3D interior rendering of a modern living room with a sofa, pillows, coffee table, and realistic rug created in V-Ray for 3ds Max.
Ramy Hanna
Ramy Hanna
Last updated: December 19, 2025  •  6 min read
Creating Rugs with V-Ray for 3ds Max
Summary:
  • TILTPIXEL artist Ramy Hanna shares techniques for creating realistic 3D rugs using V-Ray for 3ds Max, emphasizing the importance of texture methods for visual accuracy and creative control.
  • The VRayDisplacementMod technique uses a Cellular map for displacement, offering quick results but limited detail in close-ups and control over fur direction.
  • VRayFur provides two methods for creating rug strands, with adjustable settings like length, thickness, and taper to achieve desired effects, including curly and clumpy styles.
  • VRayDistanceTex helps manage fur growth around objects, using a Density Map to prevent fur from growing through furniture, enhancing scene realism.
  • These methods offer endless possibilities for customizing 3D rug textures, allowing artists to achieve unique and controlled visual results.
TILTPIXEL partner and artist Ramy Hanna explores the creation of realistic 3D rugs in his latest V-Ray for 3ds Max tutorial. Ramy, a frequent presenter at conferences, reminds artists that “textures can be approached multiple ways.” However, some methods provide better results than others, producing visually accurate textures while offering creative control and fast results.
Here, Ramy dissects the options and weighs in on his methods of choice.
The scene
3D wireframe rendering of a sofa, pillows, and rug in V-Ray for 3ds Max, showing geometry setup for creating realistic fabrics.
© Tiltpixel
The rug in our scene is created from a chamfer box with the bottom half deleted. This allows a slight curvature to the rug itself. The rug also has fifty segments in both the length and width.
Option 1: VRayDisplacementMod
The first technique uses the VRayDisplacement modifier on the rug mesh itself. I used the 3ds Max Cellular map to drive displacement. The only adjustment to the Cellular map was the size, set to 0.001.
Displacement: 0.0"
Displacement: 0.125"
Displacement: 0.25"
Displacement: 0.5"
Displacement: 1"
Displacement: 2"
In this example, the settings in the modifier are the default settings except for turning Keep continuity on. You should note that the Amount of displacement ranges from 0"–2" and increasing the displacement gives very different results. While this is a quick and effective solution for camera angles that are not close to the rug, the detail in the rug breaks down when you look at the close-ups. Additionally, you will see that as the displacement amount increases, the control on the fur direction is limited with straight strands of fur. You could probably get away with using a vector map to control bending in the strands themselves, but again, this depends on how close the camera is to the mesh.
Option 2: VRayFur
Now we'll explore using VRayFur to create our rug strands. Using VRayFur in a scene is quite simple and can be done in one of the two ways. For both methods, first select the object for which you will generate fur.
Method 1:
1. In the Command Panel, choose the Create tab. 2. Be sure the Geometry button is selected. 3. In the rollout, choose V-Ray from the list. 4. Finally, select the VRayFur button.
This series of steps creates the VRayFur object, and you will instantly see strands of fur on your selection.
Method 2 (my preference):
If you have the V-Ray Toolbar open, with your object selected, simply click on the VRayFur button that has an icon of what looks like grass. Easy enough.
3D rendering of a sofa and pillows with a rug in progress, showing V-Ray fur strands before final material application.
@ Tiltpixel
As you can see, the default settings are less than ideal. With just a few tweaks, however, we can achieve the desired effect.
Length: This one is self-explanatory. To start, I changed the length from the default of 1'3" to 0.125". We will discuss various lengths again shortly.
Thickness: Here, I adjusted the thickness from 0.2" to 0.02".
Gravity: This is the one value that doesn’t change in real life, so I left it as the default setting. Of course, if you’re going for a unique look, feel free to change this up. That’s why it’s here!
Bend: For now, I’m leaving this as the default value.
Taper: Taper determines how thin the strand gets as it approaches the tip. The default is at 0.0 with no taper, while 1.0 means it goes to a sharp point. For this exercise, I adjusted the value to 0.85.
For now, I won’t adjust any of the variation amounts, but we will look at the way Distribution works.
Comparison of V-Ray fur distribution settings, showing per area versus per face rug strand placement.
@ Tiltpixel
Per area is the default setting. This setting simply means that for every square inch in the scene there are X number of strands. Switching to Per face tells V-Ray to place X number of strands within each face. I have found this method to be more consistent for giving me the results that I desire. However, keep in mind that small faces will have the same number of strands as large faces, so it really comes down to the effect you are trying to achieve.
Length: 0.125"
Length: 0.25"
Length: 0.5"
Length: 1"
This example simply shows the adjustments in Length of the strands with the above settings already described. As you can see, the rug becomes darker as the strands become longer. This is simply due to light getting trapped in-between the strands. The ideal length really depends on the look or style you are trying to achieve.
There are a few other styles of rugs that we will explore, along with the settings to achieve each style.
Curly
3D rendering of a sofa and rug with V-Ray fur settings, showing curly strand parameters for realistic carpet detail.
@ Tiltpixel
Rugs come in an infinite array of shapes and looks. Some are fluffier while others have a tighter, curlier pile. To achieve the latter, V-Ray has a curl property. When turned on, this tool allows you to specify the details behind the fibers’ curls. Here, I set the Curl radius to 0.05. The length of the strand is a factor for the way the curl is displayed. I also set the Number of curls to 4. Note that I adjusted the bend to 0.0 to keep the strands straight and just allow for the curl to control the bending.
Clumpy
V-Ray fur clumpy strand settings applied to a 3D rug in front of a modern sofa, demonstrating realistic carpet variations in 3ds Max.
@ Tiltpixel
The clumpy settings enable portions of the rug to grow in a specific direction. V-Ray allows you to control specific properties to be driven by maps. In this case, I used a combination of a Cellular map with a Noise map to regulate the direction.
Direction in this case is driven by the RGB values, with each color as a different direction.
Red: u texture offset
Green: v texture offset Blue: surface normal offset
These parameters require a bit of trial and error, and you can achieve some very interesting and surprising results from simply adjusting the colors and values.
DistanceTex
In each example above, you can achieve some unique, controlled results, but as the strands get longer there is one problem that arises. The fur has no regard for other objects in the scene. This is evident when there is a piece of furniture that the fur will grow through or over. An easy yet powerful solution, however, prevents fur from growing where objects stand in place.
Without Distance Tex
With Distance Tex
Just like the Initial Direction Map, there is an option called Density Map. This field specifies which portions of the rug will grow fur and which will not. Simply put, a greyscale image will determine the density of the fur in that area with white being 100% dense and black having no fur. Cleverly, V-Ray has a map called VRayDistanceTex that allows you to specify objects in the scene to drive the Density Map.
In this map, you can specify which objects in the scene will control the density of the fur. Here, I applied the base of the lamp and the legs of the coffee table. Where these objects exist in the scene, the Density map will generate zero strands of fur. The distance parameter in this map allows you to control how far from these objects the fur will begin to generate.
This map not only applies to fur, but any other texture where you want objects in the scene to control how maps are changed. Very powerful indeed!
These are simply a few examples of the ways in which fur can be adjusted and controlled. Once you begin playing with the settings, you will have a better understanding of how to control the look you are trying to achieve…and the possibilities are endless.
Happy rendering!
About TILTPIXEL: TILTPIXEL is an award-winning design studio that delivers dynamic 3D imagery, virtual reality and short films for real estate and architecture. Based in Houston, Texas, our team is both collaborative and responsive, and our deliverables reflect a strong, sophisticated design sense that enable clients to market and sell. We view innovation as the lynchpin to our success, as we continuously strive to push past stalemates, disrupt obstacles, and create stunning visualization for clients around the globe.
Ready to try Chaos products?
Start your free trial today and explore all features.
Share
Ramy Hanna
Ramy Hanna
Ramy Hanna is a Partner of TILTPIXEL and a leader in architectural visualization. With a passion for architecture, art and technology, Ramy shares his knowledge as a frequent guest speaker at conferences such as Autodesk University and Revit Technology. He has written and developed tutorial DVDs for both Gnomon Workshop and Black Spectacles, and he currently serves on the Autodesk Advisory Council. Well-connected in the industry and a master of 3D software, Ramy is instrumental in developing TILTPIXEL’s artists and growing the studio’s worldwide client base.
© Tiltpixel
@ Tiltpixel
@ Tiltpixel
@ Tiltpixel
@ Tiltpixel
