Modern white office building with large glass windows, surrounded by trees, with people walking in the foreground and a car parked on the street.
Kalina Prelikj
Kalina Prelikj
Last updated: January 13, 2026  •  8 min read
How to speed up the architecture ideation process
You can speed up the architecture ideation process by sketching, sharing ideas early, and using tools like Veras, Enscape, and AI Enhancer to explore and refine ideas in less time.
This guide looks at practical ways to work more efficiently in the early design phase, from setting clearer goals to using rapid ideation techniques. It also explores how a trio of tools (Veras, Enscape, and AI Enhancer) can help you visualize, iterate, and refine concepts faster than ever.
To set the stage, let’s look at why early design can be both the most creative and the most challenging part of the process.
Table of contents
1. Grounding the ideation process
2. Meet the power trio: Veras, Enscape & AI Enhancer
3. How to use Veras, Enscape, and AI Enhancer together
4. AI is a design partner, not a replacement
5. Getting started: tips for integration
6. FAQs
Grounding the ideation process: techniques before the tools
You aren’t really able to get a good idea from a blank screen. First, you’ll need to clearly understand the problem and do a few quick sketches to try things before overcommitting. In other words: start analog.
Here are a few techniques that can help you speed up your thinking before the software even loads.
  • Define the problem and the constraints.
  • Use rapid ideation methods.
  • Prototype quickly and share your ideas early.
  • Keep creativity flowing.
Let's look at each one of these techniques in more detail.
Sketching ideas for an architectural projectCredit: Lex Photography
1. Define the problem and the constraints
One of the biggest time-wasters in early design is not knowing what the idea is meant to solve. To avoid spinning in circles, ground your process with a few essential steps:
  • Understand who you’re designing for: What do they actually need? How will they move through the space? What matters most in their day-to-day use?
  • Study the site: Orientation, access points, views, climate, and surrounding context all shape the design, whether you intend them to or not.
  • Set boundaries early: Budget, technical limitations, and programmatic needs aren’t obstacles, but parameters that help focus your creative energy.
  • Define the goals: Is this project about adaptability, identity, sustainability, or something else entirely? A clear purpose helps eliminate guesswork and sharpens your decisions from the start.
2. Use rapid ideation methods
When time is limited, detail is not your friend. But speed is. Some quick ways to embrace it include:
  • Sketch freely: Massing, flow, form, light. Put it all on paper (or tablet) without trying to get it right. Getting it out is the point.
  • Mind map spatial ideas: Especially when dealing with overlapping functions or abstract design goals. It helps clarify what belongs together.
  • Look beyond architecture: Take cues from nature, industrial design, or anything with form and function. Cross-pollination often sparks the best ideas.
  • Use AI for variation, not validation: Try using Veras or other generative tools to create quick visual prompts. Instead of expecting clear answers, look for new directions.
Sketch uploaded into the Veras web-based app with prompt
Upload a sketch to Veras and see AI-rendered ideas
3. Prototype quickly and share your ideas early
It’s easy to fall in love with an idea in your head. But make sure it works in space. To get there faster:
  • Build fast and dirty: Use paper models, foam blocks, rough digital form. Whatever gets the idea into three dimensions quickly.
  • Get feedback sooner: Share rough ideas with peers or stakeholders. Early input saves late revisions.
  • Try a quick digital check: If you want to see a sketch in context, the web version of Veras can generate a 3D visualization in minutes, or you can open your CAD model in Veras via Enscape.
Dan Stine-Enscape rendering in Veras Web 04b-1
Credit: Dan Stine
4. Keep creativity flowing
Getting too detailed too early can slow down the ideation process. Use these quick tips to stay flexible and productive:
  • Don’t overdefine too soon: Avoid locking in every line, material, or layout before the concept is ready.
  • Prioritize momentum: Keep your ideas moving by sketching, modeling, and comparing rapidly.
  • Externalize your thinking: Capture ideas visually on paper, whiteboards, or pin-up walls to spot patterns and opportunities.
  • Stay flexible: Let ideas evolve mid-process. Many of the best concepts emerge through iteration.
Once the groundwork is in place, tools like Veras, Enscape, and AI Enhancer can help you iterate faster and visualize more clearly. But without a strong starting point, even the best tools won’t take you far.
Once your concept is in place, these three tools, which are all available within Enscape, can help you move faster, from sketch to presentation-ready visuals:
  • Veras: An AI-powered generative design tool;
  • Enscape: A real-time rendering tool;
  • AI Enhancer: A post-processing tool for clean, polished renders.
Together, they form a streamlined workflow for fast, flexible ideation.
From sketch to concept in minutes with Veras
What is Veras? It's an AI-powered ideation and visualization tool for architects that helps you generate and refine design concepts using prompts, sketches, or model overrides right inside Revit, Rhino, SketchUp and other modeling software.
It’s built for early-stage exploration, making it easy to test out mood, material, or massing ideas quickly without starting from scratch.
Prompt, material, and geometry overrides in Veras and Enscape copy
Veras
Design, visualize, and iterate with Enscape
Enscape is your design companion for better decisions in real-time, offering real-time rendering inside BIM/CAD tools like SketchUp, Revit, and Rhino.
You can model and visualize simultaneously, test lighting and materials instantly and walk clients through immersive environments via VR or live walkthroughs, all while staying in your design tool.
Close-up of a modern building facade with vertical wooden paneling, balconies, and windows, shown alongside Enscape material editor settings.
Enscape for Rhino
Final touches with AI Enhancer
Chaos AI Enhancer boosts visual quality with AI in Enscape by refining people and vegetation in a single click.
It brings post-production effects, clarity adjustments, and stylistic polish to your Enscape or Veras renderings, and no extra software or time is required.
AI-Enhanced image of people sitting outside of a building
Refined with AI Enhancer
You can use Veras, Enscape, and AI Enhancer together for a combined workflow, from early ideation to client-ready renderings. Each tool plays a specific role and when used together, they can dramatically speed up the design process without sacrificing design quality or clarity.
Rendered version of sketch from Veras web app copy
Veras
1. Explore design variations quickly with Veras
Use Veras as your AI-powered ideation engine. It helps you move through early concepts without slowing down.
With Veras, you can:
  • Generate visual ideas from prompts or rough geometry;
  • Explore multiple façade, massing, or material options in minutes;
  • Iterate visually before committing to modeling or detailing.
For instance, in the Villa am Hang penthouse extension project by Germany-based architect Marco Iannelli, Veras was used to test out roof forms and facade ideas that matched the sustainable goals of the original building. Marco quickly generated ten variations, refined the best ones, and iterated again, all before committing to any modeling. This helped him land on a translucent facade design that was structurally efficient and visually aligned with the original home.
That’s why Veras is ideal at the start: it lets you move fast, stay open, and avoid bottlenecks in the concept phase.
Modern two-story house created with Enscape and Veras with large glass windows, wood paneling, and a spacious rooftop terrace surrounded by greenery.
Marco Iannelli
2. Switch to Enscape to design in real-time
Once your concept takes shape, Enscape lets you refine and test it in context—all without leaving your modeling software.
Use Enscape to:
  • Visualize geometry, materials, and lighting in real time;
  • Make design decisions directly inside your BIM or CAD tool;
  • Adjust layout, form, or sequencing on the spot;
  • Use immersive walkthroughs or VR to evaluate experience and spatial flow.
In the Mönchengladbach Medical Centre project by Sonnentag Architektur, Enscape’s Site Context tool helped the team address difficult topography from day one. They used real-time rendering to study the approach sequence, refine the entrance, and adjust the façade, all while modeling. This saved time and allowed for creative moves like the sculptural entrance stair, which might not have emerged in 2D.
Enscape is your testing ground: it makes sure your concept works in space and not just on screen.
sonnentag architektur hospital
3. Use AI Enhancer to polish final renders
When your design is ready to present, AI Enhancer helps create professional-grade images with minimal effort.
AI Enhance will help you to:
  • Refine people and vegetation with a single click;
  • Add polish and clarity without opening another rendering app;
  • Produce client-ready visuals with minimal post-production effort.
In the examples mentioned above, Marco used AI Enhancer to finish his penthouse renderings, helping non-technical co-owners understand and approve the design. The images were clear and compelling enough that he didn’t even need to show floorplans.
Similarly, for the medical center, the Sonnentag team used AI Enhancer to elevate their final visuals in time for a fast-moving client presentation. Even a more ambitious design option was approved, thanks in part to the clarity and realism of the renderings.
AI Enhancer helps your ideas land, turning iterative design into presentation-ready visuals in a quick and clean manner.
Enscape AI Enhanced render example outdoor scene copy
AI Enhancer, available in Enscape and other Chaos tools
As you can see, tools like Veras, Enscape, and AI Enhancer aren’t here to replace architects. Rather, this specific AI-powered combination helps you move through the most time-consuming parts of early design faster: Veras generates visual ideas from rough prompts or early models, Enscape lets you test and refine those ideas in real time, and AI Enhancer adds clarity and polish. All without requiring hours of manual post-processing.
There are many benefits to working this way, such as exploring more design options in less time and producing client-ready visuals early in the process. More importantly, it lets you spend less time grinding through model updates or tweaking render settings and more time thinking critically about space, user needs, and how your design actually works.
The best way to try Veras, Enscape, and AI Enhancer together is on a small concept project. Use a simple massing model or sketch and focus on testing ideas, not perfecting them.
Quick tips before you dive in:
  • Check your hardware: A strong GPU will improve performance, especially when using Enscape or Veras;
  • Start with what you have: You don’t need detailed models. Even rough sketches or early geometry are enough to generate ideas;
  • Keep your software up to date: Make sure your BIM or CAD tools support the latest plugin versions for a smooth experience.
Helpful resources:
Integrating these tools early in your workflow helps you ideate faster, explore more variations, and spend less time on manual rendering so you can focus on the bigger design decisions that matter.
FAQs
Do I need all three tools, or can I use just one or two?
You can use Veras and Enscape separately, but they work best as a trio. Veras speeds up ideation, Enscape brings real-time feedback, and AI Enhancer polishes the final visuals. Using all three creates a streamlined workflow from concept to client-ready.
What software do these tools work with?
  • Veras: Works within Enscape and as a separate web app;
  • Enscape: Compatible with Revit, SketchUp, Rhino, Archicad, and Vectorworks on Windows and Mac;
  • AI Enhancer: Built into Enscape, so it works wherever Enscape does.
Can I use this workflow for interior design?
Yes. Many architects and designers use this setup for interior projects to test lighting, layouts, finishes, and style variations with speed and clarity.
Is this suitable for small firms or solo architects?
Definitely. These tools save time and reduce manual work, which is especially valuable when resources are limited.
Will this replace my rendering pipeline?
Not entirely, but it can simplify it. Enscape plus AI Enhancer delivers high-quality visuals fast, which may reduce or even eliminate the need for separate post-production tools in many cases.
chaos logo
Report: How AI is reshaping design & visualization in 2026
How AI is reshaping architectural design and visualization in 2026 new report from Chaos and Architizer
Share
Kalina Prelikj
Kalina Prelikj
A jack of all trades and a Master of Architecture, Kalina enjoys embracing her creative side and has dabbled in everything from marketing to design to communications. Now, as an Editorial Assistant at Architizer, she channels her passion for architecture, helping celebrate the world's best designs and the people behind them.
Credit: Dan Stine
Veras
Enscape for Rhino
Veras
Marco Iannelli
