Cinematic Enscape render of a modern hillside house at dusk surrounded by eucalyptus trees.
Boyan Petrov
Boyan Petrov
Last updated: August 20, 2026  •  6 min read
How to turn Enscape renders into cinematic animations with Envision
In this deep dive, Chaos 3D Artist Boyan Petrov shows how to transform static Enscape renders into cinematic animations. By leveraging the new one-click live link to Envision, along with other updates such as an AI-powered assistant and animated water, he shows how this workflow makes it faster and more intuitive than ever to achieve high-end animations in Enscape.
Key takeaways:
  • Seamless live sync: A new one-click Live Link ensures real-time visual consistency from Enscape to Envision, reflecting all design changes instantly.
  • Smart asset integration: AI analyzes reference images to suggest matching 3D assets and enables natural-language searches in the Cosmos Library.
  • Automated lighting & grading: Replicate specific lighting moods from a single reference image, with AI generating setups and custom LUTs for perfect tone mapping.
  • Dynamic animations: Import Enscape camera paths and quickly add animated people and vehicles by simply drawing paths in the scene.
  • Flexible scene control: Use scene variations for view-specific adjustments and manipulate the environment (sun, terrain) for ideal shots without affecting the overall project.
Jump to a design phase:
Today, I’ll show you how to take your static renders and turn them into fully cinematic animations, complete with realistic moving people, vehicles, and high-end camera work using Enscape and Revit. It's faster than ever thanks to the new one-click live link and the new AI-powered assistant.
Eliminate re-work with a live sync
Starting in Enscape, I have this modern linear house set in nature. The interior layout is also complete, featuring a kitchen, bedroom, living room area, and bathroom. I'm happy with the design, but I really want to showcase it in a cinematic way.
All it takes to start is clicking the new Envision Live Link button right inside of Enscape. This will send everything, ensuring visual consistency. The materials, the lighting, and even the tone mapping should look very similar.
Plus, any design changes we make in Revit will be reflected instantly. That's good to have in case we have to change anything on the model. By the way, if you're new to Envision, you can switch to Easy Mode to simplify the user interface and focus only on the essentials.
The Envision Live Link feature setup dialog connecting Enscape to Envision for cinematic rendering.
📚 Read next: Discover the latest Enscape workflow features, including Envision Easy Mode
Speed up tasks with AI
To achieve a more cinematic look, we need a highly detailed scene. The AI Assistant in Envision can help with that. It can speed up tedious tasks or give us creative direction. Starting with the large details, I think the vegetation could use more improvement.
Envision handles tons of geometry effortlessly, so let's ask the assistant for some high-poly, regional-specific assets. It came up with some suggestions. I could refine the prompt to be more specific, but these are perfect for now. And then it's super easy to replace the trees in the scene with the new ones.
I'm going to continue working on the vegetation with the help of the AI Assistant. I have a reference image of a landscaping style I like, but I'm not sure which specific plant species it is. Instead of manually digging through thousands of 3D assets in the library, I can just show the assistant this image. It analyzes the photo and finds matching assets for me.
These look great, so I'll grab a few of them and quickly scatter them around the yard. Speaking of browsing, the Cosmos Library just got a lot smarter. Thanks to the new AI-powered search, you can now casually describe what you're looking for instead of relying on rigid keywords.
Chaos AI Assistant MoodMatch feature suggesting HDRIs for a sunset architectural render in Envision.
📚 Read next: The complete guide to AI in Chaos products
Get perfect golden-hour lighting
Alright, so I'm mostly ready with the scene in terms of adding detail. The next step toward creating a cinematic animation is to refine the lighting. Lighting is everything when it comes to immersion, but getting it right can be tricky and time-consuming.
Manually matching lighting to a reference photo isn't design, and digging through thousands of assets to find one that fits only slows down your vision. The AI Assistant fixes that by replicating a specific mood based on a single image.
Chaos AI Assistant matching a landscape photo mood to an Enscape architectural render in Envision.
Here is a reference image of the exact look I want: a vibrant, soft-lit golden-hour sunset. The assistant automatically generates a few lighting setups based on this image. I can click through them to preview or ask for more options. I think the first option is a very good match.
But getting the light right is only half of the process. Tone mapping is just as important. The assistant takes care of this by generating custom lookup tables, or LUT for short, to better match the color grading of the reference. And this is how I got from a bland image to something very close to what I'm after in no time.
From here, I can manually tweak things further. I'll dial back the tone mapping slightly and introduce a bit more direct sunlight to make the vegetation pop and bring the whole image to life.
📚 Read next: A simple guide to lighting basics for 3D rendering in Enscape
Fine-tune your animation
Now that the scene is enriched and well-lit, it's time to set up cameras for the final animation. Since I already created some camera paths in Enscape, I can simply import the XML file containing them. I have the exact same animation in Envision and can continue refining it. I can also edit keyframes or add new ones. Furthermore, I can add animated people. I'll just draw a path for them to walk on and then select a model from the library. And that's how easy it is.
To make the most of the animation, I can adjust the lighting and rearrange objects to enhance the composition of each shot. That's where the scene variation comes in handy. For example, I can change the curtain here to soften the light and cover the windows so that it's less distracting. Because I want to limit the adjustment to a specific view, I can use a new scene variation. This allows me to make significant modifications without affecting the result of the project.
Envision timeline editor showing camera and environment tracks for cinematic animation sequencing.
Bring your scene to life
Adding vehicles is just as easy as adding people. Draw a path and generate. While this tool is meant to generate complex traffic simulations with many vehicles, in this case, I only need a single vehicle to support the storytelling. By the way, water surfaces in Envision now animate directly in the viewport, just like in Enscape. So you can see your oceans, rivers, and pools in real time without waiting for a final render.
I can then freely explore the building and the environment from different angles, just like a photographer walking around, looking to capture an interesting composition. Furthermore, working with the complete digital landscape provides the unique ability to manipulate the environment itself, whether it is repositioning the sun or shifting an entire mountain to create the ideal shadow and capture that perfect shot.
Envision traffic tool with vehicle asset library for adding animated cars to an architectural Enscape render.
📚 Read next: Enscape water material - best rendering practices
From static to cinematic, faster than ever
And there we have it! a complete cinematic animation achieved in a fraction of the time. The gap between your Enscape models and high-end animation has never been shorter, thanks to a powerful, intuitive workflow.
From the one-click live sync to the AI Assistant that perfects your lighting with a single reference image, every step is designed to accelerate your creative process. You no longer need to be just a designer; you can be a director, a photographer, and a storyteller, all within a single, fluid ecosystem.
👉 Try the Enscape Collection and take your visuals further
Ready to try Chaos products?
Start your free trial today and explore all features.
Share
Boyan Petrov
Boyan Petrov
Boyan is a 3D artist who's interested in creating architecture and VFX shots that tell a story. He graduated from Saxion University in the Netherlands, specializing as a Game Designer. In his free time he likes to play guitar and do handstands, not at the same time.
