The new, unified Chaos Forum is now live.
Join the conversation!
Architectural Rendering Example
Gemma Da Silva
Gemma Da Silva
Last updated: October 08, 2025  •  9 min read
What is Architectural Rendering and How Does it Work?
Architectural rendering is the process of creating a realistic image of a future building or space. Rendering software takes a project designed in a modeling tool such as Revit or SketchUp and transforms it into a 3D visualization.
It is an increasingly popular way for architects and designers to communicate their proposed architectural design to clients and contractors and make faster design decisions based on how a space will look and feel in reality.
This article will answer the most common questions asked on the topic of 3D architectural rendering. It will also outline the benefits, and provide examples of the different types of renders that can be produced with very little effort using real-time rendering technology.
What is architectural rendering?
Architectural rendering is the process of producing visual outputs that illustrate a future building or space. These outputs, such as images or animations, can be highly realistic and detailed, accounting for all aspects of the physical design or just impressionistic depictions of the design concept.
This process can also be referred to as architectural illustration, architectural visualization, 3D rendering, or 3D visualization.
Using rendering in architectural design doesn’t just give architects helpful visual references as they work on a concept, it also enables them to market their design ideas to clients, solicit feedback for design refinement, and keep projects moving forward.
The process of rendering can be found in a variety of disciplines, from manufacturing to engineering. Developing images that give a comprehensive view of designs is widely utilized in visualizing new products, equipment systems, machinery, and even to visualize entire landscapes.
co-working cafe rendering
Enscape rendering courtesy of Vilhelm Lauritzen Architects and Liljewall Architects
Types of architectural renderings
An architectural rendering can take many forms. It can be, for example, a still image, a panorama, a standalone rendered image file of an entire building, or an architectural walkthrough. With some real-time rendering tools, it is even possible to explore a project in virtual reality with a VR headset.
These formats can showcase different views of a design: exterior, interior, orthographic, and aerial view. These perspectives can give critical insights into how a design is composed and how it will manifest in the real world.
A 3D rendering, in any of these points of view, is particularly helpful for clarifying how a design uses space, allowing architects to craft optimal layouts and spot potential problems. They are also useful for clients and stakeholders to help them comprehend the overall architectural design.
Example of an orthographic view renderingExample of an orthographic projection rendering
Architectural rendering styles
Different rendering styles can be produced with the help of architectural rendering software.
  • White mode: All materials, except transparent ones, are rendered white. Particularly useful in the conceptual stages of design when the viewer should focus on the main concepts rather than the details.
  • Light view: Displays how much light will hit a surface through the representation of a heat map.
  • Sketch style: When the weight of outlines is increased to give the effect of a sketched image.
  • Photorealistic: The most realistic type of rendering. Typically when lighting, shadows, materials, and 3D models are added and refined to create a photorealistic image.
Light view in EnscapeLight view mode in an Enscape rendering
White mode in cartoon modeWhite mode and sketch style combined
How are architectural renders created?
Architectural renderings are typically created from a project modeled in three-dimensional modeling software such as SketchUp, Revit, Rhino, Vectorworks, or Archicad.
3D architectural rendering software converts the model into an image that is more true-to-life and easier to understand. Sometimes the images are so realistic it’s hard to tell if they are a digital architectural illustration (a 3D visualization) or a photo of the finished building.
With real-time rendering software, a render can be created very easily, often by clicking a button that automatically converts a model into a 3D visualization. Various elements can then be adjusted, such as lighting, materials, sun settings, cloud coverage, and 3D assets, to achieve the desired visual effects.
Visualization and rendering in Enscape
Example of a rendering created with Revit and Enscape
What do architects and designers use to render?
Different types of renderers are available to architects and designers, and it’s important to understand the difference before deciding which is best for you.
Offline renderers
Offline rendering engines, such as V-Ray, can produce strikingly realistic renders. They are typically used toward the end of the design process when there is a need to create renders of the highest visual quality and accuracy. These renderings are often used for competitions and marketing purposes.
Sometimes a visualization specialist or studio is used to make use of the full artistic and photorealistic potential of this software.
V-Ray6_Revit_Hero_ImageExample of a rendering created with V-Ray
Real-time renderers
Real-time rendering engines provide the fastest way to create 3D architectural renderings. Not all work in real time as we at Chaos Enscape define it, though 😉.
Most require additional steps in the visualization workflow. For example, if any changes are made within the rendering software itself, then these are not replicated in the source model. They have to be manually added, leading to a duplication of work that can slow down the design process.
Enscape, on the other hand, is a real-time rendering plugin that is 100% integrated into the design modeling application. As you model, you can see your project as a rendered 3D visualization that you can navigate and explore.
Any changes made in Enscape (such as adding materials or assets), are synced back to the CAD or BIM model in real time, saving you from having to manually make those changes to your original project. This is particularly useful as you can work with a single source of truth and don’t need to worry about version control.
Lacruz Design Studio - Dining Room Side
Enscape rendering, courtesy of Adriana Lacruz of Lacruz Design Studio
3D architectural rendering examples
Archviz and 3D visualization communities such as CGarchitect and the Enscape Forum are filled with examples of architectural renderings. It’s hard not to find inspiration in these spaces!
Here are a few examples of renderings produced with the real-time rendering software, Enscape.
Modern multi-family residential night rendering
Exterior rendering courtesy of forum user @Abhi Kishore
Oriental style wooden buildingExterior rendering courtesy of forum user @VAN-NHUT
School modern building renderingExterior rendering courtesy of forum user @Herbo
Ultra modern living room rendering brown leather lookInterior rendering courtesy of forum user @Joel Guerra
What happened before architectural rendering?
Before 3D rendering software came along, images were created by hand (and some architects continue sketching today - it’s a beautiful skill!).
Specialized artists would use traditional mediums such as pencil and paint to translate a project’s blueprints into scenes that could give a good impression of the finished construction.
It took a great deal of skill and knowledge for these artists to be able to accurately capture the project’s various features, including dimensions, proportions, textures, and lighting. The expertise required to create quality drawings made it so that the job usually had to be outsourced, adding significant time and costs to an architect’s project.
Example of an architectural rendering drawn by hand
When the initial rendering programs arrived, it could take hours to render a single image. The need for expertise was a barrier to adoption, and few professionals had the familiarity or know-how to work successfully with these programs.
Technology has since evolved, and now it’s possible to create an architectural rendering with the click of a button. Ease of use and an intuitive interface allows designers to DIY their renders and get stunning results in just a few seconds. Best yet, designers can go far beyond traditional visualization methods by creating videos, panorama tours, and exploring through virtual reality.
Who does architectural rendering?
With today’s real-time rendering solutions, anyone can create an architectural 3D rendering. The job no longer requires refined skills and expertise. While it certainly helps to have the aid of specialists when developing the finalized images for project presentations and marketing purposes, drafting preliminary images during the active design process is something that can be done without outsourcing or in-house specialists.
Any member of an architecture team can create a rendering using intuitive software that walks them through the process and automates even some of the most complex aspects of imaging. This frees up teams to speed through design work, making reference imagery available without the outsourcing delays that used to slow down the process.
An example of a rendering created in Enscape - modern building with a lake viewAn example of a rendering created in Enscape
What are the benefits of architectural rendering?
Using modern technology to create architectural renders brings so much to the table. And when you choose a real-time rendering solution, additional benefits to the design process can be enjoyed.
The benefits of architectural rendering in real time include:
  • Efficient ideation: Visualizing a rendered project enables architects and designers to quickly test and develop different design ideas.
  • Rapid rendering: Using a real-time rendering solution means that images, animations, panoramas, and entire project files can be exported at speed.
  • Clear communication: Architectural renders empower architects and designers to clearly demonstrate their design intent, helping to win client confidence and gain faster approvals.
Let’s take a deeper look into some of the benefits of architectural rendering.
1. 3D architectural renderings help you demonstrate value to stakeholders
Having fully detailed, explorable 3D renders means architects don’t have to leave anything to the imagination. Clients and investors can get a complete view of proposed designs, enabling them to understand what the project will accomplish and how the design and specifications are justified.
This helps firms win projects they’re submitting proposals for and also helps to improve communication and collaboration with clients. Project stakeholders can have a clear representation of what they’re getting before the first brick is even laid.
For projects requiring community approval, 3D architectural renderings, and even virtual reality, can be great tools for showing the general public how a project can enhance their community’s beauty and functionality. People can clearly visualize how they may interact with the place in their daily lives and see the value in their taxpayer investment.
2. Improve project efficiency
Rendering software that works within a BIM or CAD program allows architects to render as they design. It's the fastest and most efficient way to design, iterate, visualize, and generate all types of renderings.
3D renders can give a much fuller picture than typical drawings, and architects can fast-track project decision-making as a result. Stakeholders and contractors can more easily assess and determine what should be done when they don’t have to imagine the result. It’s a system that dramatically improves project efficiency.
3. Identify issues not apparent in architectural drawings
Rendering programs use advanced algorithms to produce the most realistic effects for architectural renders. Sunlight angles and intensities can be accurately simulated and even automatically modified in response to the addition of cloud cover, time of day, and surrounding vegetation.
Interior renderings appropriately reflect the lighting conditions as they would be in real life, allowing architects to optimize their designs for daylight exposure. They can spot when lighting is too strong (causing issues with occupant comfort and energy efficiency) or too weak.
The interactive quality of real-time renders also allows for design analysis and troubleshooting. Where a standard drawing may not indicate any issues, a virtual walkthrough may reveal that a layout doesn’t work as well as anticipated or detect clashes that could seriously disrupt the construction process.
Exterior rendering of modern building night shotExterior rendering of modern building. Rendered with Enscape.
What is the easiest way to create architectural renders?
Enscape has earned a reputation as one of the industry’s best tools for empowering architects and designers to make their own high-quality 3D renderings. The user-friendly software doesn’t require expert knowledge; it's easy to use, simplifying the creation of architectural renderings and virtual experiences (just check out some of these independent reviews of Enscape!).
By working directly inside design modeling tools such as SketchUp and Revit, Enscape provides its users with a fast real-time rendering solution. The rendering window is right there beside you, so you can take a screenshot as you walk through your project and instantly create great-looking architectural renderings.
FAQ
Why do we need architectural rendering?
Architectural rendering speeds up design development, design review, and decision-making. It enables architects to visualize, review, refine, and easily communicate their design concepts. Clients can see and understand exactly what is being proposed and can make informed decisions by viewing and interacting with realistic renderings.
What are architectural rendering techniques?
Architectural rendering techniques include 3D rendering, animation, panoramas, virtual tours, interactive walkthroughs, interior rendering, exterior visualization, and aerial rendering.
What makes a good architectural render?
Accurate lighting, realistic textures, and high-quality 3D models help to make a good architectural render. The render should also effectively communicate the key design ideas and features, helping all stakeholders understand the project.
chaos logo
Report: How AI is reshaping design & visualization in 2026
How AI is reshaping architectural design and visualization in 2026 new report from Chaos and Architizer
Share
Gemma Da Silva
Gemma Da Silva
Gemma is part of the Content team at Chaos and loves to provide architects, designers, and 3D artists with practical tips to improve their workflows and visualizations. If you have something you'd like to share with the wider Chaos community, email blog-editor@chaos.com.
