V-Ray render of a gold ergonomic office chair at wooden desk in modern home office setup.
© Vitor Souza
Vitor Souza
Vitor Souza
Last updated: September 08, 2026  •  5 min read
Visualizing the Atria Chair: Precision shading, color fidelity, and workflow efficiency
Vitor Souza is a senior 3D modeler and designer based in Rio de Janeiro, Brazil. His experience in 3D modeling includes working on games and in product design. Over his career, he has produced product visualizations for DT3, a pioneering brand in the gaming chair market.
Visualizing commercial furniture for competitive e-commerce and architectural markets demands a delicate balance between artistic storytelling and rigorous physical fidelity. Traditional CGI often suffers from a sterile, "over-polished" aesthetic commonly referred to as the "plastic look." For the Atria Chair, a flagship ergonomic high-end office product developed by DT3, the objective was to engineer an uncompromised Digital Twin.
This article presents the visualization process and strategy behind "Concept Atria: Color with Purpose." This approach was developed to accurately represent vibrant-colored polymers, technical mesh geometries, and metal structures. By utilizing an advanced workflow in 3ds Max and V-Ray 7 (GPU engine) in conjunction with the Chaos Cosmos ecosystem this project established a robust pipeline that connects physical manufacturing data with commercial grade photorealism.
1. Material engineering: The "Real DNA" micro-texturing pipeline
V-Ray render of a close-up of ergonomic chair's adjustable headrest and mesh backrest mechanism.
The defining feature of the Atria chair is its high-density seat and backrest mesh. Unlike generic procedural shaders or tileable textures that lack tactile weight, Atria utilizes a bespoke geometric micro-weave pattern composed of interlocking triangular scales. Here is what the pipeline workflow looks like:
  • High-Res Capture: Extraction of high-resolution photographic data directly from physical textile samples of the Atria mesh.
  • Photoshop Calibration: Generation of seamless Albedo, Bump/Displacement, and Glossiness maps, eliminating repetition artifacts across sweeping curves.
  • UVW Mapping: Precision manual calibration in 3ds Max ensuring the physical scale of the triangular weave matches the millimeter-exact factory product.
  • Smart Asset Hub: Integration into the Chaos Cosmos ecosystem with V-Ray.
2. Advanced material specifications & shader engineering
V-Ray Render of five ergonomic office chairs in green, gold, black, white, and red mesh finishes.
Harmonizing vibrant, saturated colors alongside technical engineering plastics and structural alloys required precise physical parameter calibration. Each surface on the Atria Chair carries its own optical behavior, so no single shader setup could serve the whole model. The table below breaks down how each component was approached. Together, these parameters are what separate a convincing render from one that reads as flat or synthetic.
Component / Part
Material Identification
Shader / V-Ray Parameters
Technical & Aesthetic Purpose
Shell & Frame
Satin Technical Polymer
• Glossiness: 0.65 – 0.75
• Roughness: Low-contrast
• Diffuse: Calibrated Albedo
Creates broad, soft specular reflections to accurately simulate a satin technical polymer finish, avoiding the harsh specular highlights of polished plastic .
Base & Piston
Brushed Alloy
• Anisotropy: -0.6
Produces fluid, elongated specular highlight streaks following the legs' continuous curvature.
Seat & Backrest
High-Density Tri-Mesh
• Texture: Authorial Photographic Map
Delivers physical volume, block transparency, and authentic micro-fiber light scattering.
Castors / Accents
Engineering Plastic (POM)
• Roughness: High light absorption
• Reflectance: Low specular
Provides visual grounding and high contrast anchoring against reflective studio backdrops.
V-Ray render of an Ergonomic mesh chair at reclaimed wood desk against a red accent wall.
3. Studio lighting strategy: Cool temperature & light mix control
V-Ray render of a coral-red ergonomic office chair shown from the back, showcasing lumbar support.
Lighting design for saturated commercial products must strictly avoid shifting product colors or degrading material details. Getting there requires control at three separate levels: the physics of cool lighting, the lighting rig breakdown, and Color Bleeding Mitigation via V-Ray Light Mix.
3.1 Studio color balance & specular highlight control (5500K–6500K)
V-Ray render of black and red ergonomic chairs side by side against a teal background.
  • Albedo Fidelity: A neutral-to-cool daylight setup (5500K - 6500K) preserves the true hue of vibrant yellow or red plastics, preventing the warm, muddy color shifts caused by tungsten-like lighting (3000K).
  • Channel Clipping & Highlight Detail: Neutral daylight spectrum avoids saturating the Red color channel prematurely under high key-light intensity. This preserves subtle micro-weave displacement and surface bump details inside the specular highlights.
3.2 Lighting rig breakdown
Light Rig Component
Source Type & Angle
Color Temp (K)
Multiplier
V-Ray Light Mix / Technical Role
Key Light
V-Ray Plane (45° Diagonal)
5500K
25.0 – 35.0
Provides neutral studio illumination to preserve true material albedo and avoid Red channel saturation.
Rim Light
V-Ray Light (Rear Off-Axis)
6000K – 6500K
15.0 – 20.0
Separates the asset from the background, highlighting edge contours and subtle surface bump details.
Top Fill
Overhead Softbox / Plane
5500K
10.0
Softens contact shadows in complex geometry and harmonizes transitions between polymer and fabric components.
Color Bleeding Mitigation via V-Ray Light Mix: High saturation surfaces bounce colored light onto surrounding studio environments. By configuring the setup with V-Ray Light Mix, individual light groups were isolated post-render. Secondary bounce intensities were adjusted independently to maintain absolute neutral white balances on background surfaces while keeping the primary asset vivid.
V-Ray render of five ergonomic chairs in grey, green, red, yellow, and black shown side profile.
4. Production render setup (V-Ray 7 GPU Engine)
To deliver commercial assets across multiple formats (1080x1080, 1080x1350, and 1080x1920), the rendering setup was optimized for physical accuracy, high sample density. Each stage of the pipeline was tuned to hold that accuracy without sacrificing turnaround time. The breakdown below walks through how each of these settings was configured to support the delivery formats:
  • Render Engine: V-Ray GPU using Bucket Sampler mode (Noise Threshold: 0.005 - 0.01). The bucket approach ensures rigorous sample distribution over complex geometry like mesh textures and leather folds.
  • Secondary GI Engine: Light Cache (2000–3000 Subdivisions) for smooth light distribution across dark or ambient studio enclosures.
  • Color Mapping: Reinhard Mapping with a reduced Burn Value (0.35 to 0.50), effectively suppressing clipped specular highlights on metals and plastics while preserving rich midtones.
  • Primary GI Engine (Brute Force): Calculates unbiased global illumination, ensuring precise indirect light distribution and sharp anisotropic reflection details without interpolation artifacts.
  • Render Elements Pipeline: Targeted channel extraction (V-Ray LightMix, Denoiser, Reflection, Specular) provided flexible post-production look-development, enabling quick tonal adjustments directly within the VFB or Photoshop.
V-Ray render of a gold mesh ergonomic chair rear three-quarter view highlighting frame design.
5. Architectural integration & contextual environments
V-Ray render of a red ergonomic chair in sunlit home office beside potted plants and a side table.
A key requirement of modern furniture marketing is demonstrating product adaptability across diverse architectural contexts. The table below outlines the two environments built to prove that range: a studio showcase that lines up the full colorway against a seamless backdrop for catalog and e-commerce use, and a live architectural interior that places the chair within a realistic home office setting, blending warm ambient light with a cooler daylight key to support lifestyle and editorial positioning.
Environment Setup
Composition Strategy
Lighting & Color Palette
Commercial Target
Studio Showcase (Line-up)
Multi-color array against continuous seamless backdrop
High-contrast neutral studio lighting (6000K)
E-commerce catalogs, marketing banners, colorway displays.
Architectural Interior (Live Context)
Focal framing within modern executive home office
Warm architectural ambient paired with cool key daylight
High-end ArchViz, design editorials, lifestyle positioning.
6. Conclusion: Commercial value of the Digital Twin pipeline
V-Ray render of two grey ergonomic chairs with adjustable headrests in a dark accent-lit room.
The DT3 Atria Chair example demonstrates that high-end 3D visualization is more than an aesthetic exercise; it is a strategic marketing asset. By pairing accurate real-world UVW mapping with neutral physical studio lighting (5500K) and pre-optimized asset integration, this workflow reliably bridges the gap between digital modeling and physical manufacturing.
The resulting imagery offers the authenticity of high-end studio photography, the flexibility of instant color variations via CGI, and the structural accuracy required by industrial design standards.
Project Credits
  • Furniture Design & Manufacturing: DT3 (dt3.com)
  • 3D Modeling, Shading, Lighting & Rendering: Vitor Souza
Ready to try Chaos products?
Start your free trial today and explore all features.
Share
Vitor Souza
Vitor Souza
Based in Rio de Janeiro, Vitor Souza is a PUC-RJ graduate and digital media professional who seamlessly blends technology with limitless creativity. He brings extensive expertise across 3D modeling, gaming, augmented reality, and VR, specializing in turning ambitious digital visions into reality. You can contact him via his website or on LinkedIn, both linked below:
