Intelligent City Enscape-rendered building image
Dinnie Muslihat
Dinnie Muslihat
Last updated: December 19, 2025  •  3 min read
Building a Different Kind of Urban Living with Real-Time Visualization
Summary:
  • Intelligent City, a Vancouver-based technology-enabled company, designs mixed-use urban housing projects near public infrastructure to foster vibrant communities.
  • The company has developed a process called Platforms for Life, which accelerates the delivery of urban housing while maintaining high-quality design and sustainability.
  • Intelligent City uses Enscape’s real-time rendering capabilities to create immersive, realistic visualizations, boosting client confidence in their designs.
  • By integrating Enscape into their workflow, the firm streamlines communication, improves project efficiency and gives clients a connection to the design process.
Intelligent City is a technology-enabled housing company based in Vancouver, Canada. They combine architecture, design, engineering, building systems, and manufacturing into a platform-and-product-based approach. They call this highly automated and product-oriented end-to-end approach “Platforms for Life.”
Chief Technology Officer Oliver David (OD) Krieg and Computational Design Architect Timo Tsui share how they incorporate Enscape to create mixed-use urban housing solutions with Platforms for Life.
Creating communities with mixed-use buildings
In North America, many cities are very dense in the center and have a huge sprawl outside of it. Because of this, you have what is called a ‘missing middle,’ where you find duplex-like residential buildings an hour away from the city center.
OD explains that Intelligent City's objective is to fill that missing middle by creating vibrant communities with the buildings it designs.
“We think having mixed-use buildings between six to 12 stories high can produce enough density to generate a lively city with close public infrastructure. You can walk, cycle, use public transport, and are less reliant on cars. Because of the commercial spaces on the ground floor of the buildings, whatever you need to do, you can do it within a travel distance of 15 minutes. This creates communities and provides better urban living than created by the typical high-rise concrete towers.”
IntelligentCity_Rendering_01
Embracing a parametric design approach
Platforms for Life is the fast and cost-efficient process Intelligent City developed to design and deliver urban housing projects. It embraces a parametric design approach where components are automated and customizable.
“The underlying logic of how a building comes together is parameterized. Every building we design and build can be repeated and easily adapted because everything that goes into it is pre-engineered and pre-developed. So, whenever you adjust a building to a certain size or shape and add apartments to it, all the geometry adapts to it. You pretty much create a digital twin instantly,” says OD.
He adds how the use of mass timber makes the approach a sustainable one. “Mass timber is an excellent material to work with for six, 12, or 18-story high buildings. It's also easy to prefabricate and process in a factory environment.”
IntelligentCity_ICP_manufacturer
Connecting clients to designs with real-time visualization
Intelligent City is a company filled with architects, engineers, and builders, so showing their clients a connection to the designs is a crucial part of their workflow.
“The premise of our process is knowing how to design a good building. We understand the materials, the engineering, and the manufacturing that goes into it. When we talk to clients, it’s imperative to visualize the building in high quality. It can’t take too long, and it can’t be too complicated. It has to be quick, and it has to look good because that’s how we get our vision across,” explains OD.
Last year, the team started to experiment with Enscape when Timo introduced it.
“We were looking for a way to visualize the buildings quickly. If we couldn’t keep up with the iterations of the generated designs, then we wouldn’t be able to visualize them properly for our clients. So, we needed something fast, and Enscape met our requirements,” explains Timo.
IntelligentCity_back
Developing a trouble-free project experience
OD and Timo share how Enscape helps them deliver a more efficient project experience.
“Our clients want a trouble-free process, but traditional construction is never trouble-free. That’s why they talk to us. We can show them the entire building virtually before any construction happens, and this gives them more confidence about the process,” says Timo.
Because the underlying logic of Intelligent City’s design process is systemized, they can automate the export and then use Enscape to add a level of realism and detail to showcase it.
“My favorite thing about Enscape is it removes the work that would otherwise be needed to produce a realistic texture or a 3D asset. I think it has changed the rendering world because now we have libraries at our fingertips. We can easily change the lighting, fill the scenes, and quickly find the right angle of a building,” says OD.
Ready to try Chaos products?
Start your free trial today and explore all features.
Share
Dinnie Muslihat
Dinnie Muslihat
Dinnie manages the Chaos blog, where she publishes practical guides, industry insights, and inspiring projects for architects, artists, and designers. Have an idea for an article? Get in touch at blog-editor@chaos.com.
