title: "AI architecture prompts: the complete guide for architects"
description: Master AI architecture prompts with this complete guide. Learn prompt techniques to generate stunning visuals and speed up your design workflow.
image: https://blog.chaos.com/hubfs/AI-architecture-prompts.jpg
[Chaos Logo](https://blog.chaos.com/)
- Products
    - [Enscape](https://www.chaos.com/enscape)
    - [V-Ray](https://www.chaos.com/vray)
    - [Corona](https://www.chaos.com/corona)
    - [Veras](https://chaos.com/veras)
    - [Cloud](https://chaos.com/credits)
    - [V-Ray Blender](https://www.chaos.com/vray/blender)
    - [Arena](https://www.chaos.com/arena)
- Industry solutions
    - [Education](https://www.chaos.com/education/educational-hub)
    - [Student](https://www.chaos.com/students)
    - [Educator](https://www.chaos.com/educators)
    - [Institutions](https://www.chaos.com/educational-institutions)
    - [Architectural design](https://www.chaos.com/architecture)
    - [Architectural visualization](https://www.chaos.com/architectural-visualization)
    - [Interior design](https://www.chaos.com/interior-design)
    - [Landscape rendering](https://www.chaos.com/landscape-architecture)
    - [Urban planning](https://www.chaos.com/urban-planning)
    - [Film and television VFX](https://www.chaos.com/film-vfx)
    - [Virtual production](https://www.chaos.com/virtual-production)
    - [Advertising](https://www.chaos.com/advertising)
    - [Automotive](https://www.chaos.com/automotive)
    - [Games](https://www.chaos.com/games)
    - [Product design](https://www.chaos.com/product-design)
    - [Software development](https://www.chaos.com/developers)
- Learning & Community
    - [Learning](https://chaos.com/learning)
    - [Chaos Academy](https://academy.chaos.com/)
    - [Blog](https://blog.chaos.com/)
    - [Case studies](https://blog.chaos.com/tag/case-studies)
    - [CGconnect](https://chaos.com/cgconnect)
    - [Gallery](https://chaos.com/gallery)
    - [Forum](https://forums.chaos.com/)
- Support
    - [Contact Support](https://chaos.com/contact-us)
    - [Help Center](https://support.chaos.com/hc/en-us)
    - [FAQ](https://support.chaos.com/hc/en-us/categories/360003671518-FAQ)
    - [Documentation](https://documentation.chaos.com/)
- [Pricing](https://www.chaos.com/pricing)
[Try](https://www.chaos.com/free-trial)
[Buy](https://www.chaos.com/pricing)
- Products
- Support
[Try](https://www.chaos.com/free-trial) [Buy](https://www.chaos.com/pricing)
[\< All Blog Posts](https://blog.chaos.com)
 Dinnie Muslihat
Published: June 26, 2026  •   16 min read
# AI architecture prompts: the complete guide for architects
A good AI architecture prompt does one thing: it tells the model what you already can't show it. Most architects write weak prompts because they describe the building information, the structure, the geometry, and the floor plan—things that are already in the 3D model or sketch. This results in redundant input, and then, often, the output suffers.
The prompts in this guide are written for architects who start with something real: a [Revit](https://www.chaos.com/enscape/revit-rendering) model, a [SketchUp](https://www.chaos.com/enscape/sketchup-rendering) scene, a hand sketch, or a screenshot of an early massing study. When your geometry already exists, the way you write changes. The prompt becomes a mood instruction, and your job becomes to specify materials, lighting, environment, and image style, not to re-describe what the AI can already see.
Key takeaways:
- Front-load building type and materials: AI models anchor heavily on early prompt input, so lead with what matters most.
- Always specify lighting: as it's the highest-impact variable, skipping it defaults to flat, neutral daylight.
- Match prompt detail to geometry override: low override = materials/lighting focus; high override = full architectural description. In BIM-integrated tools, skip geometry terms entirely and prompt for surface, light, and atmosphere.
- Cap materials at 2–4 terms, then lock your seed: once a style works, fix the seed and vary one parameter at a time across views.
- Avoid incompatible style combinations: pick one primary style and use the others as single accent elements. This which opens up a wider world of concept exploration when paired with the right prompt strategy.
This guide covers everything from prompt anatomy and ready-to-use examples to BIM-integrated workflows and [tool selection](https://blog.chaos.com/ai-tools-for-architects?hsLang=en). Jump to the section most relevant to your current project:
- [What makes an AI architecture prompt work?](https://blog.chaos.com/ai-architecture-prompts#What)
- [Exterior architecture prompts](https://blog.chaos.com/ai-architecture-prompts#Exterior)
- [Interior design prompts](https://blog.chaos.com/ai-architecture-prompts#Interior)
- [Prompts by architectural style](https://blog.chaos.com/ai-architecture-prompts#Style)
- [Prompts for sketch-to-render and BIM-integrated workflows](https://blog.chaos.com/ai-architecture-prompts#BIM)
- [Common prompting mistakes and how to fix them](https://blog.chaos.com/ai-architecture-prompts#Common)
- [Choosing the right AI tool for your prompt type](https://blog.chaos.com/ai-architecture-prompts#Choosing)
## What makes an AI architecture prompt work?
An effective architecture prompt is built from six components, each narrowing the output closer to what you want. Order matters: [AI models](https://blog.chaos.com/ai-in-architecture?hsLang=en) process text left to right, so front-load the attributes that matter most. Burying your lighting specification at the end is one of the most common reasons renders come back flat.
Here's the sequence you should follow, ranked by impact on output quality:
### Subject and building type
Be specific about typology, scale, and character. Writing "cantilevered cliffside residence," "circular sustainable pavilion," or "mixed-use tower with planted terraces" produces fundamentally different outputs from the same tool. Vague subjects give the model too much latitude. Name the building type and, if relevant, the project phase; a massing study reads differently from a schematic design render.
### Materials
Prompts like "modern materials" or "glass facade" tell the model almost nothing, whereas "fluted glass, brushed concrete, and warm teak wood" give it three distinct surface qualities to work with. Be specific about texture and finish, because naming [building materials](https://blog.chaos.com/top-sustainable-building-materials?hsLang=en) more precisely helps the model render the intended surface qualities: reclaimed timber reads differently from smooth CLT panels; Corten steel at midday looks nothing like limestone in soft morning light. List two to four materials maximum; anything more than that and the model averages them into noise. Different materials can materially change the final aesthetic, so choose intentionally rather than exhaustively.
### Lighting
[Lighting](https://blog.chaos.com/lighting-basics-for-3d-rendering-in-enscape?hsLang=en) has more influence on the final image than any other single variable, so specify light conditions with realistic lighting in mind. The same building at golden hour, diffused overcast, and blue-hour twilight produces three images that feel like entirely different projects. Specify time of day, light quality, and direction; the right words here improve realism and control: "volumetric morning rays through foliage," "hard midday sun with high-contrast shadows," "warm interior lighting contrasting with blue-hour exterior." Leave lighting unspecified, and most models default to flat, neutral daylight, technically correct, visually inert.
### Environment and context
The environment sets the emotional register. Specify landscape, climate, and immediate surroundings, think along the lines of: dense pine forest, Mediterranean hillside, urban rooftop, rocky coastline. In a context that supports [sustainable architecture](https://blog.chaos.com/what-is-green-architecture?hsLang=en), goals like eco-friendly, [energy-efficient design](https://blog.chaos.com/what-is-energy-efficiency?hsLang=en), a modern courtyard residence surrounded by lush landscaping read as approachable. The same structure on a desert plateau with heat haze reads as austere. In urban settings, rooftop gardens can shift both the mood and the sustainability cues.
### Camera angle and lens
Lens choice directly affects how a structure reads spatially, and camera settings give you precise control over that read. A wide-angle lens emphasizes scale and the building-landscape relationship. A 35mm lens produces a natural eye-level perspective that reads as architectural photography. Drone view works for massing but flattens facade detail. Tilt-shift gives the controlled perspective correction seen in professional architectural photography. Pair the lens with an aperture: f/8 keeps the full structure sharp; f/2.8 throws the background out of focus, drawing attention to surface detail. When depth of field and light control matter, specify aperture priority mode or another priority mode to guide the [photographic treatment](https://blog.chaos.com/ciro-sannino-vray-corona?hsLang=en). You can also adjust shutter speed to create motion blur, long-exposure effects, or tighter realism.
### Style and render quality modifiers
These signal the output register; how the image should feel, not what it should show. "[Photorealistic](https://blog.chaos.com/7-essential-steps-to-creating-realistic-renderings?hsLang=en)" and "high dynamic range" push toward accuracy. "Cinematic lighting" and "editorial composition" shift toward mood. Use one or two modifiers, as stacking quality descriptors dilutes rather than compounds the effect.
## The stacking order in practice
\[building type\] + \[materials\] + \[lighting\] + \[environment\] + \[camera\] + \[style modifier\]
Example: Cantilevered cliffside residence, fluted glass and brushed concrete, golden hour with warm side light, rocky Pacific coastline, wide-angle 35mm, photorealistic editorial
Even simple prompts can work when each component is doing a clear job. More specific prompts give you greater control when you need tighter output consistency.
Each component hands off to the next: subject establishes what, materials establish the surface, lighting establishes the mood, environment establishes the scale, camera establishes the perspective, and style modifier establishes the output quality.
## Exterior architecture prompts
Each prompt below is copy-paste ready. The note after each one identifies which parameter carries the most weight in that output.
- Contemporary residential
Prompt 1: 'Cantilevered glass villa suspended over a rocky pine forest cliff, floor-to-ceiling glass curtain walls, blue-hour twilight with warm interior lighting contrasting cool exterior, wide-angle 35mm, photorealistic architectural photography'
What does the heavy lifting: the lighting contrast between warm interior and blue-hour exterior is what makes cantilevered structures read as dramatic rather than just geometric.
Prompt 2: 'Corten steel desert house, weathered rust facade against pale sand plateau, hard midday sun with high-contrast shadows, heat haze in the distance, eye-level, ultra-sharp photorealistic'
What does the heavy lifting: the material-environment pairing. Corten steel and desert plateau are visually coherent; the model reinforces that relationship rather than resolving a conflict.
- Sustainable and biophilic
Prompt 1: '[Biophilic](https://blog.chaos.com/biophilic-design?hsLang=en) hillside residence integrated into a tropical slope, cascading planted terraces, limestone and warm teak wood facade, vertical gardens framing large windows, cinematic morning light with soft volumetric rays, wide-angle photorealistic editorial'
What does the heavy lifting: volumetric morning light give depth to layered greenery. It prevents the terraces from reading as flat.
Prompt 2: 'Mass timber passive house in a dense forest, cross-laminated timber structure, south-facing floor-to-ceiling glazing, solar panels integrated into the roof plane, diffused overcast daylight, clean composition, photorealistic'
What does the heavy lifting: diffused light. Overcast conditions render timber grain and material texture more accurately than direct sun, which blows out pale wood surfaces.
- Vernacular and contextual
Prompt 1: 'Neoclassical public building, white marble facade, Doric columns, triangular pediment, symmetrical urban plaza with a central fountain, hard midday sun, clean lines, wide-angle editorial'
What does the heavy lifting: the symmetry instruction embedded in "symmetrical urban plaza," anchors the composition. It stops the model from generating an off-axis view.
Prompt 2: 'Brutalist architecture complex, raw exposed concrete facade, bold massed geometry, dense urban setting, dramatic side lighting emphasizing surface texture, overcast sky, eye-level 35mm photorealistic'
What does the heavy lifting: side lighting. Brutalist architecture depends on shadow to read as intentional, rather than just heavy frontal light flattens it entirely.
- Parametric and experimental
Prompt 1: 'Computational parametric facade, folded aluminum panels with angular shadow geometry, glass curtain walls, urban skyline at dusk, vibrant colors in the sky contrasting the metallic structure, wide-angle, cinematic lighting, high dynamic range'
What does the heavy lifting: the dusk sky. Parametric facades need a strong background contrast to separate panel geometry from the surrounding context.
Prompt 2: 'Shell-inspired suspended structure, curved surfaces resembling a seashell, dappled natural light across the facade, lush landscaping at the base, tranquil pool reflecting the form, fish-eye lens, soft lighting, photorealistic'
What does the heavy lifting: the fish-eye lens. It's the only camera setting that accurately renders the full curvature of a shell-form without geometric distortion at the edges.
## Interior design prompts
- Living and social spaces
Prompt 1: 'Minimalist living room, polished concrete floor, white sofa, floor-to-ceiling windows with natural light flooding the space, 24mm wide-angle lens, clean composition, photorealistic [architectural interior](https://blog.chaos.com/architectural-rendering-basics-interiors?hsLang=en)'
What does the heavy lifting: the 24mm lens. It's wide enough to capture the full room without distortion, and it emphasizes ceiling height, which is critical for minimalist interiors where spatial volume is the main design statement.
Prompt 2: 'Industrial loft, sleek urban loft aesthetic, exposed brick walls, steel beams, open shelving, copper accents, warm afternoon light entering through large windows, soft lighting on interior surfaces, 35mm eye-level, photorealistic'
What does the heavy lifting: afternoon light direction. Side-raking light at this time of day catches the brick texture and copper reflectivity simultaneously, which gives you material depth without [artificial lighting effects](https://blog.chaos.com/electric-lighting-enscape-new-light-management-feature?hsLang=en).
- Kitchen and dining
Prompt 1: '[Open-plan kitchen](https://blog.chaos.com/kitchen-renovation-veras-4.0?hsLang=en), Calacatta marble island with visible veining, matte black fixtures, integrated pendant lighting, clean lines, diffused soft lighting, wide-angle 28mm, photorealistic editorial interior'
What does the heavy lifting: specifying visible veining on the marble, without it, the model renders a generic white surface. That one phrase forces material-level detail.
Prompt 2: 'Japanese dining room, shoji screens diffusing natural light, low timber dining table, raked sand garden visible through floor-to-ceiling glass, clean composition, soft lighting, 35mm eye-level, photorealistic'
What does the heavy lifting: the raked sand garden as a background element. It gives the model a depth cue and reinforces the spatial logic of the interior without requiring additional descriptors.
- Wellness and hospitality
Prompt 1: 'Luxury spa bathroom, Venetian plaster walls, gold fixtures, eucalyptus branches, steam atmosphere, warm LED strip lighting along the ceiling perimeter, diffused light, 35mm, cinematic [photorealistic interior](https://blog.chaos.com/interior-rendering-best-practices?hsLang=en)'
What does the heavy lifting: steam atmosphere. It softens edges, diffuses the LED lighting naturally, and gives the render an immediate sense of warmth that no lighting modifier alone achieves.
Prompt 2: 'Luxury hotel suite, double-height space, woven timber ceiling, floor-to-ceiling windows, warm interior lighting at evening, [lush landscaping](https://blog.chaos.com/beautiful-landscape-renders-by-the-enscape-community?hsLang=en) visible outside the glass, wide-angle 24mm, cinematic lighting, photorealistic'
What does the heavy lifting: the double-height instruction, paired with a wide-angle lens. Together, they force the model to render the vertical scale accurately. Without both, the room collapses to a standard ceiling height.
## Prompts by architectural styles
Use this table as a starting reference. Pick your style, pull the core elements and lighting suggestion into the prompt structure from the previous section, then adjust for your specific building type and context.
| Architectural style | Core prompt elements | Suggested lighting | Works best in |
| **Modernist** | Clean lines, flat roof, floor-to-ceiling windows, glass curtain walls, white or grey render, open plan | Diffused overcast or soft golden hour | Text-to-image (Midjourney, Firefly) / BIM-integrated (Veras) |
| **Brutalist** | Raw exposed concrete, bold massed geometry, deeply recessed windows, ribbed or board-formed surfaces | Hard side lighting, dramatic shadows, overcast sky | Text-to-image — geometry hallucination less critical for abstract massing |
| **Neoclassical** | Doric or Ionic columns, triangular pediment, white marble facade, symmetrical composition, urban plaza context | Hard midday sun, even frontal lighting | Text-to-image for concept; Veras for model-based elevation studies |
| **Biophilic** | Planted terraces, vertical gardens, limestone and teak, large windows, reflecting pools, dense greenery | Volumetric morning rays, cinematic dawn, soft golden hour | BIM-integrated (Veras) — geometry grounds the landscaping relationship |
| **Japandi** | Timber slats, shoji screens, raked sand garden, matte plaster, low furniture, floor-to-ceiling glass | Soft diffused natural light, overcast morning | BIM-integrated for interiors; text-to-image for exterior concept |
| **Sustainable/mass timber** | Cross-laminated timber, solar panels integrated into roof, south-facing glazing, green roof, reclaimed materials | Diffused overcast — renders timber grain accurately without blowout | BIM-integrated (Veras) — solar panel placement needs geometric accuracy |
| **Parametric** | Folded aluminium panels, computational facade, non-repeating geometry, glass curtain walls, angular shadow geometry | Dusk or blue hour — sky contrast separates panel geometry from context | BIM-integrated (Veras) — solar panel placement needs geometric accuracy |
| **Adaptive reuse** | Exposed original brickwork, steel insertions, industrial glazing, contrast between old fabric and new elements | Warm interior lighting against cooler exterior, afternoon side light | Text-to-image for atmosphere; Veras for retrofit studies on existing model geometry |
| **Mediterranean vernacular** | Limestone or stucco render, terracotta roof tiles, deep window reveals, courtyard with tranquil pool, lush landscaping | Golden hour, warm side light, long shadows | Text-to-image and BIM-integrated — both handle warm-palette scenes well |
| **Bauhaus** | Primary colors or white render, flat roof, ribbon windows, industrial materials, asymmetric but balanced composition | Clean diffused daylight, minimal shadow drama | Text-to-image — the style depends on geometric precision the model handles well from description alone |
## Prompts for sketch-to-render and BIM-integrated workflows
### How prompting changes when your geometry already exists
When a tool like [Veras](https://www.chaos.com/veras) reads your model, the geometry is already visible to the AI: floor count, massing, window placement, and spatial layout. Your prompt is not a description of the building; it's an instruction for how that building should look and feel.
Drop the geometry descriptors and use that space for what the model cannot see, such as materials, lighting, environment, and atmosphere. A prompt like "modern [residential building](https://blog.chaos.com/what-is-residential-architecture?hsLang=en) with large windows and an open plan" wastes every word on information already in the model. Whereas a prompt like "warm concrete, exposed aggregate, afternoon sun, Mediterranean courtyard, photorealistic" tells the AI everything it actually needs. It helps the tool visualize atmosphere and material intent rather than redraw geometry.
 Try Veras free for 14 days
[Try now](https://www.chaos.com/veras)
### Geometry override and what it means for your prompt
At low override, the AI respects your geometry and applies materials and lighting without altering the structure. Prompts should focus entirely on surface and light.
At high override, the AI takes creative liberties with the form. Prompts should describe the architecture more fully, since you're inviting the model to reinterpret the structure.
Same base model, two intents:
1. Low override: warm concrete walls, exposed aggregate, afternoon sun, Mediterranean courtyard, photorealistic
2. High override: biophilic tower with vertical gardens, cascading planted terraces, limestone and glass curtain walls, tropical hillside, cinematic dawn light, photorealistic editorial
At high override, form descriptors like "biophilic tower" and "cascading terraces" are useful. At low override, they create tension with the existing geometry and degrade the output.
### Prompting from hand sketches and 2D drawings
When you upload a sketch, the model can see your spatial layout but can't read material intent from linework alone, though [AI-generated imagery](https://blog.chaos.com/ai-rendering-for-architecture?hsLang=en) can still depict innovative architectural concepts even from a loose drawing. Your prompt should specify what the sketch can't show: surface, light, and environment.
A sketch of a courtyard house does not need "courtyard house with surrounding walls and central open space" in the prompt; the model already sees that. It needs: limestone render, terracotta floor, tranquil pool, golden hour, warm sidelight, lush landscaping at the perimeter, and photorealistic.
The more resolved the sketch, the less form description the prompt needs. The same approach also works for broader architectural prompts built from diagrams or simple linework.
### Keeping consistency across views: the seed approach
Once you find a prompt and output that captures the right atmosphere, lock the seed before generating additional views. The seed preserves lighting quality, material rendering, and color palette across views while the geometry changes.
For a presentation deck, the workflow is: generate the first view, approve the style, lock seed, generate remaining views with the same prompt, then make single-variable adjustments per view where needed, such as camera angle, time of day, or foreground landscaping—this lets you compare results across locked-seed variations without losing consistency. The result reads as one scheme rather than five separate [AI experiments](https://blog.chaos.com/ai-in-architecture-research?hsLang=en).
## Common prompting mistakes and how to fix them
- Overloading the prompt
Having more descriptors doesn't mean producing better renders in AI prompts. Beyond 12–15 terms, the model starts averaging inputs, and the output loses definition.
Weak: modern sustainable biophilic residential villa, glass and timber and concrete and steel and brick, golden hour, blue hour, overcast, dramatic shadows, soft light, wide-angle, drone view, fish-eye, cinematic, photorealistic, ultra-sharp, high dynamic range, editorial
Fixed: biophilic hillside villa, limestone and warm teak, volumetric morning light, wide-angle 35mm, photorealistic editorial
- Generic material terms
"Modern materials," "natural finishes," and "glass facade" give the model nothing specific to render. Name the material, the finish, and, where possible, add concrete details such as texture.
Weak: [contemporary house](https://blog.chaos.com/what-is-contemporary-architecture?hsLang=en) with modern materials and a glass exterior
Fixed: fluted glass curtain walls, brushed concrete base, reclaimed timber soffits
- Missing lighting specification
Without a lighting instruction, most models default to flat neutral daylight. The render is technically correct and visually inert.
Weak: minimalist concrete pavilion, forest context, wide-angle, photorealistic
Fixed: minimalist concrete pavilion, forest context, diffused light through pine canopy, soft shadows, wide-angle, photorealistic
- Describing geometry, the model already has
In [BIM-integrated tools](https://www.chaos.com/bim-management) like [Veras](https://blog.chaos.com/what-is-veras?hsLang=en), describing your building's form wastes prompt space and can create conflict with the existing geometry.
Weak: five-story residential building with large windows, open plan floors, and a flat roof, concrete and glass
Fixed: warm concrete, floor-to-ceiling glass, golden hour, urban rooftop context, photorealistic
- Stacking incompatible styles
Combining styles with contradictory visual languages forces the model to resolve a conflict it cannot win, especially when too many [architectural styles](https://blog.chaos.com/architectural-styles-that-changed-the-industry?hsLang=en) are mixed into a single prompt. The output satisfies none of the references.
Weak: brutalist biophilic Japandi residence with raw concrete, vertical gardens, and timber slats and shoji screens
Fixed: Pick one primary style and use the others as single accent elements: Japandi residence, timber slats and matte plaster, shoji screens, single moss wall as biophilic accent, diffused natural light
## Choosing the right AI tool for your prompt type
The prompt type you need determines the tool you should use. This table covers the five most widely used options across [architecture workflows](https://blog.chaos.com/ai-archdesign-workflows?hsLang=en).
| Tool | Works from | BIM integration | Best for |
| **Veras** | Text prompt, image upload, 3D model | Yes — Revit, SketchUp, Rhino, Vectorworks, Archicad | Design development renders that need to reflect actual building geometry; sketch-to-render workflows; iterative concept exploration within an existing CAD/BIM environment |
| **Midjourney** | Text prompt only | No | Mood boards, competition imagery, and early concept visuals where artistic impact matters more than geometric accuracy, with strong spatial aesthetics and realistic materials |
| **Adobe Firefly** | Text prompt, reference image | No | Client-facing mood collages, non-technical users, and teams already in the Adobe Creative Cloud ecosystem |
| **Rendair AI** | Image upload, text prompt | No | Quick concept variations from screenshots or sketches; accessible entry point for students and small practices |
| **Stable Diffusion** | Text prompt, image input | No (third-party plugins exist) | Custom workflows, open-source fine-tuning, and users who need full control over the model and output pipeline |
| **Nano Banana Pro** | Text prompt, image input | No | Softer, refined architectural visuals |
The axis that matters most for practicing architects is the third column. If your workflow starts from a 3D model or sketch, [BIM](https://blog.chaos.com/what-is-bim?hsLang=en) integration determines whether the tool preserves your geometry or ignores it entirely. Stable Diffusion and Midjourney are both effective for early design concepts, with different tradeoffs in control and output character. For everything else—mood boards, competition entries, client inspiration decks—any [text-to-image tool](https://blog.chaos.com/best-ai-rendering-tools-for-architects-compared?hsLang=en) produces usable output, and the choice comes down to image-quality preferences and budget.
## Bottom line
The best prompt matches the tool you are working in, and choosing the right words matters as much as choosing the right tool when shaping output quality. For standalone text-to-image tools, describe everything, as the model has no other information to work from. For BIM-integrated tools like [Veras](https://blog.chaos.com/whats-new-in-veras?hsLang=en), your model handles the geometry, and your prompt handles the mood. Start with lighting and materials, iterate with seed locking, and reserve full design exploration prompts for high-geometry overrides.
[![Try Veras](https://no-cache.hubspot.com/cta/default/6852391/0efee417-8dca-4aac-94c9-8079e167af41.png)](https://cta-redirect.hubspot.com/cta/redirect/6852391/0efee417-8dca-4aac-94c9-8079e167af41)
## FAQ
### How do I include material textures in AI architecture prompts?
Name the texture explicitly rather than the material category. "Brushed concrete" and "board-formed concrete" produce different surfaces despite being the same material. Use finish descriptors such as rough, polished, weathered, ribbed, paired with the material name. For composite surfaces, specify which texture belongs to which element: "fluted glass facade, rough limestone base, smooth teak soffits."
### What are negative prompts, and should I use them for architecture renders?
Negative prompts tell the model what to exclude. In tools that support them, primarily Stable Diffusion, they remove recurring problems: "blurry, distorted windows, floating elements, unrealistic proportions." Midjourney and Veras do not use traditional negative prompts; in these tools, precision in the positive prompt is the primary quality-control mechanism.
### Can ChatGPT generate architecture renders?
ChatGPT does not generate images. It can help write, refine, and structure prompts, draft AI prompts, and polish prompt wording before you paste them into a text-to-image tool like Midjourney or Firefly. For direct image output, you need a separate generation tool, or a BIM-integrated tool like Veras if you are working from an existing model.
### Ready to try Chaos products?
Start your free trial today and explore all features.
[Start Free Trial](https://www.chaos.com/free-trial)
Share
<https://www.facebook.com/sharer/sharer.php?u=https://blog.chaos.com/ai-architecture-prompts&title=AI%20architecture%20prompts:%20the%20complete%20guide%20for%20architects&picture=https://blog.chaos.com/hubfs/AI-architecture-prompts.jpg&description=Master%20AI%20architecture%20prompts%20with%20this%20complete%20guide.%20Learn%20prompt%20techniques%20to%20generate%20stunning%20visuals%20and%20speed%20up%20your%20design%20workflow.>
<https://twitter.com/share?url=https://blog.chaos.com/ai-architecture-prompts&hashtags=>
<https://www.linkedin.com/shareArticle?mini=true&url=https://blog.chaos.com/ai-architecture-prompts&title=AI%20architecture%20prompts:%20the%20complete%20guide%20for%20architects&summary=Master%20AI%20architecture%20prompts%20with%20this%20complete%20guide.%20Learn%20prompt%20techniques%20to%20generate%20stunning%20visuals%20and%20speed%20up%20your%20design%20workflow.>
[mailto:?subject=AI%20architecture%20prompts:%20the%20complete%20guide%20for%20architects&body=AI%20architecture%20prompts:%20the%20complete%20guide%20for%20architects%20https://blog.chaos.com/ai-architecture-prompts](mailto:?subject=AI%20architecture%20prompts:%20the%20complete%20guide%20for%20architects&body=AI%20architecture%20prompts:%20the%20complete%20guide%20for%20architects%20https://blog.chaos.com/ai-architecture-prompts)
[BIM](https://blog.chaos.com/tag/bim) [Architecture](https://blog.chaos.com/tag/architecture) [AI](https://blog.chaos.com/tag/ai) [Veras](https://blog.chaos.com/tag/veras) [Tips & tricks](https://blog.chaos.com/tag/tips-tricks)
Dinnie Muslihat
Dinnie manages the Chaos blog, where she publishes practical guides, industry insights, and inspiring projects for architects, artists, and designers. Have an idea for an article? Get in touch at blog-editor@chaos.com.
<https://www.linkedin.com/in/dinniemuslihat>
## Related Articles
### [November 9, 2026 Real-Time Rendering for Architects: How It Works and When to Use It Andreea Lipan  •  10 min read Read more](https://blog.chaos.com/real-time-rendering-for-architects?hsLang=en)
### [November 6, 2026 Veras vs. Standalone GPT-6 Astra and Claude Opus 5.5: A comparison Bill Allen  •  8 min read Read more](https://blog.chaos.com/veras-vs-gpt-6-astra-claude-opus-5-5?hsLang=en)
### [November 5, 2026 V-Ray 7, Update 5: Easier to Use & More Powerful Than Ever Dinnie Muslihat  •  8 min read Read more](https://blog.chaos.com/v-ray-7-update-5?hsLang=en)
[Visit the blog for more articles](https://blog.chaos.com)
## Subscribe to Our Blog
<https://www.chaos.com/>
<https://www.chaos.com/enscape> <https://www.chaos.com/vray> <https://www.chaos.com/corona> <https://www.chaos.com/veras>
Chaos
- [About us](https://www.chaos.com/about)
- [Blog](https://blog.chaos.com)
- [Press](https://www.chaos.com/press)
- [Careers](https://www.chaos.com/careers)
- [Events](https://www.chaos.com/events)
- [Contact us](https://www.chaos.com/contact-us)
Purchasing
- [Buy online](https://www.chaos.com/pricing)
- [Find a reseller](https://www.chaos.com/pricing/resellers)
- [Upgrade options](https://www.chaos.com/upgrade)
- [Manage your products](https://my.chaos.com/products)
- [Download your software](https://download.chaos.com/)
- [Refund policy](https://support.chaos.com/hc/en-us/articles/4402140621457-Do-you-offer-refunds-What-is-your-refund-policy)
- [Help with purchasing](https://support.chaos.com/hc/en-us/sections/360005717237-Purchasing)
- [Become a reseller](https://www.chaos.com/become-partner)
Support
- [Resources](https://academy.chaos.com/catalog)
- [Get support](https://support.chaos.com/hc/en-us/categories/360003671518-FAQ)
- [Service status](https://status.chaos.com/)
- [Help docs](https://docs.chaos.com/)
- [Forums](https://www.chaos.com/forums)
Passion projects
- [CGconnect](https://cgconnect.chaos.com/)
- [CG Garage podcast](https://www.chaos.com/cg-garage)
Technology
- [Real-time rendering](https://www.chaos.com/real-time-rendering)
- [3D rendering](https://www.chaos.com/3d-rendering-software)
- [GPU rendering](https://www.chaos.com/vray-gpu)
- [Fluid dynamics simulation](https://www.chaos.com/fluid-dynamics-software)
- [Cloud rendering](https://www.chaos.com/cloud-rendering)
- [Photorealistic rendering](https://www.chaos.com/photorealistic-rendering)
- [Innovation Lab](https://www.chaos.com/innovation-lab)
- [Responsible AI](https://www.chaos.com/responsible-ai)
Follow us
- <https://www.chaos.com/social-channels#facebook>
- <https://www.chaos.com/social-channels#instagram>
- <https://www.chaos.com/social-channels#youtube>
- <https://www.chaos.com/social-channels#linkedin>
- [Terms of use](https://www.chaos.com/terms)
- [Privacy policy](https://www.chaos.com/privacy)
- [Legal](https://www.chaos.com/legal)
- [Sitemap](https://www.chaos.com/sitemap)
- Cookie-Einstellungen
```json
  "@context" : "https://schema.org",
  "@type" : "BlogPosting",
  "author" : {
    "@type" : "Person",
    "name" : "Dinnie Muslihat",
    "url" : "https://blog.chaos.com/author/dinnie-muslihat"
  "dateModified" : "2026-06-26T14:41:37.417Z",
  "datePublished" : "2026-06-26T14:40:34.000Z",
  "headline" : "AI architecture prompts: the complete guide for architects",
  "image" : [ "https://blog.chaos.com/hubfs/AI-architecture-prompts.jpg" ],
  "mainEntityOfPage" : {
    "@id" : "https://blog.chaos.com/ai-architecture-prompts",
    "@type" : "WebPage"
  "publisher" : {
    "@type" : "Organization",
    "logo" : {
      "@type" : "ImageObject",
      "url" : "https://blog.chaos.com/hubfs/Chaos_Icon_Colour_RGB.png"
    "name" : "Chaos Software GmbH"
