Modern house on a lake with trees and mist in the background
Dijana Boshkova
Dijana Boshkova
Published: May 28, 2026  •  6 min read
6 ways to use Corona + Veras AI ideation in your workflow
With the release of Corona 15, AI ideation with Veras is now built into your workflow and is available in all Corona plans! This integration allows archviz artists, architects, and designers to leverage AI for rapid brainstorming, quick client iterations, and instant animations while maintaining the production-grade quality of the Corona engine.
Key takeaways:
  • Native AI integration: Veras is now available across all Corona plans, bringing AI-powered creative direction directly into your workspace.
  • Unified workflow: Send screenshots from the Corona VFB or complete renders to Veras for instant ideation, eliminating the friction of manual file management.
  • Balanced production: Use Veras to explore seasons, materials, or variations alongside Corona's intuitive, high-fidelity photorealism engine at any stage of production.
Table of Contents:
Veras is now available for all Corona plans!
With the Corona 15 release, this integration brings AI power directly into your workflow, eliminating the need to juggle third-party AI tools or manage manual file exports.
By combining the speed of Veras with Corona’s intuitive photorealism, you can iterate on concepts with confidence and deliver polished results faster. This combined approach ensures you stay in your creative flow, using the best tool for every stage of the project.
In this article, we’ll explore practical ways to use Corona and Veras together and achieve superior results across every stage of your project.
👉 Try Corona + Veras together
👉 See what's new in Corona 15
What does this mean for you?
The Corona + Veras integration represents a change in how you balance creative speed and rendering quality. By bringing AI directly into your workflow, you gain access to a complete ecosystem built to accelerate the process of turning a concept into a polished visual with simplicity and ease.
  • Work without interruptions: Eliminate the friction of third-party tools or manual file exports and stay in the creative flow.
  • AI where you need it: Use Veras for rapid brainstorming, moodboards, lighting tests, and material swapping without changing scene geometry.
  • Complete artistic control: You decide how much AI to use and where it fits in your process. Use Veras for fast, interactive exploration alongside Corona's high-end, production-proven rendering capabilities.
💡 Read more: The Complete Guide to AI in Chaos Products
Use case #1: Rapid creative iteration
The official integration of Veras in Corona provides a faster way to brainstorm and present design directions before committing to a complex scene build. This is particularly useful for the initial phases of a project where visual exploration is constant, and deadlines are tight.
  • Instant visuals: Send a screenshot of your Corona VFB directly to Veras to generate dozens of conceptual directions instantly.
  • Reduced complexity: Eliminate the need to juggle third-party AI tools or manage manual file exports.
  • Strategic choice: Use Veras for rapid exploration and visual brainstorming, and rely on Corona’s engine for your final, high-end renders.
By sharing these AI-generated concepts early on, you can confirm the creative direction with your client before investing time in detailed modeling.
Veras interface in Corona Renderer with a lake house
© Chaos 3D Team
Send a screenshot of your Corona VFB directly to Veras to generate dozens of different conceptual directions
Use case #2: Accelerating client reviews and design iterations
Handling client feedback often requires time-consuming adjustments to geometry or lighting that usually necessitate a full re-render. Veras lets you handle last-minute changes and design variations directly in the image, enabling you to iterate faster during reviews and make confident decisions with your clients in real time.
  • Dynamic material swapping: Quickly test different floor, wall, and finish options without modifying your 3D scene.
  • Environmental adjustments: Instantly change seasons or adjust lighting to demonstrate how a project looks under various conditions.
  • Context and life: Effortlessly add entourage, such as people and greenery, to a view to provide a better sense of scale and life.
This integrated workflow means you spend less time on manual iterations and more time on high-value creative work.
Use case #3: Creating design variations from a single render
One of the most efficient parts of this integration is the ability to expand a single visual into multiple design options. Instead of spending hours remodeling for every possible scenario, you can use Veras to generate a wide array of environmental contexts and style variations from one Corona render.
  • Multiple views from one source: Generate additional views and detail shots from a single initial render, eliminating the need to return to the 3D scene for every new angle.
  • Explore environmental scenarios: Instantly see how your design looks in different lighting conditions or weather scenarios to find the perfect mood for your visual.
Moodboard of house renderings with different weather
© Chaos 3D Team
Explore different weather scenarios and find the perfect mood for your visual
Use case #4: Refining detail without re-rendering
Sometimes a render is nearly complete but requires an extra layer of polish to feel authentic. Instead of returning to your 3D software to swap high-resolution textures or adjust geometry, you can use Veras to refine the image directly.
  • Surface polish: Enhance the quality of walls and floors by adding realistic micro-detail and texture depth to existing renders.
  • Environmental depth: Improve the visual fidelity of environment details to achieve a richer, more detailed result with less effort.
  • Time-saving refinement: Polish your visuals and add more detail without the traditional wait times associated with restarting the rendering process.
Use case #5: Instant animation from stills
Transitioning from static visuals to dynamic presentations often requires a specialized animation pipeline and significant time. With Veras in Corona, you can turn static renders into short animations instantly, with no complex setup or extra render passes required.
  • Direct motion generation: Produce short animations straight from your still images without managing a dedicated animation workflow.
  • Professional storytelling: Enhance your presentations with smooth, controlled movement that keeps the focus on your design.
This feature provides a fast, efficient way to add motion to your project deliverables without the traditional production overhead.
Lake house on a cloudy day with reflections in water
© Chaos 3D Team
Tell an unforgettable story with just the right mood in every render. Corona and Veras give you the speed to experiment and the depth to create spaces that feel alive, instantly.
Use case #6: Scaling for more conceptual and high-volume work
The efficiency gained from the Corona and Veras integration allows you to rethink the scope and type of projects you can accept. By reducing the time spent on manual production tasks, you can take on faster, more conceptual, and iteration-heavy work that wasn't previously practical.
  • Deliver more in less time: Meet the growing industry demand for faster visualizations and bigger ideas without sacrificing your most valuable asset: your time.
  • Scale your creative output: Use AI-powered ideation to accelerate, not replace, your creativity, allowing you to move through the early stages of a project with unprecedented speed.
  • Focus on the vision: With a more streamlined and connected workflow, you spend less time managing complex software and more time on the creative storytelling that adds value to your projects.
Get started with Corona + Veras
The Corona + Veras integration brings together Veras’ AI power with Corona’s intuitive photorealistic rendering into a single, unified workflow.
Confirm design directions in minutes, iterate without remodeling, and deliver high-end visuals with significantly less friction. This streamlined experience is designed to give you your time back, letting you focus on the creative storytelling that sets your work apart.
FAQs
What Corona plans include Veras?
Veras is now available across all Corona tiers, ensuring every user can access AI-powered ideation regardless of their plan.
Do I need to export files to use AI with Corona?
No, Veras is built directly into your workflow. You can send a screenshot of the Corona VFB to Veras instantly without juggling third-party tools or managing complex exports.
Is Veras meant to replace Corona rendering?
Not at all. The two tools form a powerful partnership: Veras allows you to rapidly brainstorm concepts in pre-production, spin up design variations and animations during production, and polish fine details in post-production. This keeps Corona centered on delivering high-end, photorealistic visuals, while Veras gives you maximum creative flexibility at every stage of the workflow.
Can I create animations with this new workflow?
Yes, you can transform static Corona renders into short animations instantly with Veras, without the need for a complex animation setup or additional render passes.
What is the new Chaos credit system?
The Chaos credit system is a single currency that provides on-demand access to multiple services within the ecosystem, supporting you when you need to scale or tap into AI tools.
Ready to try Chaos products?
Start your free trial today and explore all features.
Share
Dijana Boshkova
Dijana Boshkova
Dijana is part of the Marketing team at Chaos and leads the architectural visualization content vertical. She loves writing informative and inspirational content that helps ArchViz specialists & 3D artists get the most value out of V-Ray, Corona, Vantage, and more. Have a workflow tip or an idea for a blog post? Reach out to her at blog-editor@chaos.com.
© Chaos 3D Team
© Chaos 3D Team
© Chaos 3D Team
