.com/events)
- [Contact us](https://www.chaos.com/contact-us)
Purchasing
- [Buy online](https://www.chaos.com/pricing)
- [Find a reseller](https://www.chaos.com/pricing/resellers)
- [Upgrade options](https://www.chaos.com/upgrade)
- [Manage your products](https://my.chaos.com/products)
- [Download your software](https://download.chaos.com/)
- [Refund policy](https://support.chaos.com/hc/en-us/articles/4402140621457-Do-you-offer-refunds-What-is-your-refund-policy)
- [Help with purchasing](https://support.chaos.com/hc/en-us/sections/360005717237-Purchasing)
- [Become a reseller](https://www.chaos.com/become-partner)
Support
- [Resources](https://academy.chaos.com/catalog)
- [Get support](https://support.chaos.com/hc/en-us/categories/360003671518-FAQ)
- [Service status](https://status.chaos.com/)
- [Help docs](https://docs.chaos.com/)
- [Forums](https://www.chaos.com/forums)
Passion projects
- [CGconnect](https://cgconnect.chaos.com/)
- [CG Garage podcast](https://www.chaos.com/cg-garage)
Technology
- [Real-time rendering](https://www.chaos.com/real-time-rendering)
- [3D rendering](https://www.chaos.com/3d-rendering-software)
- [GPU rendering](https://www.chaos.com/vray-gpu)
- [Fluid dynamics simulation](https://www.chaos.com/fluid-dynamics-software)
- [Cloud rendering](https://www.chaos.com/cloud-rendering)
- [Photorealistic rendering](https://www.chaos.com/photorealistic-rendering)
- [Innovation Lab](https://www.chaos.com/innovation-lab)
- [Responsible AI](https://www.chaos.com/responsible-ai)
Follow us
- <https://www.chaos.com/social-channels#facebook>
- <https://www.chaos.com/social-channels#instagram>
- <https://www.chaos.com/social-channels#youtube>
- <https://www.chaos.com/social-channels#linkedin>
- [Terms of use](https://www.chaos.com/terms)
- [Privacy policy](https://www.chaos.com/privacy)
- [Legal](https://www.chaos.com/legal)
- [Sitemap](https://www.chaos.com/sitemap)
- Cookie-Einstellungen
```json
  "@context" : "https://schema.org",
  "@type" : "BlogPosting",
  "author" : {
    "@type" : "Person",
    "name" : "Ricardo Ortiz",
    "url" : "https://blog.chaos.com/author/ricardo-ortiz"
  "dateModified" : "2026-06-11T18:38:44.167Z",
  "datePublished" : "2022-11-06T23:00:00.000Z",
  "headline" : "What is Rendering in Interior Design - A Helpful Overview",
  "image" : [ "https://blog.chaos.com/hubfs/Imported_Blog_Media/Architectural_interiors_thumb.jpg" ],
  "mainEntityOfPage" : {
    "@id" : "https://blog.chaos.com/architectural-rendering-basics-interiors",
    "@type" : "WebPage"
  "publisher" : {
    "@type" : "Organization",
    "logo" : {
      "@type" : "ImageObject",
      "url" : "https://blog.chaos.com/hubfs/Chaos_Icon_Colour_RGB.png"
    "name" : "Chaos Software GmbH"
