V-Ray hybrid rendering of seed close up
Christopher Nichols
Christopher Nichols
Last updated: December 19, 2025  •  3 min read
Understanding V-Ray Hybrid rendering
Summary:
  • CUDA Rendering on CPUs: Debugging GPU code can be challenging, but porting CUDA code to the CPU allows for better debugging tools, leading to the development of V-Ray Hybrid rendering, which works on both CPUs and GPUs.
  • V-Ray Hybrid Benchmarks: Adding CPUs to GPU rendering reduced render times by 13% and 25% in benchmark tests, demonstrating the efficiency of utilizing both CPUs and GPUs.
  • Hardware Setup: The tests used 2 Intel Xeon CPUs, 128 GB RAM, and 2 NVIDIA Quadro GPUs, highlighting the potential of combining CPU and GPU resources.
  • Use Cases for V-Ray Hybrid: This technology maximizes computing power, utilizes all render nodes, provides a CPU fallback for memory limits, and supports gradual GPU upgrades.
  • Key Considerations: V-Ray Hybrid is distinct from the V-Ray Production renderer, and real-world benchmarks are necessary to compare CPU and GPU core performance.
GPU code can be difficult to debug. When the code crashes, as it inevitably does, it may only return a kernel dump, with no information about which part of the code actually caused the crash. To uncover the cause, a developer will comment out each section of the code until the culprit is found. This process can be tedious and time-consuming.
To make GPU debugging easier, our lead GPU developer Blago Taskov had the idea to port the CUDA code over to the CPU, where he could use better debugging tools. Once he had it working, Blago could identify exactly which line of code caused the crash. But this also led to a bigger discovery. Now that V-Ray CUDA was rendering on both CPUs and GPUs, and producing the exact same results, V-Ray Hybrid rendering was officially born.
To find out the speed boost we get by adding CPUs to the GPU mix, we benchmarked two V-Ray CUDA scenes from our friends at Dabarti Studio.
For these scenes, the addition of CPUs helped reduce render times by 13% and 25%. It’s a welcome speed boost, rather than leaving these powerful CPUs idle.
Hardware
CPUs: 2 x Intel Xeon CPU E5-2687W v3 3.10 GHz, total of 40 logical CPU cores RAM: 128 GB GPUs: 2 x NVIDIA Quadro GP100 with 16GB each, total of 7,168 GPU cores
Mars rover robot scene
© Dabarti Studio
Mars Rover scene
Engine: V-Ray 3.6 CUDA Resolution: 1920×1080 Noise threshold: 0.01
GPUs + CPUs Time: 4:27 (267s)
GPUs only Time: 5:03 (303s) 13% longer than GPU + CPU
CPUs only Time: 26:25 (1585s) 520% longer than GPUs alone
Salt and Pepper scene
GPUs + CPUs Time: 9:11 (551s)
GPUs only Time: 11:33 (693s) 25% longer than GPU+CPU.
CPUs only Time: 40:52 (2452s) 354% longer than GPU alone.
Let’s consider a few use cases for V-Ray Hybrid
Maximize your computing power
If you have a powerful workstation, say 40 CPU cores and 4 GPUs, you can take advantage of all its computing power. Nothing is left idle.
Use all your render nodes
Many artists and studios have GPU & CPU workstations and CPU render nodes. With V-Ray Hybrid they can render using all the hardware they have.
CPU fallback
In case your scene won’t fit into your GPU RAM limits, you can still render on CPU.
Upgrade to GPUs as you go
As CPU machines are ready to be replaced, V-Ray Hybrid can help ease the transition to more GPU rendering, while continuing to take advantage of existing CPU resources. Additionally, if there is an empty PCIe slot on a workstation or render node, adding a GPU can give it a radical speed boost without replacing the whole machine.
A few things to note
V-Ray Hybrid and V-Ray Production renderer
It’s important to note that the V-Ray Hybrid (GPU–CPU CUDA) renderer is not the same as the V-Ray Production (CPU) renderer, and the two engines will continue to remain separate.
GPU cores vs. CPU cores
While V-Ray Hybrid can render on CPUs and GPUs simultaneously, CPU cores and GPU cores are not the same. For example, a GPU with 2560 cores is not simply 320 times faster than an 8-core CPU. To determine the actual speed difference, real-world benchmark tests are required.
Ready to try Chaos products?
Start your free trial today and explore all features.
Share
Christopher Nichols
Christopher Nichols
Chris is a CG industry veteran and Director of Chaos Labs. He can also be heard regularly as the host of the CG Garage podcast which attracts 20,000 weekly listeners. With a background in both VFX and Design, Chris has worked for Gensler, Digital Domain, Imageworks and Method Studios. His credits include Maleficent, Oblivion and Tron: Legacy.
