Photorealistic mountain landscape at sunset with rugged terrain, misty valleys, and a small cabin in the distance.
Admin
Last updated: August 29, 2025  •  3 min read
V-Ray 6 for 3ds Max, beta launches
Summary:
  • Join the V-Ray 6 for 3ds Max beta program to explore new tools and enhance your design capabilities.
  • Use Chaos Scatter to create detailed environments with minimal memory usage, and start with free presets from Chaos Cosmos.
  • V-Ray Enmesh allows you to create tileable geometric patterns efficiently, ideal for fences and fabrics.
  • Enhance realism with V-Ray Decal by adding displacement to surfaces for detailed textures like cracked walls.
  • Streamline workflows with V-Ray Proxy Object Hierarchy, enabling easy visibility and material management.
  • Collaborate effectively using Chaos Cloud Collaboration for feedback and annotations on your renders.
  • Create custom skies with V-Ray’s procedural clouds and improve HDRI renders with new ground projection features.
  • Experience faster UI draw times and enhanced material accuracy with V-Ray’s updated interface and energy preservation.
  • Render realistic effects like soap bubbles using the new Thin Film layer in V-Ray Material.
We’re getting close to releasing V-Ray 6 for 3ds Max and we’d like to invite V-Ray users to join our beta program, explore all that’s new, and help us make it even better.
Join the beta to test-drive all the new tools, allowing you to build anything imaginable — faster than ever before. Create complex environments, or intricate geometric patterns for your designs quickly and easily.
Shade faster and create even more physically accurate materials.
And, when you’re ready, fast-forward your collaboration, reviews and approvals in Chaos Cloud.
Plus much more.
Join now
Want to know what to expect from your beta experience?
Check out the V-Ray 6 for 3ds Max beta features:
  • Chaos Scatter
Create forests, fields, crowds, and more using our new scatter tool. It's fast, easy, and it lets you add lots of detail to your scene without using lots of memory. Download one of our free scatter presets from Chaos Cosmos to get started.
  • V-Ray Enmesh
With Enmesh, you can think of geometry like a texture — but rather than repeating an image over a surface, it uses tileable geometry. Enmesh is ideal for creating patterns such as fences and fabrics, and it uses much less memory than displacement or copying by hand.
  • V-Ray Decal with Displacement
You can now use V-Ray Decal to add displacement to any surface for even more realistic cracked walls, rocks, embossed lettering, and more.
  • V-Ray Proxy Object Hierarchy
Easily turn on or off an individual object’s visibility or material override with the new V-Ray Proxy hierarchical view. Set custom order by name, and streamline your geometry exchange and custom library workflows.
  • Chaos Cloud Collaboration
Get rapid, consolidated feedback on your work’s progress. Upload your renders to Chaos Cloud Collaboration right from V-Ray’s Frame Buffer, and share your work with colleagues and clients to add comments and annotations.
  • Procedural clouds
Craft just the right cloudy sky for your environment in just a few clicks with V-Ray’s new procedural clouds system.
  • New ground projection
Elevate your HDRI environment renders with the new, more flexible ground projection capabilities of the V-Ray Dome Light.
  • Faster UI draw times
Get a smoother experience when working with shading networks. V-Ray’s materials and textures interface now comes with much faster load times.
  • Enhanced V-Ray Material energy preservation
Render even more physically accurate rough metals and other reflective surfaces with enhanced V-Ray Material energy preservation.
  • Thin Film layer
Create realistic soap bubbles, oil spills, and more with the new Thin Film option in the V-Ray Material.
  • V-Ray Material Faster SSS
Render translucent materials even faster with a brand-new V-Ray Material SSS mode.
And more.
cg-connect-logo-white-rgb
Introducing a new design & visualization community
CGconnect the new design and visualization community
Share
