Corona rendering of an aerial view of a lush green forest canopy blanketing rolling hills in soft, dappled sunlight.
Marcin Miodek
Marcin Miodek
Last updated: December 19, 2025  •  4 min read
Corona Scatter Introduction by AsymmetricA Ltd.
Summary:
Grow yourself a forest with this step-by-step tutorial presented by UK-based creative architecture visualization studio, AsymmericA Ltd. You'll discover how to import tree models, convert to Corona materials, and scatter them over large areas using Corona, Corona Material Converter, and Adobe Photoshop in this introduction to Corona Scatter for 3ds Max.
Welcome to this Corona Scatter introduction for 3ds Max. In this lesson we are going to take a look at how easy it is to import tree models, convert them to Corona compatible materials, turn them into proxies and scatter over large areas. For this tutorial you will need Corona, Corona Material Converter and Adobe Photoshop (or similar image editor).
Corona Scatter for 3ds Max forest tutorial in steps
Part I.
1) Lets start by opening your favourite tree model – for this presentation we are using Laubwerk models, but it will work for all other commercial models like iTrees or Evermotion.
3D modeling software interface showing a digital birch tree asset being edited with the Corona Material Converter.
(fig.1)
2) Open Corona Material Converter and use the above settings (fig.1)
3) Now let’s convert the tree model to Corona Proxy file – this is not 100% necessary but it can lighten the scene if large amounts of high-poly models are used – right click in the viewport and choose “Corona proxy exporter” (fig.2) and use the following settings (fig.3) – feel free to experiment!
Corona Material Converter menu with the proxy exporter option highlighted.
(fig.2)
The Export proxy section of the Corona Material Converter menu.
(fig.3)
Corona render viewport showing a detailed tree model beside its simplified point-cloud proxy representation.
(fig.4)
4) Congrats! You have made your first Corona proxy! In case you will need to make the scene even lighter you can change the „Viewport visualization Method“ to wire box, or just set the „Point cloud“ % to a lower number (fig.4)
5) Now you are ready to make your own first scatter – to test it, let’s make a plane and a Corona Scatter object – from Create roll down menu choose Corona category and click on Scatter. Then click and drag to create the scatter object (fig.5)
Corona render viewport with a single tree model next to a large gray plane and Corona Scatter object selected.
(fig.5)
6) Assign the plane to „Distribute on objects“ and your tree model to „Instanced objects“. If you will have more than one model within one Scatter Object you can control how frequently they appear by the „Frequency“ parameter. At this point let’s just increase the „Scatter count“ under Scattering category and play around with the „Random seed“. You should get a somewhat uniform result, similar to (fig.6)
3D viewport with multiple tree models on a large gray plane.
(fig.6)
7) We just want to make the Scatter look a bit more random so let’s change some of the parameters – mainly rotation and scale. It is very neat to add some more randomness to you scattered objects by giving them slight rotation in X and Y axis, that’s why we are using -5 to 5 degrees for both, then 0 to 360 degrees for the Z axis. Scale depends on real object size but in most cases 35%-120% is ok. Again, when the scene becomes heavy just by displaying high amounts of proxied objects (even though they are displayed as boxes) you can lighten the scene by switching the „Previz type“ to Dot or None. Increase the „Scatter count“ to a number that pleases you – in our case it was 100 (this depends on the size of the area you are scattering). We end up with a much nicer and more random scatter (fig.7)
(fig.7)
8) This birch feels a bit lonely – lets load some of her friends and use the same scatter, only with higher scatter count and over a larger area (fig.8a + 8b)
Five tree models in a line on a dark gray plane.
(fig.8a)
Corona Scatter menu with settings to distribute objects.
(fig.8b)
The result:
Part II.
9) Let’s get a bit more serious about this and see what’s going to happen if we would like to scatter over a really big and non-flat area. For this we have prepared this chunk of Californian landscape (fig.9)
3D terrain model of a mountainous landscape with satellite texture applied, floating in a dark viewport.
(fig.9)
10) In order to make it even more interesting, we are going to use a bitmap for the density – simply open the satellite map you are using as texture for you terrain in Photoshop (or equivalent) and extract several shades of green as separate black&white bitmaps (fig.10a+10b+10c)
Top-down satellite view of mountain valleys, forested ridges and nearby suburban city grid at top.
(fig.10a - original texture)
Top-down satellite view of mountain valleys texture split into maps.
(fig.10b – texture split to 6 maps – each map represents a shade of green)
Black and white example of a Corona Scatter textured map.
(fig.10c – BW example of one of the 6 maps)
11) Now we will need a separate scatter object for each tree and as well one of these BW maps loaded in the „Density“ slot. As you can see the „Scatter count“ went up to 50,000 and this time it is a good idea to use „Dot“ as the „Previz type“. To achieve even more variation the scale range has been changed to 25%-150%. See (fig.11a-f)
3D scene showing scatted blue colored points across terrain with tree models lined up for Corona Scatter setup.
(fig.11a)
3D scene showing scatted red colored points across terrain with tree models lined up for Corona Scatter setup.
(fig.11b)
3D scene showing scatted yellow colored points across terrain with tree models lined up for Corona Scatter setup.
(fig.11c)
3D scene showing scatted green colored points across terrain with tree models lined up for Corona Scatter setup.
(fig.11d)
3D scene showing scatted purple colored points across terrain with tree models lined up for Corona Scatter setup.
(fig.11e)
3D scene showing scatted yellow-green colored points across terrain with tree models lined up for Corona Scatter setup.
(fig.11f)
12) You can give each scatter object different wire color for better orientation, also for more realism it is a good idea to include couple of variation of each model within each scatter group, and each bitmap may need additional corrections like in this case the city or water. (fig.12)
Viewport filled with dense multicolored scatter points indicating varied vegetation distribution across terrain.
(fig.12)
13) If you have done everything correctly you should get rewarded by a lot of trees:
-AsymmetricA Ltd.
chaos logo
Report: How AI is reshaping design & visualization in 2026
How AI is reshaping architectural design and visualization in 2026 new report from Chaos and Architizer
Share
Marcin Miodek
Marcin Miodek
Marcin is the Corona 3D Support Team Lead at Chaos, a position he has held since the first Corona release in 2015. In his role, together with his team of fearless bug-hunters, he is responsible for assisting Corona users with their queries, maintaining the Chaos Help Center and Documentation, testing the software, logging bugs, and providing feedback on new features. Marcin enjoys diving into the latest in hardware, software, and technical news, blending his passion for tech with his love for art.
