Vitor Souza is a senior 3D modeler and designer based in Rio de Janeiro, Brazil. After first gaining interest in the world of 3D graphics and gaming as a teenager, he quickly jumped into 3D modeling, working on games and in product design. Over his career, he has produced product visualizations for DT3, a pioneering brand in the gaming chair market.
Creating photorealistic product visualizations is absolutely essential for retailers looking to bridge the gap between consumer expectation and reality. The ability for a customer to clearly see an item up close and from all angles, closely inspect the materials, colors, and features, not only contributes to conversion but can lower return rates and build brand trust. For 3D modelers and designers, this means it's crucial to find ways to most accurately and best represent these products.
This article presents the technical analysis of a real product: an imported ergonomic chair. We’ll explore the complete visualization workflow in minute detail, from advanced lighting strategies to the integration of the Chaos ecosystem. You’ll also learn how the synergy between V-Ray 7 and Chaos Cosmos was fundamental to achieving the photorealism and productive efficiency of this project.
1. Complex materials and anisotropy
Credit: DT3 and Vitor Souza
In the Frost project, the shader challenge went beyond metallic surfaces, applying concepts of light physics to polymeric and textile structures:
- Polymer structure: For the chair body (white/ice finish), we implemented complex materials with Subsurface Scattering (SSS). This technique simulates light penetration into surface layers, reproducing the characteristic translucency of high-density polymers. The result is a material that avoids the "solid and dry" appearance of common plastic, gaining life at the edges and areas of greater light incidence.
- Anisotropy in the piston: The metal base and central piston were configured with refined anisotropy. This ensures that studio reflections extend and follow the cylindrical curvature in a mathematically precise way, reproducing the real behavior of brushed or machined metal.
2. V-Ray Enmesh: optimization and geometric detailing
The use of V-Ray Enmesh on the perforated backrest is undoubtedly the technical "heart" of the Frost project. It's a practical example of how technology can superiorly replace traditional methods:
- Intelligent geometric pattern: Instead of resorting to destructive modeling of each hole or using Opacity maps, which often generate shadow artifacts and increase rendering time, we opted for Enmesh. It distributes the geometry of the hole pattern directly onto the surface at render time.
- Performance and precision: This approach keeps the viewport extremely lightweight, facilitating scene manipulation. The end result delivers physically perfect shadows and real volume at each intersection of the pattern, guaranteeing a level of detail impossible to achieve with simple textures.
- The volumetric effect of enmesh: Using V-Ray Enmesh on the Frost chair created a surface with real physical thickness. This generates optical phenomena that conventional (2D) opacity maps are unable to replicate. As the camera angle moves, the holes "close" or "open" due to the depth of the geometry. This parallax behavior reinforces the perception of the chair as a solid, technical, and three-dimensional object, eliminating any aspect of "thin film" or flat texture. Furthermore, light not only passes through the backrest, it bounces off the internal walls of each micro-hole. This effect generates a "volumetric transparency": the chair conveys lightness and permeability, but maintains the visual robustness of injected plastic.
- Render efficiency: At smaller scales, Enmesh functions more as an optical volume generator than as an isolated geometric detail. When the holes are very small, the human eye and the virtual camera do not focus on the individual hole, but rather on how light passes through and behaves within that perforated mass. While rendering speed gains might not be massive at this scale, the preparation speed is significantly improved over traditional methods. If your delivery deadline is tight, it is a perfect strategy to streamline and optimize your time management and delivery quality.
3. Materials curation: technology and lightness
Close ups of mesh and headrests
The choice of polymers followed a logic of functionality and realism, using the Chaos Cosmos library as a basis for customization:
- Asset selection: Variations such as Plastic_Simple_White_C01 and Plastic_Grainy_White durable finishes were used. The combination of these textures allowed for differentiation between smooth parts and areas with more grip and resistance.
- Technical adjustment and colorimetry: To avoid a "matte plaster" appearance, Refraction Glossiness was slightly reduced and Subsurface Scattering (SSS) was implemented. In tonal control, the starting point was the native white of the materials, and the grayscale was gradually worked, ensuring that the polymer reacted to studio lighting with depth and volume, achieving the exact tone of the real pieces.
- Seat mesh (technical fabric): The Frost seat has a very specific specular sheen, typical of synthetic fibers. Materials like Fabric_Mesh_A01 or Fabric_Upholstery_Net best suit this high-performance office chair look. The use of a strong Displacement or Bump map here generates that tactile relief that "holds" the light, creating micro-points of shine on the seat.
- Base metal (brushed aluminum): The Frost base is light and clean, focusing on neutrality. Aluminum_Satin or Metal_Aluminum_Anodized were the logical choices. Applying anisotropy, the Cosmos material served as the base for albedo and reflection, while the anisotropy parameters in the V-Ray Material created the circular brushing effect that defines the metallic base.
- Black plastic details: Plastic_Rough_Black was chosen with high roughness to ensure these components remain hidden in the shadows, maintaining visual focus on the white structure and the perforated backrest.
Materials mapping for ‘Frost’
| Object part | Identified material | V-Ray technique/pillar |
| Perforated backrest | Technical polymer / mesh | V-Ray Enmesh (Geometric Pattern) for realistic volume. |
| Structure (frame) | Solid injected plastic | Complex Materials with subtle glossiness and SSS. |
| Seat | Technical fabric (mesh) | Microtexture via Displacement or high-res Bump. |
| Base and casters | Brushed aluminum | Anisotropy for linear metallic reflections. |
| Under-seat mechanism | Rigid plastic / painted metal | Low-reflection shaders to maintain focus on the seat. |
4. Lighting setup and positioning
The studio setup was designed to treat light as a precision tool to explain the chair's engineering:
- Top light: A large rectangular V-Ray Plane Light or Softbox, positioned directly above the chair. This creates the smooth gradient that descends along the backrest, defines the shoulders of the chair, and cuts through the mesh to reveal the "block transparency."
- Side rim lights: Two narrow vertical lights positioned on the rear diagonals (left and right). These create the rim light that separates the white plastic from the black background, emphasizing the physical thickness of the frame.
- Kick light: A small, low-intensity light focused on the metal base to activate the anisotropy of the aluminum, stretching the reflections to reveal its metallic nature.
- The "High-Tech Glow" intention: The exposure was controlled to maintain the white at a light gray level (white clip around 0.8 or 0.9), avoiding pure white (1.0) to preserve the readability of shadows within the micro-holes.
- Color temperature: The atmosphere is strictly cool, utilizing values between 6000K and 7000K to reinforce the name "Frost" and the feeling of a modern engineering product. Cooler lighting emphasizes micro-contrasts, cleanly cutting the geometry and keeping highly reflective objects from blowing out. It provides a serious and sober tone reminiscent of high-end corporate or laboratory environments.
Technical Values
| Source | Intensity (multiplier) | Temperature (K) | Render function |
| Top light | 20.0 - 40.0 | 6500K | General volume and seat illumination. |
| Rim lights | 15.0 - 25.0 | 7000K | Silhouette definition against the black background. |
| Base light | 5.0 - 10.0 | 6000K | Highlighting the metal base and casters. |
The role of V-Ray Light Mix: Light Mix allowed us to individually reduce the intensity of the top light in post-rendering, ensuring that the mesh detail wasn't washed out by excessive brightness. It also enabled us to increase the brightness on the metal base without affecting the exposure of the fabric seat, achieving a dynamic balance difficult to replicate with physical lights alone.
Conclusion
The convergence of these workflow strategies results in a high-precision rendering process that eliminates the boundaries between CGI and reality. By bringing the DNA of real-world photo references into an optimized Chaos Cosmos asset framework and leveraging V-Ray Enmesh, complex shader and geometry setups are transformed into highly efficient production steps. This delivers the photorealism of photography with the structural flexibility demanded by the modern market.
Ultimately, technical sobriety achieved through precise exposure control, cool color temperatures, and adaptive Light Mix adjustments removes emotional "noise" and redirects focus back onto the product’s core engineering and material quality. Through this optimized ecosystem, 3D models cease to be simple renders and transform into flawless digital assets ready for real-world high-end commercial use.
