Interior rendering futuristic white
Dijana Boshkova
Dijana Boshkova
Published: March 02, 2026  •  9 min read
25 Free video tutorials for archviz beginners (6+ hours of learning content)
Explore the curated collection of free video tutorials for beginners in architectural visualization and learn the fundamentals. From software-agnostic physics of light explanations to more advanced lighting and material settings and AI-driven workflows, these resources are handpicked to help you achieve photorealism faster.
Key takeaways:
  • Foundational mastery is a must: Your success as an archviz artist largely depends on mastering lighting physics, material accuracy, and photographic composition.
  • Industry-standard pipeline: Starting with an industry-standard pipeline, such as 3ds Max + V-Ray or 3ds Max + Corona, is the most effective workflow for lifelike imagery.
  • AI integration: Learning how to use modern AI tools will significantly reduce manual work and accelerate workflows by automating tasks such as upscaling, denoising, and adding realistic scene details.
Table of Contents:
What are the most important skills for archviz beginners?
The most important skills for archviz beginners are a deep understanding of the light physics, material properties, and photographic composition. While software mastery is necessary to be able to execute the artist's vision, the “art of seeing” is what separates great artists.
Focus on these three pillars to establish the foundation of architectural visualization:
  • Lighting physics: Understanding how light bounces (Global Illumination), the difference between hard and soft shadows, and how color temperature affects the mood of a space.
  • Material accuracy: Learning the PBR (Physically Based Rendering) workflow to ensure surfaces like wood, glass, and metal react to light exactly as they do in the real world.
  • Composition & staging: Developing a photographer’s eye for camera angles that highlight features and staging the scene with entourage such as furniture, people, and plants to tell the story of a lived-in place.
architectural model building
Chaos 3D Team
The essential building blocks: Mastering archviz fundamentals
Here are some tutorials that break down the fundamentals of architectural visualization.
Photorealism Explained by Blender Guru
Andrew Price breaks down the fundamental laws of realism and covers the four pillars of photorealistic rendering: modeling, materials, lighting, and post-processing. This video is essential for understanding why renders look "fake" and how to fix them.
Beginner's Guide to Mastering Color Theory by Grant Abbitt
This guide explains essential concepts like hue, saturation, and value specifically for 3D artists. You’ll learn how color palettes can dramatically change the mood of your story.
4 Composition Techniques for your Architecture Images by Show it Better
Since composition is 50% of a great render, you need to think like a photographer. This video explains how to find the hero angle of a building, use the rule of thirds, and avoid common mistakes, such as leaning vertical lines.
💡 Master the art of visual storytelling with the 2026 ArchViz Masterclass, where timeless creative fundamentals meet the power of AI-driven workflows.
What is the best archviz workflow for beginners?
The best workflow for archviz beginners is a project-based approach that smoothly transitions from 3D modeling to a high-end rendering engine such as V-Ray or Corona.
Starting with the 3ds Max + Corona or 3ds Max + V-Ray combination may be a good choice for beginners, as this industry-standard pipeline allows you to transform raw architectural plans into photorealistic imagery.
By focusing on this specific workflow, you are learning the tools used by the world's top visualization studios. This process typically involves:
  • Modeling: Building clean, accurate geometry based on real-world measurements.
  • Camera setup: Placing your virtual lens using photographic principles like the rule of thirds.
  • Lighting: Using Sun/Sky systems or HDRIs to replicate natural light physics.
  • Shading: Applying PBR (Physically Based Rendering) materials to ensure surfaces react realistically to light.
Archviz beginner tutorials for 3ds Max
Here are some tutorials to help you get started with your 3ds Max workflow.
3ds Max Tutorial: Beginner Guide by Arch Viz Artist
This is a focused introduction to 3ds Max specifically for complete beginners in the field. Agnieszka Kwiatek walks you through the software, covering the File Menu, Viewports, the Command Panel, and selection options.
Getting Started with V-Ray for 3ds Max by Chaos
Straight from the source, this official Chaos tutorial is the perfect entry point for the software. The video explains how to set up your first V-Ray camera, apply basic materials, and use the Sun & Sky system to produce a clean, professional render in minutes.
💡Pro tip: The V-Ray ArchViz channel on YouTube offers many more beginner-friendly tutorials for a deeper dive into the product!
3ds Max Modeling + Corona Render Masterclass by Simple or Difficult
This project-based masterclass takes you through a complete workflow. In this tutorial, you will learn how to model a modern interior scene from scratch, set up photorealistic lighting using Corona, and apply high-quality textures to create a photorealistic image.
Getting Started with Chaos Corona for 3ds Max by Chaos
In this practical guide, you'll learn how to take a project from start to finish using the latest tools. Watch the full playlist to dive deeper into the 3ds Max + Corona workflow.
Why are lighting and shadows important for archviz?
Lighting and shadows are the most important elements in archviz because they define the space's volume, depth, texture, and mood. By simulating how natural and artificial light sources interact with elements and surfaces, you transform flat geometry into a tangible, lifelike environment.
Beyond the technical aspects, strategic lighting and shadows set the mood and guide the viewer’s attention to key areas of the scene.
Lighting & shadow tutorials for beginners
Here are some videos to help you master the basics of lights and shadow in archviz.
The fundamentals of lighting by Arch Viz Artist
This tutorial breaks down core basics like light intensity, direction, and how color temperature affects realism.
HDRI Lighting Setup for Interior Visualizations by Arch Viz Artist
Learn the exact process for setting up HDRI Lighting specifically for interior visualization projects in 3ds Max + Corona.
Interior Lighting in 3Ds Max with Corona & HDRI by inchi studio
Discover how to work effectively with light and shadows to achieve a natural, photorealistic atmosphere in 3ds Max.
Realistic interior day lighting with V-Ray for 3ds Max by Chaos
In this tutorial, you’ll see how to light an interior day scene with V-Ray for 3ds Max, set up a V-Ray Sun and Sky system, and light your scene by creating a V-Ray Dome Light and loading an HDRI.
V-Ray interior lighting set up by PRODESIGN
Master interior lighting setup to achieve photorealistic rendering results with SketchUp and V-Ray, with the technical remedies and easy fixes for common mistakes.
Exterior Render Lighting Techniques by Arch Viz Artist
Learn how to work with various natural lighting scenarios, from the Golden Hour and Blue Hour to midday and night setups, and how to layer artificial lighting to create depth and highlight forms effectively.
How do I create realistic materials for archviz?
In archviz, realistic materials are created using the principles of Physically Based Rendering (PBR), which dictate how surfaces reflect and absorb light according to real-world physics. Mastering the material creation in archviz isn’t only about choosing the prettiest texture but rather about understanding how light interacts with different surfaces.
Beginners can move away from flat-looking renders by focusing on:
  • PBR workflow: Using a standardized set of textures to ensure materials look correct under any lighting condition.
  • Reflections and glossiness: Fine-tuning how shiny or dull a surface is to mimic real-world wear and tear.
  • UV Mapping: Ensuring your textures wrap around your 3D objects correctly without stretching or seams.
  • Procedural vs. bitmaps: Knowing when to use a high-resolution photo (bitmap) versus a mathematically generated texture (procedural).
Material & texturing video tutorials
Here are some resources to guide you through the material & texturing part of the process.
PBR Materials Explained by Graffinity3D
This video offers a clear, straightforward breakdown of how Physically Based Rendering works to create professional-grade 3D surfaces.
How to Make Photorealistic PBR Materials by Blender Guru
This tutorial introduces the fundamental PBR workflow used to define the physical look and feel of 3D surfaces. You will learn how core texture maps work together to achieve professional realism in architectural visualization.
PBR Materials Explained by Educk
This thorough guide explains how to create photorealistic materials by covering both the Metallic and Specular PBR workflows, as well as practical applications for wooden floors, fabrics, and metals.
3 Steps to Create Photorealistic Materials in Blender by Chaos
Learn the three primary methods for creating professional materials: using AI generation from photos, importing from the Chaos Cosmos library, or building custom shaders from scratch.
AI Materials - Cosmos for Corona & V-Ray by Learn Corona Render
Discover how the latest AI-powered Material Generator allows you to instantly create professional-grade materials and textures in Chaos Cosmos.
Which post-production techniques should I use to finalize my renders?
Post-production is the so-called digital darkroom where you refine colors and contrast to create emotional storytelling. AI has revolutionized this stage, enabling you to upscale, denoise, and add details like people or plants in seconds.
Key techniques include:
  • Color grading and LUTs: Using Look-Up Tables (LUTs) and AI color-matching help create a consistent, cinematic mood across your project.
  • AI denoising and upscaling: These tools enhance lower-resolution renders to 4K or 8K while removing "grain" without sacrificing fine architectural details.
  • Generative fill: AI-powered tools in Photoshop allow you to instantly add realistic people, plants, or background buildings that automatically match the lighting and perspective of your 3D scene.
  • Post-render light mixing: Features like Corona’s LightMix let you adjust the intensity and color of individual lights after the render is complete, effectively "re-lighting" a scene without needing a new render.
Post-production video tutorials for beginners
AI Post Production for Arch Viz Artists by Jake Denham
Explore how to integrate AI tools into any 3D workflow to upscale images with Magnific, use Generative Fill for adding scene details, and enhance the quality of 3D people and textures.
3D Artist Uses AI in Visualization Postproduction Process in Photoshop by Arch Viz Artist
Join a professional walkthrough of a post-production workflow that integrates AI to streamline traditional tasks. This tutorial covers everything from initial adjustments in the Frame Buffer to using AI Generative Fill and the Remove Tool in Photoshop to fix issues and add realistic environmental details effortlessly.
Save hours with V-Ray 7.2 AI Features by Arch Viz Artist
Upgrade your workflow by mastering V-Ray 7.2's new AI Enhancer and Upscaler to add incredible detail to your renders, and use the AI Material Generator to create textures instantly.
Workflow for 3DS & Corona + AI for interior designers by VizAcademy UK
Explore how the traditional Archviz workflow is evolving in 2026, with a focus on AI-assisted modeling to future-proof your career.
20 More Photoshop Tips, Tricks & Secrets for Architecture by Upstairs
Master advanced Photoshop techniques to speed up your architectural workflow while delivering lifelike, professional visuals.
Post-processing your renders in V-Ray for SketchUp
Master V-Ray for SketchUp's post-processing tools to apply color corrections, fine-tune lighting with Light Mix without re-rendering, and use Chaos Cloud Collaboration to gather client feedback.
Rendering Post-production | Photoshop for 3D artists by Learn Corona Render
Elevate your renders by moving beyond simple contrast curves, and see how a simple Photoshop trick with lights & shadows brings your image to life.
Conclusion
Mastering architectural visualization is a journey of balancing technical precision with artistic intuition. By focusing on the core pillars of modeling, lighting, and materials, and leveraging the massive advantages of modern AI, you can create portfolio-ready renders that truly resonate with clients.
🗣️ Join the community @ CGconnect
The journey doesn't have to be solo. If you're looking to grow alongside other artists, CGconnect is the dedicated space for the design and visualization community. It’s the perfect place to connect with peers, get expert advice on your latest WIPs, and stay inspired by the incredible work being produced across the industry.
Ready to try Chaos products?
Start your free trial today and explore all features.
Share
Dijana Boshkova
Dijana Boshkova
Dijana is part of the Marketing team at Chaos and leads the architectural visualization content vertical. She loves writing informative and inspirational content that helps ArchViz specialists & 3D artists get the most value out of V-Ray, Corona, Vantage, and more. Have a workflow tip or an idea for a blog post? Reach out to her at blog-editor@chaos.com.
Chaos 3D Team
