The new, unified Chaos Forum is now live.
Join the conversation!
Enscape exterior rendering of flat roof bungalow surrounded by trees and grass, with a river in the foregound
Dan Stine
Dan Stine
Last updated: July 15, 2025  •  3 min read
Creating Accurate Toposolids in Revit 2025
With the new object type in Revit 2024 and 2025, it is helpful for Enscape users to have a good understanding of how to create an accurate surface from a civil CAD file. This post will cover two primary options while highlighting the slight difference in accuracy. Following these steps will result in a more accurate toposurface in Revit and Enscape!
Included with this article is a video highlighting the process of exporting an AutoCAD Civil 3D surface for use in Revit. Revit users are not often experienced with Civil 3D and vice versa. Thus, consider sharing this article with your civil team.
Civil CAD files – elevated contours
The most common, yet least accurate, method of creating a Revit toposolid in Revit is by using a civil CAD file defined by contours at the correct elevation. Revit will find points along these contours and use those points to create the toposolid. The limitation is there is often a lot happening between the contours that is lost. For example, spot elevation, tie-ins to stoops, and more. However, as shown in the video, the overall accuracy is still decent.
Example of Revit Civil CAD file defined by contours
Civil CAD files – triangulated surface
A more accurate option is to ask your civil team for a triangulated surface. As shown in the image below for the same surface, there is a lot more detail. Revit has a lot more lines to add points to. In the video, you will clearly see how the contours more closely match the contours from AutoCAD Civil 3D.
Example of Revit Civil CAD file defined by triangles
Accurate contours in Revit
Once the civil CAD file has been linked in and the Revit toposurface has been created, the contour display for the toposolid can be adjusted. Here, you want to match the contour spacing in the civil CAD file. The Start value should be set to zero so the contours are created from sea level. This will make them graphically and numerically align.
Screenshot of Revir contour display settings
Revit contour display dialog
The following image shows the contour in Civil 3D is set to 55.
Screenshot of AutoCAD contours settings at specific elevations
AutoCAD contours at specific elevations
The next image is from Revit, showing the contours have the same values.
Example of Revit contours labeled with the correct elevation
Results in Enscape
By default, the surface may look triangulated and choppy, as shown in the image below. This is the civil 3D surface defined by a toposolid in Revit. The sun has been adjusted to be early in the morning to exaggerate the issue.
Example of choppy toposolid within Revit, viewed in Enscape
Choppy (not smooth) toposolid within Revit, viewed in Enscape
In Revit, on the Massing and Site tab, the Toposolid Smooth Shading can be toggled on to help alleviate the choppy look.
Screenshot of Revit toggle showcasing how to smooth toposolids
Revit toggle to smooth toposolids
Notice how the ground surface looks much smoother now.
Smooth toposolid
Example of smoother toposolid in Revit, viewed in Enscape
Here are two more views within Enscape showing off this large complex site now clearly and accurately defined in Enscape for Revit.
Enscape exterior rendering of field with mountains on the horizon meeting a cloud-filled sky
Enscape rendered-example
Enscape exterior rendering of tree-shaded area
Enscape-rendered example
Toposolid accuracy video
To make the entire creation process within Revit clear, I created this video highlighting two methods of creating the toposolid: from contours and triangulated surfaces.
Another important aspect of managing locations within Revit is Shared Coordinates. I have a video series that provides an easy-to-understand overview. This method works on local and BIM 360 projects.
Enscape context feature
While on the topic of developing sites, it is helpful to note that Enscape can generate an early-phase site context model. Enscape's Site Context feature, which uses OpenStreetMap data, immerses your design within the urban fabric it is meant for.
Instead of linking a map or plat drawing to your design software and spending a couple of hours outlining and extruding shapes to represent existing buildings around the project, you can achieve similar results in minutes with Site Context.
Example of Enscape's Site Context feature
Site Context model generated within Enscape
This feature might only be used at the beginning of a project, while others might find the level of detail adequate for the entire project. To learn more about its best practices, you can read my article on the topic.
Conclusion
Creating an accurate ground surface within your CAD/BIM tool is important to ensure your building is well coordinated and also improves the visualization experience and credibility of a project’s design proposal.
chaos logo
Report: How AI is reshaping design & visualization in 2026
How AI is reshaping architectural design and visualization in 2026 new report from Chaos and Architizer
Share
Dan Stine
Dan Stine
Dan is an author, blogger, educator, design technologist and Wisconsin-registered architect. He is the Director of Design Technology at Lake | Flato architects in San Antonio, Texas. Connect with Dan on LinkedIn.
Smooth toposolid
