Gemma Da Silva
Gemma Da Silva
Last updated: December 19, 2025  •  3 min read
Enscape Users Render Cyberpunk 2077 with Incredible Results
Cyberpunk 2077 is an open-world video game developed by CD Projekt Red, released in December 2020.
Not long after its release, we spotted a few Cyberpunk renders and videos that had already been recreated in Enscape by a few of our users – including regular contributor Lasse Herbo Madsen. We were astonished at what had been created!
Take a look at these impressive renders and get a glimpse into some of the techniques that Lasse used to achieve these effects.
Cyberpunk in Enscape by Lasse Herbo Madsen
Cyberpunk_street_1_final_post
“I've wanted to try out a bunch of stuff for a long time, and I figured that a Cyberpunk scene would be the perfect setting for it! My goal was to create as many effects as possible directly inside of Enscape, and that is exactly what I did.” explains Lasse Herbo Madsen, an architect at Vilhelm Lauritzen Architects, who are based in Copenhagen, Denmark.
“Rain, smoke, fog, and haze is all done directly in Enscape. All that has been done in Photoshop is a small amount of color grading. I wanted a very specific atmosphere and light in the scenes, and I'm really impressed at how well Enscape has handled it! The models are from various places, and the scene is composed and set up myself. Most of the textures, including the street, are done using Quixel Mixer."
Enscape is an incredible tool, and it is quickly closing the gap to traditional offline renders, especially when you push it to the edge.
Lasse Herbo Madsen, Vilhelm Lauritzen Architects
Cyberpunk_street_2_final
Cyberpunk_street_4_final
Linked models in SketchUp
Here, Lasse shares a few cuts from the original rendering and some SketchUp model shots to show the setup, which he explained was mostly done with linked models.
cyberpunk_collage_1
SketchUp View 1
sketchupview_2
Creating rain in Enscape
Lasse goes on to explain how he created the rain effect in Enscape for his Cyberpunk renders:
“It is basically all done with pngs. The rain is done by making a bunch of regular planes standing on the ground, distributed around evenly. I've played a lot with the texture itself, as you have to get the transparency, the scale and the amount of droplets right here.
Transparency is especially important, as it will not work to add this in the Enscape material editor; this makes the wrong effect. Instead, it should be set to the right amount in the png itself. I've also added some impact splatter in the bottom to emphasize the rain hitting the ground. Make sure this is not making a straight line in the bottom of the texture, as this will show up in the renders.”
creating rain in Enscape
Rain in Enscape
The above image is a jpg with a black background so you can see the rain effect. To try this technique yourself, you can download the original png files that do not have a background here.
Creating a haze around light sources
Lasse goes on to explain how he was able to create the haze around the street lights.
“The haze around the lights sources and other places are made in a similar fashion. I've made a png with all the right settings and then added the texture to a plane that is placed in the model. Here is an example from the street lights:”
Creating a haze in Enscape
Creating a haze in Enscape example
“The smoke effects are made in the exact same way. The overall fog in the image is made as a combination of the native Enscape fog, a big png, and some clever placements of light sources. Here you'll have to experiment!”
Using modular textures for the Cyberpunk street
Finally, Lasse mentions his use of Quixel Mixer to help him create the right texture for his Cyberpunk street scenes.
“The street is made of three modular textures, each containing all the detail directly on the map itself. This is the strength of Quixel Mixer; being able to add all the details you want and then merge it all into one simple texture with all corresponding maps. Here are the three street segments as seen in Mixer:
Street scene in Mixer
Street scene 2 in Mixer
Street scene 3 in Mixer
Thanks to Lasse for sharing a few of the processes he used to help him achieve these super realistic Cyberpunk scenes. The results are outstanding. Congratulations Lasse!
chaos logo
Report: How AI is reshaping design & visualization in 2026
How AI is reshaping architectural design and visualization in 2026 new report from Chaos and Architizer
Share
Gemma Da Silva
Gemma Da Silva
Gemma is part of the Content team at Chaos and loves to provide architects, designers, and 3D artists with practical tips to improve their workflows and visualizations. If you have something you'd like to share with the wider Chaos community, email blog-editor@chaos.com.
