The new, unified Chaos Forum is now live.
Join the conversation!
Street with shops and apartments, trees with autumn leaves
Ina Iontcheva
Ina Iontcheva
Last updated: January 16, 2026  •  5 min read
Transform how you create with V-Ray 7 for Maya and Houdini
Summary:
  • V-Ray 7 enhances rendering speed and realism with faster rendering, photorealistic materials, and powerful GPUs, allowing for quicker scene building and creative experimentation.
  • Gaussian splats enable easy 3D capture of real-world locations, while new algorithms and updated denoisers improve image quality by eliminating fireflies and enhancing sharpness.
  • V-Ray GPU for Maya and Houdini supports realistic lighting effects with Caustics and offers improved performance, including faster animation rendering and efficient handling of texture-heavy scenes.
  • Open PBR support in V-Ray 7 for Maya ensures shader consistency across applications, and new layering schemes allow for the creation of complex, lifelike materials.
  • V-Ray 7 for Houdini introduces a new volume shader for creating volumetric effects, extended MaterialX support, and an intuitive toon shading workflow for stylized work.
With V-Ray 7’s faster rendering, photorealistic materials, and powerful GPUs, the technical hurdles fade away, empowering you to build scenes faster, experiment freely, and push your creative boundaries.
Effortlessly capture real-world locations in 3D as easily as snapping a photo with Gaussian splats, dropping highly detailed environments straight into your scene. Enjoy a new algorithm that eliminates fireflies automatically as you render, plus an updated Intel Open Image Denoiser, resulting in sharper and cleaner final images with less effort.
V-Ray GPU for Maya and Houdini now supports Caustics, so you can render realistic lighting effects fast. Performance-wise, V-Ray GPU has also seen many improvements. This includes faster time to first pixel, even faster animation rendering, more efficient rendering of texture-heavy scenes, and a boost in performance thanks to new Metal support for Mac users. With enhanced V-Ray Sun and Sky and Light Path Expressions for shadows, V-Ray 7 gives you so much control over lighting and compositing. You can now render even more realistic natural daylight transitions, including nautical twilight. Plus, you also get even more control in compositing with LPEs for shadows.
👉Read More: From the Apocalypse to Organ Sales: Ada, the Animated Series Featured on TED-Ed, Tackles Big Questions
And this is just the beginning! Let’s dive into the platform-specific features.
V-Ray 7 for Maya: Key features and updates
Red metal object showing PBR supported materials
Open PBR support
Working on a project that transitions between different applications like Autodesk Maya and Adobe Substance Painter? In the past, you might have had to tweak shaders repeatedly to maintain consistency between programs. With OpenPBR support, V-Ray 7 eliminates this hassle, ensuring your shaders maintain the same standard across platforms—no rework required.
We’ve also ensured you can effortlessly create sophisticated effects within this shading standard. With a new layering scheme and an enhanced Sheen layer, you can easily craft complex, lifelike materials. From neon lights, dusty lacquered wood, and peach fuzz to velvet, satin, silk, and more, achieving realistic and intricate details has never been easier.
V-Ray new layering scheme and an enhanced sheen layer
Even more powerful VFB
VFB enhancements in V-Ray 7 now offer even more creative control. You can create custom-shaped regions now, so you can isolate and render specific parts of your scene without re-rendering the whole thing. For example, you could just render a character's face to tweak the skin without rendering the entire environment, saving you a lot of time.
To add to that, there's a new Vignette Layer for more artistic control, and new color correction presets built right in.
jpeg-optimizer_v-ray7-maya-houdini-feature-scatter-improvement-1410x800
More control with Chaos Scatter
Populating your scenes and art-directing your scatters just got easier with new, even more powerful Chaos Scatter controls. Objects can now automatically orient themselves towards a target, like palm trees leaning towards the sun thanks to the new Look at option. With Chaos Scatter, you can use splines as surfaces for scattering, so even more control over placement. The Falloff curve option gives you really precise control over things like altitude variance in vegetation, so you could create a super realistic landscape with just a few clicks.
3D rendering of a modern glass office building surrounded by dense forest. A vertical split shows two lighting and color variations the left side with soft green tones and a reflective pond
Chaos Cosmos
The biggest new Chaos Cosmos feature is asset variants, which allows you to easily switch between different asset versions. For instance, if you're working with a tree model, you can instantly switch between a summer version with vibrant leaves and an autumn version to where they are beautifully falling. Additionally, there's multi-asset selection which lets you import tons of assets from Chaos Cosmos at the same time.
3D rendering of a futuristic sci-fi corridor with orange walls, glowing control panels, exposed cables, and industrial machinery. The passage is illuminated by ceiling lights and red indicators, leading to a circular sealed door at the end.
V-Ray Luminaires
With support for V-Ray Luminaires complex light fixture assets available in our ever-growing Chaos Cosmos library, you can now achieve more physically accurate lighting faster and instantly elevate the quality and realism of artificial lights in your scenes.
Extended USD support
V-Ray 7 for Maya supports the latest official version of MayaUSD 0.30.0. We’ve also extended our support to include V-Ray Clipper alongside other enhancements to ensure seamless data exchange between V-Ray integrations.
Learn more
What's new in V-Ray 7 for Houdini
Rendering of a dense forest and mountain surrounded by clouds
© Davide Valvona
New Volume Shader
V-Ray 7 for Houdini introduces powerful shading updates, starting with the new volume shader—an initial implementation that enables you to easily create amazing volumetric effects like clouds, smoke, and captivating atmospheres with magical effects that add depth and powerful storytelling to your scenes. You can build shading graphs to craft complex shaders and customize your effects, and enjoy greater control over your volumetrics in compositing thanks to light select support. Plus, the new volume shader renders up to x6 times faster.
MaterialX support extended
You can now create and render most MtlX procedural textures, including noises, patterns, and randomization options.
Easier toon shading
We’ve completely redesigned the toon shading workflow in V-Ray for Solaris to make it way more intuitive. If you want that classic look with the bold outlines and flat colors, it's easier than ever to achieve that. That's great news for anyone doing non-photorealistic, stylized work.
Example of toon shading in V-Ray 7 for Houdini
Chaos Cosmos support in Solaris
Chaos Cosmos is fully integrated with V-Ray for Solaris now, so you have access to a massive library of assets including stones, vegetation, and other essential props. Users can populate their scenes with all those amazing models, materials, and HDRIs from Chaos Cosmos and make their stunning, immersive scenes with ease.
Car assets
VFB enhancements
V-Ray 7 also offers Houdini users some nice VFB enhancements, custom-shaped render regions, and color correction presets.
Yeti cache support & Copernicus support
With the new V-Ray yeti node, you can render Yeti cache files right in Solaris. So if you've created super detailed fur or hair grooms in another program like Maya, you can bring them straight into Houdini and render them without breaking a sweat. Plus, V-Ray for Solaris now supports Copernicus, a powerful procedural texturing tool, enabling more third-party plugin options and greater flexibility when working with V-Ray.
Learn more
A whole new world of creative freedom
We've talked about a ton of new features in V-Ray 7 for both Maya and Houdini, but if we zoom out a bit and look at the bigger picture it's not just about the individual features themselves, but what becomes possible creatively when you combine them together.
Artists can now create faster, experiment more freely, and really push their creative boundaries. V-Ray 7 is all about creative freedom. So what are you waiting for? Unleash your creativity and let the art, the story, and the fun of creation take center stage, while the technical fades away.
Try now
chaos logo
Report: How AI is reshaping design & visualization in 2026
How AI is reshaping architectural design and visualization in 2026 new report from Chaos and Architizer
Share
Ina Iontcheva
Ina Iontcheva
Ina is a Content Marketing Manager at Chaos with a great passion for writing and the visual arts. She finds inspiration in exploring the way textures and shapes interact with each other in space.
