Realistic render of man with white t-shirt, brown hair, realistic skin and soft lighting
Lynette Clee
Lynette Clee
Last updated: December 19, 2025  •  11 min read
The secrets of Ian Spriggs’ 3D portraits
Summary:
  • Ian Spriggs creates highly realistic 3D character portraits using simple settings and strong foundational sculpting, primarily relying on V-Ray Next's default settings for efficiency and ease of adjustments.
  • His latest works, "Portrait of Erica" and "Portrait of Scott Eaton," showcase his ability to incorporate meaningful details and symbolism, such as using a werewolf model for a dog and embedding symbolic elements like elongated skulls.
  • Spriggs emphasizes the importance of hands in portraits, equating their expressiveness to that of faces, and uses them to convey deeper narratives about the subject's life and career.
  • Utilizing V-Ray Next GPU rendering, Ian achieves rapid iterations, allowing for hundreds of adjustments in a day, significantly enhancing his workflow efficiency.
  • Ian Spriggs balances a full-time role and personal projects, demonstrating dedication to his craft, and continues to explore new techniques in character modeling and rendering.
Ian Spriggs takes attention to detail to the Next level. Go behind the scenes of his recent works to see how a master tells story through composition and detail.
Ian Spriggs’ 3D character portraits don’t just cross the uncanny valley, they boldly leap over and rejoice on the other side. It’s easy to assume that the gobsmacking detail and realism in Ian’s work is the result of complicated processes and settings. But this couldn’t be further from the truth.
It’s actually quite simple. And when it comes to materials and rendering, the simpler the better. “For the longest time, I was using V-Ray Fast SSS, but I’ve graduated to the alSurface shader [for the skin],” Ian discloses. “It's pretty simple: I just use Diffuse, Specular, Bump, and a little bit of Glossiness — and that's basically it. I just have those four maps that plug into it and I usually keep all the default settings.”
Portrait of Scott Eaton is a brand-new 3D illustration revealed today by Ian Spriggs. Rendered in V-Ray Next for Maya.Portrait of Scott Eaton is a brand-new 3D illustration revealed today by Ian Spriggs. Rendered in V-Ray Next for Maya.
You see, Ian actually relies on V-Ray Next’s defaults a lot. He explains: “V-Ray has been awesome for the out-of-the-package default stuff; if you just leave it how it is, it usually works phenomenally. I add as little into that as possible.” Because the more layers and variables you have, the harder it can be to pinpoint errors and make revisions. Ian adds: “If I look back at the portrait, I’m like, ‘Okay, well, the red part of the cheek doesn't look good; well, I know that's the diffuse map,’ so I can just go and paint the diffuse map.”
So, just how do Ian’s portraits look so unbelievably realistic with these simple settings?
Underlying sculpting is important for natural looking materials and texturesIf your foundations are strong, your materials and textures will behave naturally. You can see just how much of the quality comes from Ian's underlying sculpt.
Well, laying a solid foundation helps. Ian’s meticulously sculpted models are a masterpiece in and of themselves. In fact, most of the quality comes from Ian’s sculpting handiwork, which allows the textures and shaders to just act, well, very naturally. What’s more, Ian doesn’t go crazy with his lighting setups either; just like his shaders, he uses out-of-the-box lighting for both speed and efficiency. And the results are stunning. By doing this — and keeping things simple — the variables are massively reduced and the adjustments to perfection are relatively pain-free.
We know what you’re thinking: How do we reach Ian’s level of sculpting genius? Well, being self-critical is a good start. “For me, if it looks weird, it's not final,” Ian clarifies. “There's no way to know how many revisions or how many iterations you're going to need; I just keep on working on it non-stop, and if I see a problem, I'll fix that problem. Every time I see a problem I try and fix it until there are no more problems that I can see.” Like every artist, Ian looks back on past portraits after they’ve been finalized and sees things he can improve, but the key is just knowing you’ve achieved the highest level possible at the time.
sculpting work in MudboxIan takes care of the sculpting work in Mudbox; here you can see some screenshots of the sculpt in the Mudbox interface.
So there it is. You don’t need to be a master of advanced settings to render a masterpiece. And now that we’ve burst that bubble, let’s enjoy a few behind-the-scenes secrets of Ian’s two latest creations — both rendered in V-Ray Next for Maya.
Portrait #1: Erica
Digital portrait of a woman with long dark hair, wearing a floral jacket and ripped jeans, sitting in front of a green patterned curtain with a small dog resting on her lap.
Portrait of Erica is a 3D illustration of Ian’s girlfriend, featuring her one true love, Carmine the dog. This 3D portrait was modeled and textured in Maya, Mudbox and Photoshop, with hair created using XGen. The skin details included some XYZ textures, and the work was rendered with V-Ray Next for Maya on a Lenovo workstation with NVIDIA Quadro P6000 graphics cards. This setup allowed him to make use of V-Ray Next’s GPU rendering to dramatically speed up the time it took to make iterations and adjustments. Final touch-ups were taken care of in Photoshop.
A wolf in puppy’s clothing
Portrait of Erica — a beautiful illustration that includes Erica’s four-legged friend — presented a challenge that Ian had never faced before: how to model and groom a dog. “Even aesthetically, just trying to make a dog look like a dog was a challenge,” Ian reveals. “Learning dog anatomy and then doing the fur, and then understanding the shininess of the fur; it’s just so completely different to a human.”
So just how did he tackle his first dog portrait? Well, it started with a wolf. Ian describes: “It was a werewolf model that I’d used once for a freelance project, and I just like scaled it down, changed proportions — and then it looked nothing like a werewolf.”
Close-up of a sleeping dog resting on a person’s lap, with the person wearing ripped jeans, a floral jacket, and red nail polish.Do all dogs come from wolves? Carmine sure does. She was modeled from a werewolf right down to her true pint-size. (And she's perfect.)
The secret to eternal life? Render buckets.
Our modern-day master is inspired by some of the greatest paintings in history. In fact, Portrait of Erica was inspired by Hans Holbein’s The Ambassadors. “It shows two people and it’s not about their faces; it’s about their clothing and belongings,” Ian explains. “It’s showcasing how wealthy they are; their job descriptions. Working with a similar theme, Ian approached Erica’s portrait and incorporated Carmine, her dog, as her prize possession. “Carmine is the thing she loves the most, so obviously I had to put her dog in there,” Ian adds.
In Hans Holbein’s The Ambassadors, there’s an intriguing elongated skull stretched in the foreground of the painting. “I think it’s basically saying that, no matter how rich or wealthy you are, death is at the end of everything,” Ian suggests. And here’s where Ian’s love of details gets exciting: look closely at Erica’s earring and you’ll see an elongated skull. “It’s also like Johannes Vermeer's painting The Pearl Earring, where the earring is the center point of the piece. I’ve always thought that was interesting,” Ian adds.
Collage of images showing skull motifs, including a distorted skull painting detail, a realistic skull drawing, and gold skull-shaped earrings worn by a woman.
The girl with the elongated skull earring. Every little detail in Ian's 3D portraits carries a meaning.
But that’s not all. Let’s keep looking at the details.
Notice the render buckets in the top-left? (Clue: Yes, he did finish rendering.) Ian spells out his artistic decision here: “In the corner of Hans Holbein's painting, behind the curtain, there's a cross with Jesus on it. I don't think he really believes that death is the end. So in Erica's portrait, I put the render buckets in the top corner, because I think we’ll live forever through technology. And it’s also the idea that work is never finished; it’s always a render in progress.”
Side-by-side comparison of green patterned curtains, showing fabric texture and ornate floral-like designs in close detail.It may look like Ian's render didn't quite finish, but it's all symbolic. These details are as important as the portraits themselves.
Portrait #2: Scott Eaton
Digital portrait of a man in a white t-shirt holding a human skull, seated against a dark background with dramatic lighting.
Once upon a time, back when Ian was learning character modeling, he took some of Scott Eaton’s anatomy classes. He watched the videos and kept repeating them until he had learned as much as he could. Fast-forward to 2017 and Scott and Ian were both speakers at the Trojan Horse was a Unicorn festival in Portugal, where Ian was once again blown away by Scott’s knowledge of anatomy. A huge influence on Ian’s career, this portrait came to Ian as a way he could thank Scott for helping him to become a better character artist. Scott’s portrait was rendered using V-Ray Next for Maya on a Lenovo workstation with NVIDIA Quadro P6000 graphics cards (Ian has four P6000s, to be precise).
Hands will speak
It’s easy to assume that portraits are primarily about faces. But hands are also equally as expressive. Ian states: “There's so much expression from a face, but hands are equal to a face, I would say. If you put your hand on your cheek, that means something. So, hands are like faces; they cannot lie. You can fake an expression while thinking about something else, but hands can sometimes tell even more of a story than the face.” In art history, it interestingly cost more money to have a portrait with hands. “If you have two hands in a painting, it means that you can afford two hands,” Ian points out. “If you only have one hand, you're probably fairly wealthy compared to someone with a portrait without any hands; it's another show of status and wealth.”
In Portrait of Scott Eaton, Ian wanted Scott’s hands to not necessarily describe wealth, but instead to represent his career. “I wanted to show the intimacy between Scott and his career,” Ian answers. “He chooses his path in life; he wants to do anatomy; he wants to give back as an artist. The solid grip of the skull also indicates that he's like taking control over what he loves doing.”
And the details don’t stop there. Take note that the skull is a reverse-forensics of Scott’s own head, meaning he is essentially holding his own skull in his hands. Every detail counts.
Close-up of a person’s hands holding a human skull, focusing on the teeth, bone texture, and the detailed grip of the hands.
Getting the hands right in a portrait is as important as perfecting the face. In Scott's portrait, he's holding this skull as a representation of his exceptional career mastering anatomy. (And in real life, he often carries a skull, too!)
Rendered facial reconstruction chart showing a human skull with soft tissue depth markers at various anatomical points, displayed from side and front views with measurement tables.
Scott is literally holding his own skull in his hands. Ian dabbled in a little backward-forensics, as shown here.
It’s all in the cards
As well as using his 3D portraits to tackle new challenges, they’re also an opportunity for Ian to explore new compositions. “I've always wanted to create a skull,” Ian says. “I'm fascinated by skulls for many reasons, and in Scott's portrait, it’s compositionally a playing card. It’s like a traditional King playing card with two heads; Scott’s head and his skull tell the story of life and death.”
Composition of a human portraitScott is the king of the composition in Ian's playing-card-inspired portrait.
Good grooming is essential
For Ian’s last three portraits, he’s used XGen hair. “XGen's pretty cool,” Ian comments. “It's a little more randomized than nHair, but XGen's been pretty good so far. You get faster results, and even when still creating each hair — each guide, one by one — you still have complete control. Honestly, I don’t think there's an easy way to do hair. It just takes time.”
The facial hair was a challenge, too. Adding a few grey hairs to the beard and fading those out where Scott doesn’t have any at all meant Ian had to do a few different levels of hair grooming. This detail is very subtle but extremely important to get right. “When you look at a portrait, you won’t even notice a few grey hairs here and there, or realize that there are many different levels with different maps painted for the volume and density,” Ian illustrates. “But if it wasn’t there at all, you’d know something was off right away. It can take a lot of work to get a natural look.”
Side-by-side comparison of a 3D digital model with hair guides highlighted in yellow and a realistic rendered portrait of a man with short dark hair and stubble.Ian used to groom his portraits using nHair but more recently switched to XGen, adding several different levels of hair to achieve the most natural results.
3D digital model of a man with detailed facial features, hair, and clothing, shown holding a human skull in his hands, with close-up views of the head and hands included.These Maya screenshots show the attention to detail that goes into Ian's sculpting and hair-grooming work.
Even the clothing is sculpted
Scott’s white T-shirt may look a simple choice, but it’s anything but. “It's hard to explain,” Ian begins, “but white shirts are complicated because you don't want them to stand out too much; you don’t want the brightest values of the piece to be all on the T-shirt. You need to be careful to avoid them popping too much, meaning you have to set the values back a little and show every wrinkle and detail.”
Because, when it's a white T-shirt, you’ll notice every detail. For this reason, Ian will create a lot of the sculpt maps so he can make things tileable and then go into Mudbox to use as a sculpt pass. “I can actually get some bumps and some extra creases this way,” Ian shares. “There's a lot of layering. Especially on a white T-shirt where there are large folds, and then the secondary creases. And if you scrunch a T-shirt up, you’ll get all those delicate wrinkles. Using Bump maps, you can also detail the natural fibers in the material.”
Side-by-side comparison image showing a 3D digital model of a torso in grayscale on the left and a realistic rendered version of the same figure wearing a white t-shirt on the right.Every tiny wrinkle and crease has been sculpted in Mudbox.
Ian’s secret weapon: V-Ray Next GPU rendering
The biggest change in Ian’s workflow since upgrading to V-Ray Next is the number of iterations he can achieve, and how quickly he can do them. “Before, I would have to wait 10 minutes per render, and then realize that the spec didn’t look right and have to render it again; keep testing it out,” Ian says. “Now it's just absolutely instant. It's like hundreds, even thousands of iterations in just one day — before I would have only been able to manage 50-100 in a day.”
“And you can still zoom in, which is pretty cool with the GPU,” Ian continues. “Even if you're working on the eye and you want to change something like the color of the eyelashes, you can just zoom in and fix it. If you want to change the spec, you can just change it.”
About Ian Spriggs
Ian lives in Vancouver, Canada, where he’s currently working full-time as the Character Modeling Lead at Image Engine. He’s also created characters for the likes of ILM for films including Batman v Superman: Dawn of Justice, Harry Potter and the Deathly Hallows: Part 1, and Warcraft: The Beginning. Ian is also a member of the Digital Human League and Chaos Group Labs’ Wikihuman project.
The artwork featured in this article has impressively all been created in his spare time — which was a lot easier when he was freelancing on his own hours. Now back in a nine-to-six regimen, he still manages to produce these incredible portraits in his free time. (Now that’s dedication!) Be sure to check out his full portfolio at artstation.com/ianspriggs.
chaos logo
AI in architecture: trends, risks, & what comes next
AI in Architecture new White Paper from Chaos
Share
Lynette Clee
Lynette Clee
Lynette has 13 years of experience as a writer and editor, with previous roles including the editor of Chaos, 3dtotal.com, and 3D Artist magazine in the UK, and senior editor and event producer at Gnomon School of Visual Effects in Hollywood, California.
