Split-view image showing a living room and kitchen evolving from sketch to realistic render, illustrating Veras 3.0’s AI-powered design transformation
Daniel Brown
Daniel Brown
Last updated: November 18, 2025  •  5 min read
7 SketchUp pitfalls to avoid for smoother, better Enscape results
A frustrating rendering experience in Enscape is rarely about the renderer itself. More often than not, the visual glitches, slow performance, and strange artifacts that disrupt your workflow can be traced back to a handful of common habits within SketchUp. By addressing these core modeling issues, you can ensure a smooth, predictable, and high-quality result every time you render.
What you'll learn:
Even after carefully refining a SketchUp model, launching Enscape can sometimes lead to visual inconsistencies like flickering surfaces, unexpected light leaks, or reduced performance.
These issues often aren't Enscape's fault. They're symptoms of a few common, easily avoided bad habits in SketchUp—what I call the seven sins of modeling for real-time rendering. Avoiding these pitfalls is the key to a smooth, predictable, and professional workflow.
Sin #1: Ignoring the basics - reversed faces
This is the cardinal rule. In the pride of moving quickly, it's easy to forget that every face in SketchUp has a front (white) and a back (blue-grey).
How to check for reversed faces in SketchUp and Enscape
  • The problem: Enscape's lighting engine is designed to render front faces. It treats back faces as incorrect, leading to a host of visual bugs: surfaces that look transparent, objects that are mysteriously dark, or splotchy light artifacts.
  • The fix: Periodically check your work. Go to View > Face Style > Monochrome. Your model should be uniformly white. If you see any blue-grey, right-click the face and select "Reverse Faces". For a whole object, use "Orient Faces". If you applied a texture to the face already, be sure to transfer it to the front as well.
Sin #2: Forgetting to group your geometry
This sin is born from a desire to model quickly without organization. Loose geometry—lines and faces not contained within a Group or Component—is a recipe for trouble.
Grouping your geometry in SketchUp and Enscape
  • The problem: All loose geometry is "sticky." If a chair touches a wall, they become a single, tangled object. This makes editing, hiding objects, and especially applying materials an impossible task.
  • The fix: Be disciplined. The moment you create a distinct object—a window, a wall, a piece of furniture—triple-click to select it all, right-click, and "Make Group" or “Make Component”. This one habit will save you more time than any other.
Sin #3: Modeling with paper-thin surfaces
In a rush to create form, you draw a single plane for a ceiling or a floor, with no real-world thickness.
Use the push pull tool to give every wall floor and ceiling a realistic thickness
  • The problem: Real-time renderers calculate light bounces. A surface with no substance can't properly block light, allowing it to "leak" through corners and edges. This is a primary cause of unrealistic brightness and strange shadows in interior scenes.
  • The fix: Give your geometry substance. Use the Push/Pull tool to give every wall, floor, and ceiling a realistic thickness. It’s a small step that makes a huge difference in lighting accuracy.
Sin #4: Painting groups instead of faces
You see a finished object and, in your rush to get it textured quickly, you apply a material to the outside of the Group/Component container instead of the faces inside.
How to open a group and apply your textures directly to the faces inside of SketchUp and Enscape
  • The problem: This creates a "shrink-wrap" effect. SketchUp projects the texture onto the object, often causing warped, stretched, and unpredictable mapping, especially on anything more complex than a simple box.
  • The fix: Follow the golden rule: Groups contain, Faces wear the materials. Double-click to open a group and apply your textures directly to the faces inside.
Sin #5: Letting faces fight for dominance: Z-fighting
This sin manifests as a distracting, maddening flicker. It happens when two faces are modeled in the exact same location, fighting for rendering priority.
How to ensure there are no unintentional overlaps between your objects in SketchUp and Enscape
  • The problem: SketchUp and Enscape don’t know which face to show, so they rapidly alternate between them, creating a visual artifact that ruins screenshots and makes videos unwatchable.
  • The fix: Model cleanly. Ensure there are no unintentional overlaps between your objects. A floor should sit cleanly beneath a rug and not occupy the same space. Nudge the object up or give it a bit of depth so it is not on the same plane as the floor.
Sin #6: Bloating your model with heavy assets
This is the sin of wanting it all—the most detailed plants, the highest-resolution cars, and the most complex furniture—without considering the performance cost.
Showing heavy high polygon models with oversized textures in SketchUp and Enscape
Screenshot of Cosmos asset library inside of Enscape
  • The problem: High-polygon models and oversized textures (anything over 2K for most uses) are VRAM hogs. They consume your graphics card's memory, leading to slow navigation, blurry textures, and frequent crashes.
  • The fix: Be a curator, not a collector. Use optimized libraries like Chaos Cosmos whenever possible. Vet every 3D Warehouse download for its polygon count and file size, and resize your textures before importing them. If you need to use a heavy model, consider converting it into a proxy.
Sin #7: Chasing the 'one perfect view' instead of using scenes
You find a perfect camera angle and spend your time manually orbiting back to it again and again, lusting after that one shot instead of building a proper workflow.
How to use SketchUp Scenes or Enscape View Management mode to save scenes
  • The problem: This is pure inefficiency. Without saved scenes, you can't create repeatable renders for comparison, use Enscape's powerful Batch Rendering feature, or create professional video animations.
  • The fix: Think like a photographer. Once you frame a great shot, save it. Use SketchUp Scenes or within Enscape’s View Management. This is the foundation of an organized, professional presentation workflow.
Conclusion: A foundation of good habits
It’s a simple truth: a clean SketchUp model is the foundation of every great Enscape render. These "sins" are just bad habits, and replacing them with a disciplined, professional workflow is the fastest way to get predictable, high-quality results from your renders.
At SketchUpTrainer.com, our courses are built around these core principles of clean, organized modeling. We teach you not just how to use the tools, but how to develop a workflow that saves you time and produces stunning results every single time.
Rendering course by SketchUp Trainer
Ready to try Chaos products?
Start your free trial today and explore all features.
Share
Daniel Brown
Daniel Brown
Dan is a seasoned SketchUp trainer, educator, and 3D visualization expert dedicated to making design accessible and efficient. As the founder of SketchUp Trainer, he empowers architects and designers with hands-on tutorials, practical insights, and innovative workflows. Now a proud partner of Chaos, Dan is excited to bring his expertise to the Enscape community and help you elevate your creative projects.
