Enscape rendering of open plan living, dining, and kitchen room outlooking to the balcony
Dijana Boshkova
Dijana Boshkova
Last updated: October 09, 2025  •  2 min read
7 Reasons Why Enscape is the Smart Choice for Your Design Workflow
Real-time rendering tools offer many benefits, but the reason why Enscape is a crowd favorite is simple: By incorporating Enscape into your workflow, you can achieve more in less time.
If you’re on the lookout for ways to improve the efficiency of your architectural rendering workflow without compromising the quality, then you’re in the right place. Here’s how Enscape can boost your productivity, as confirmed by customer insights from a survey in January 2024:
1. It’s easy to use
Thanks to its shallow learning curve, Enscape is ideal for both beginners and seasoned designers. You don’t need prior specialized knowledge, and 95% of surveyed customers agree that it is easy to use.
2. It saves you time
Generating renderings takes seconds, not hours, allowing you to create more and share more often for faster design decisions. Almost half of the respondents saved 2-4 hours per week by using Enscape, and 1 in 4 customers saved half a working day or more by using It.
Enscape collaborative annotation tool in an interior rendering
3. It reduces costs
Enscape lets you give clients a complete understanding of their building before it’s built with immersive features such as virtual reality. This ensures your vision and their expectations are aligned and minimizes the need for extensive redesigns, making production time more efficient. It can even cut down project costs, with 62% of the surveyed customers attesting so and 2 out of 3 customers seeing clear ROI.
4. It’s perfect for daily use
With so many built-in features, Enscape provides you with the tools you need. Everything is in one place, from the rich asset and material libraries to viewing BIM information. Half of the survey participants use Enscape at least a few times per week, and 25%, every 1 in 4 users, use Enscape daily.
5. It increases productivity
As a plug-in and not a standalone application, you work with a single source of truth. Any adjustments made to the model will be reflected in Enscape without a single import or export. This fluidity enables you to develop more accurate documentation. 87% of the surveyed customers agree that it helps them save time, which means Enscape increases productivity for 9 out of 10 customers.
Woman and man at a desk collaborating, pointing at the monitor while exchanging feedback
6. It accompanies every design stage
Enscape is a workflow optimization tool that accompanies you at every stage of the design workflow. Its real-time rendering function lets you render in the moment, allowing you to validate ideas at any point throughout your process. The survey revealed that design reviews, client presentations, and model walkthroughs are the top three use cases.
Read: How shipbuilder Damen uses Enscape to speed up the design process and give client presentations.
7. It’s revered by the community
Enscape’s robust features, rapid performance, and cost-effectiveness make it a favorite tool within the AEC industry. It is used in over 150 countries and has over 500,000 active monthly users. 9 out of 10 (89%) survey respondents find Enscape an integral part of their workflow.
Download the infographic
Infographic listing 7 reasons why Enscape is the real-time visualization plugin for design workflows
chaos logo
Report: How AI is reshaping design & visualization in 2026
How AI is reshaping architectural design and visualization in 2026 new report from Chaos and Architizer
Share
Dijana Boshkova
Dijana Boshkova
Dijana is part of the Marketing team at Chaos and leads the architectural visualization content vertical. She loves writing informative and inspirational content that helps ArchViz specialists & 3D artists get the most value out of V-Ray, Corona, Vantage, and more. Have a workflow tip or an idea for a blog post? Reach out to her at blog-editor@chaos.com.
