Abstract background in bright colors as the header image for the Chaos blog post.
Ina Iontcheva
Ina Iontcheva
Last updated: December 19, 2025  •  4 min read
Top 5 nodes Goodbye Kansas uses in Solaris for an efficient workflow
Summary:
  • Nodes enhance workflow efficiency at Goodbye Kansas by using Houdini for scene creation, supported by V-Ray for Houdini.
  • USD (Universal Scene Description) allows Goodbye Kansas to manage complex scenes, improve sequence lighting, and integrate workflows across applications.
  • Solaris in Houdini, with its custom node "The Manager," helps Goodbye Kansas manage layout and lighting, ensuring safe versioning and easy restoration of assets.
  • Key nodes like V-Ray Material Builder, Instance, Explore Variants, Light Mixer, and Husk streamline material management, geometry generation, and lighting adjustments.
  • The Snapshot tool captures both images and node networks, enabling easy reversion to previous states, enhancing workflow flexibility.
It takes a great team to succeed. To support the talented artists at Goodbye Kansas Studios, two creative minds are paving the way for a more efficient and reliable workflow in V-Ray for Houdini.
Chaos was thrilled to have Erik Johannson, head of pipeline development and Dan Englesson, technical director at Goodbye Kansas as guest speakers at 24 Hours of Chaos. In this brief summary, Dan Englesson shares Goodbye Kansas’ Solaris workflow in USD as well as the five most useful nodes they use in Solaris with the V-Ray Hydra delegate for lookdev, lighting and layout.
Benefits of using USD
USD stands for Universal Scene Description. This framework interchanges graphics data, including models and animations, for large-scale projects. It was developed by Pixar and became open source in 2016.
Goodbye Kansas’ main reasons for using USD is to be able to handle complex scenes with ease, enjoy more efficient sequence lighting, and have the ability to extend their workflow into more applications if needed.
Screenshot expalining what is USD with bullet points.
We have a layout layer where we put all our layouts in and then we have a lighting layer where we can put all our lights in and then combining those together into a shot makes up the shot. Being able to describe both the scenes and assets in the same file format makes it a very powerful pipeline tool to use among different DCCs.
Dan Englesson, Technical Director, Goodbye Kansas
Dan explains this as an agnostic process. You can do some modeling in Maya, push that into Houdini for some shading, push that into USD and then take that asset or scene and render it in V-Ray for Blender or Unreal because everything is self-contained within the USD file.
Solaris workflow
Houdini's lookdev, layout, and lighting tool for USD is known as Solaris. Goodbye Kansas has created its own node inside Houdini’s Solaris called “The Manager.” It manages all of its departments including layout and lighting effects and is built around the LOPS context.
Once the node is dropped down into the scene, and the scene is referenced, ftrack pulls in the latest scene version. After that, the team is able to pull in data from the sub context outside of Solaris. To generate terrain, Goodbye Kansas uses Houdini’s Heightfield Scatter, and doesn’t work with live geometry. They publish the shot asset onto ftrack, and then reference that file in “The Manager” node. This process lets them version it and work on it safely, letting previous versions of the asset co-exist with the current version so they can be restored easily.
Slide describing Solaris workflow with LOPs and in-house USD manager for Houdini at Goodbye Kansas.
Top 5 most useful nodes
1. V-Ray Material Builder node Goodbye Kansas uses the V-ray Material Builder node inside Houdini to create and manage several different material types. They copy any material they already have prepared in the scene and paste it into the builder to tweak it further. 2. Instance node
They also make sure to add an Instance node. It is very easy to use and it significantly speeds up geometry generation, for things like tree foliage. When pulling in a tree asset into “The Manager” node, Goodbye Kansas points it to an asset on ftrack and uses the Explore Variants node to expand all of the different modeling variants of trees in their scene.
In their example scene, they have four different palm trees they would like to instance out. To do that, they have to create prototypes to instance the map. 3. Explore Variants node
The Explore Variants node helps them see all the variants that they are working with. After that, they put the variants into a collection and name it accordingly. 4. Light Mixer node
SideFX’s Light Mixer node lets you see all the lights and edit them all in just one node. You can change the exposure or intensity of the light or the color, play around with it and disable the lights and check out how things look. 5. Husk node
The Husk node sends renders to the farm using the V-Ray Hydra delegate. Husk ships with Houdini and it allows you to use any Hydra delegate for final production rendering.
Houdini Solaris Light Mixer interface showing connected node tree and sliders for left and right lights.
Snapshot tool
Sidefx’s Snapshot tool not only takes a snapshot of the image, but a snapshot of the node network as well which makes it very powerful. You can actually tell it to revert the network to a snapshot and go back to that specific state.
Houdini Snapshot tool interface showing V-Ray render of car in grassy palm tree scene with node options.
Explore the M&E Collection
Ready to try Chaos products?
Start your free trial today and explore all features.
Share
Ina Iontcheva
Ina Iontcheva
Ina is a Content Marketing Manager at Chaos with a great passion for writing and the visual arts. She finds inspiration in exploring the way textures and shapes interact with each other in space.
