Rendering plugins do not update in lockstep with SketchUp, Revit, or Rhino. This guide explains why compatibility issues can appear after a host update, how to check supported versions, and how to build a version management plan that keeps your rendering workflow stable through every release cycle.
Key takeaways:
- Rendering plugins can be affected by host updates because they rely on the host application's API and need to support changes introduced in new versions.
- Compatibility information defines which host versions have been tested and are officially supported, so check it before every major update.
- Some post-update failures are caused by settings resets or disabled extensions, so reinstall or re-enable the plugin before assuming a version conflict.
- Multi-step workflows can involve several compatibility requirements at once, and each part needs to remain supported.
- Manage compatibility as a workflow decision: document your known-good stack, test updates before broader rollout, and avoid unnecessary changes to project-critical environments.
When a host update affects your rendering plugin
After updating SketchUp, Revit, Rhino, or another host application, you may find that a rendering plugin no longer loads, its toolbar has disappeared, or some functionality is no longer working as expected.
This does not necessarily mean the plugin is poorly built. Host applications and rendering plugins have independent release cycles, and changes to a host application can require corresponding updates to the plugin.
Understanding this relationship makes compatibility easier to plan for before introducing a new host version into an active workflow.
Why rendering plugins can be affected by host application updates
Rendering plugins rely on APIs and other integration points provided by applications such as SketchUp, Revit, or Rhino. These are the interfaces the plugin uses to communicate with the host application.
When the host ships a major update, parts of those interfaces can change. Depending on the changes introduced, the plugin may need an updated build before the new host version can be officially supported.
Not every update carries the same risk. Major host releases, such as Revit moving to a new year version or a new SketchUp release, are more likely to require an updated plugin build. Minor patches may or may not affect compatibility.
Closely integrated tools such as Enscape can also depend on a wide range of information from the host application, including geometry, materials, cameras, and model changes. Changes to those integration points can therefore affect how the plugin works with a new host version.
Rhino and Enscape
What compatibility information actually tells you
Compatibility information shows which host application versions a plugin has been tested with and officially supports.
The version numbers refer to the host application release, not the plugin release. Find the compatibility information for your specific tool and host combination, then check whether your host version is included.
For Chaos products, this information is published under System Requirements in the product documentation.
V-Ray has separate System Requirements for each host platform, including V-Ray for SketchUp, V-Ray for 3ds Max, V-Ray for Rhino, V-Ray for Revit, and others.
Enscape publishes its supported host versions on its Enscape System Requirements page.
If a newly released host version is not yet listed, it has not yet been added to the officially supported configuration.
Support for older host versions is also discontinued over time as new versions are introduced. Checking the current System Requirements before updating the host helps ensure that your software combination remains supported.
Host update behavior that is not a compatibility problem
Not every issue after a host application update is caused by a version conflict. An update may reset the toolbar layout, disable an extension, or affect how the plugin is loaded, even when the plugin still supports that host version.
Before assuming a version conflict, run a quick check:
- Confirm that your host version is included in the plugin's supported range.
- If it is, check whether the plugin is enabled, reinstall it if necessary, and restart the host application.
- If the issue continues, check the product documentation and release notes or contact support.
In some cases, re-enabling or reinstalling the plugin is enough to resolve the issue without requiring a new compatibility release.
The coordination problem in multi-step workflows
The situation becomes more complex when a workflow involves several applications or plugins. Each part of the workflow can have its own compatibility requirements.
For example, a team may bring a Revit model into SketchUp using the Revit Importer and then continue the visualization workflow there. The Revit file version, the importer, the SketchUp version, and the rendering plugin can all have their own supported-version requirements.
A change to one part of the workflow can therefore affect another part further along the process.
The Revit Importer for SketchUp shows this clearly. It supports .rvt files from versions 2015 to 2026 and is compatible with SketchUp for Desktop versions 2023 and above. A Revit license or installation is not required.
That means compatibility needs to be considered across the complete workflow rather than for one product in isolation.
The goal is to understand where the dependencies are so that you can check them before making an update, rather than discovering a compatibility issue during an active project.
How to build a version management plan for your rendering workflow
Compatibility is a workflow management consideration, not only a troubleshooting task. Treating software updates as planned changes makes it easier to maintain a stable project environment.
Here is the framework, in the order the steps matter:
- Start by documenting your current known-good stack. Write down the host version, the plugin version, and the GPU driver if your renderer depends on one. This is your baseline. If something changes, you know which configuration was working before the update.
- Next, check the vendor's compatibility information before any major host update, not after. If the new host version is not listed as supported yet, you know before introducing it into your workflow.
- Then test the new host version against your rendering plugin on a sandbox project or a secondary machine. For project-critical workflows, testing the new combination before broader rollout can help identify issues without affecting active work.
- Finally, consider the timing of software changes during active projects. If the current environment is stable and a project is approaching delivery, evaluate whether introducing a new host or plugin version is necessary at that point.
Step |
What to check |
Where to find it |
Document baseline |
Host version, plugin version, GPU driver |
Your own machine, recorded per project |
Before updating |
Is the new host version supported? |
Vendor compatibility information / System Requirements |
Before rollout |
Does the pipeline run clean? |
Sandbox project or test machine |
Mid-project |
Are versions stable until delivery? |
Your project schedule |
Some teams choose to remain on a previously validated host version until the plugins their workflow depends on support the newer release. This can be a practical way to balance access to new host features with the stability requirements of active projects.
One more thing on subscriptions: all V-Ray and Enscape subscription licenses include compatibility updates at no additional cost.
Access is not the same as automatic, though. The host application and rendering plugin are updated separately, so you still need to install the relevant V-Ray or Enscape update when it becomes available.
Get the compatible V-Ray version on the download page.
What to do when the plugin breaks anyway
If a host update has already been installed and the rendering plugin is no longer working as expected, work through these steps in order.
- First, check the vendor's System Requirements or release notes to see whether the host version is currently supported.
- Second, if a compatible plugin build exists, download and install it.
- Third, if the host version is supported but the plugin is not loading correctly, try re-enabling or reinstalling it.
- If no compatible build exists yet and a previously validated host version is still available in your environment, returning temporarily to that configuration may be an option.
- If the issue continues, contact the plugin vendor's support channel. Provide the exact host version and plugin version numbers to help with troubleshooting.
What to look for in a rendering plugin's compatibility track record
If you are evaluating tools, compatibility and maintenance are worth considering alongside rendering quality.
Look for publicly available, current compatibility information. Check whether the vendor actively adds support for new host versions and maintains release notes that document version-specific support and fixes.
Chaos aims to add support for new host application versions as soon as possible, typically within a few weeks of a major release. The exact timing can vary depending on the changes introduced by the host application and the development and testing required.
For V-Ray and Enscape, current compatibility information is available in the Chaos documentation under System Requirements. V-Ray provides separate System Requirements for each supported host platform, while Enscape lists its supported CAD and BIM applications on its Enscape System Requirements page.
Before committing to a rendering plugin, it can also be useful to test it against the applications and workflow your team currently uses.
Conclusion
Host applications and rendering plugins follow separate release cycles, so a new host version may require an additional plugin update before the combination is officially supported.
Checking the current System Requirements, documenting your working software versions, and testing important workflow changes before broader rollout can help reduce compatibility issues during active projects.
If you are ready to test a rendering plugin within your current SketchUp, Revit, Rhino, or other supported host environment, both V-Ray and Enscape offer free trials. Compatibility updates are also included with all V-Ray and Enscape subscription licenses at no additional cost.
FAQs
Why did my rendering plugin stop working after a software update?
A host update may have introduced changes that require an updated version of the rendering plugin. In some cases, though, the plugin is still compatible and the update has simply reset the toolbar, disabled the extension, or affected how the plugin is loaded. First, confirm that your host version is officially supported. If it is, try re-enabling or reinstalling the plugin before assuming a version conflict.
How long does it take for V-Ray to support a new version of SketchUp or Revit?
Chaos aims to add support for new host application versions as soon as possible, typically within a few weeks. The exact timing can vary depending on the changes introduced by the host application and the development and testing required. Check the relevant V-Ray System Requirements and release notes for the current supported host versions.
Does Enscape automatically update when Revit updates?
No. When a CAD or BIM application releases a new version, Enscape adds support for it in an upcoming release, and the oldest supported version moves out of official support. Versions out of official support no longer receive bug fixes, testing, or compatibility guarantees, but they stay available in the installer for a soft-support period before full removal. Check the Enscape System Requirements for currently supported host versions.
What should I check before updating SketchUp or Revit?
Before updating, check whether the new host version is officially supported by the rendering plugins and other integrations your workflow depends on. For project-critical workflows, you can also test the new software combination before introducing it more broadly. This lets you evaluate the update based on both its benefits and its compatibility with the rest of your workflow.
What is a plugin compatibility matrix and how do I use it?
Compatibility information shows which host versions a plugin has been tested with and officially supports. For V-Ray and Enscape, this information is published under System Requirements in the Chaos documentation. Find the information for your product and host application, then confirm that your host version is included before making a major update.
Do rendering plugin subscriptions include updates for new host application versions?
Yes. All V-Ray and Enscape subscription licenses include compatibility updates at no additional cost. The host application and rendering plugin are updated separately, however, so you still need to install the relevant V-Ray or Enscape update when support for the new host version becomes available.
