Gym assets in Enscape
Gemma Da Silva
Gemma Da Silva
Last updated: December 19, 2025  •  5 min read
Enscape Launches New Custom Asset Library With Version 2.9
This article introduces the Custom Asset Library in Enscape, a feature that lets you import and manage your own 3D assets for more tailored and realistic visualizations. Instead of relying solely on the default Enscape library, you can bring in unique objects—such as furniture, branding elements, or regional vegetation—to match real-world project needs. Supporting common formats like .gltf, .obj, and .fbx, the library also allows you to adjust materials, scale, and thumbnails for easy use. By keeping everything accessible directly within Enscape, the Custom Asset Library streamlines workflows and helps you deliver presentations that feel authentic and project-specific.
Even if we were to provide thousands more objects in
the Enscape Asset Library (and believe me, we’re working on it!), there will still be times where users need to use a specific item within their projects. This is why we’re excited to be able to officially support custom assets with the release of Enscape 2.9.
The Enscape community originally requested this feature, and thanks to pioneers like Pieter Schiettecatte, a workaround was created and shared with fellow users to allow everyone to use unique models within their designs until a fully supported custom asset library was developed.
But the wait is now over, and to get you up and running as quickly as possible with Enscape’s new Custom Asset Library, this article will provide answers to some frequently asked questions
  1. Which design software is compatible with the Custom Asset Library?
  2. How do I access the Custom Asset Library?
  3. How do I import models?
  4. Which file formats can I import?
  5. Can I import models from third-party sites?
  6. Is it possible to edit the materials of custom assets?
  7. Where will custom asset edits appear - the project, library or both?
  8. Is it possible to duplicate a custom asset?
  9. Can my team access the assets I import?
  10. Is it possible to import / export materials?
  11. Where can I find step-by-step instructions on how to use the Custom Asset Library?
  12. Can I add categories?
  13. What other features were rolled out with Enscape 2.9?
Custom Asset
Custom Asset Library: Your Questions Answered
At this timeall of the CAD and BIM design tools that we support SketchUp, Revit, Rhino, ArchiCAD, and now Vectorworks.
Firstly, you’ll need to download Enscape version 2.9 or above if you haven’t done so already.
The Custom Asset Library sits within the existing Enscape Asset Library. To access it, click on the Asset Library button in the Enscape Toolbar, or locate it via the top-level menu within your CAD / BIM software.
A new tab named Custom Assets can been seen at the top of the window:
Custom Asset Editor N
Please note, starting from Enscape 4.11, Cosmos replaces the Enscape Asset Library. Users on earlier versions of Enscape will continue to access assets via the Enscape Asset Library, but will not receive any new assets.
Open up the Asset Library window and select the Custom Assets tab. Click on the + button to start importing either single or multiple (batch) models.
The first time you click to import a single model or multiple (batch) models, you will need to set up a location for your assets. A wizard will guide you through the necessary steps to do this.
Once complete, our Asset Editor will open with the geometry and materials imported. At this time, some FBX material formats are unsupported, and you may have to assign materials manually for some models.
It is possible to import models with a file format of OBJFBX, and GLTF. It is recommended that you import low polygon models with less than 20,000 triangles (also known as 3-sided or 3-point polygons) to ensure the best performance.
Yes, you can import models from third-party sites such as SketchUp's 3D Warehouse, Free3DCGTrader, and TurboSquidas long as the 3D models are in one of our supported file formats - OBJ, FBX, and GLTF and have a poly count no greater than 20,000. However, please note that we can not guarantee that all third-party models will be compatible with Enscape.
Yes it is. You can do this by using the Materials Editor, which is located within the Custom Asset Editor in Enscape.
When you edit a custom asset, the edits made will appear in both the project itself, and in the Custom Asset Library.
At this time, it's not possible to duplicate an asset - but you can re-create one by starting a new project and importing the same geometry.
Yes. If there are valid custom assets in the defined file path, they will appear in the Custom Asset Library. So if you save the final asset to a folder on a shared network drive, every user that has access to that drive can use it. Your colleagues will need to set the source folder in the Custom Asset Library to get access to all the custom assets that are saved there.
Yes, once you are in the Enscape Custom Asset Editor, under Materials, you can right click on a material in the list to import or export a material package (*.matpkg) file.
Materials Pack
Detailed instructions and screenshots can be found in this Knowledge Base article.
A big thanks to Peter Chamberlain, a member of our Customer Success Team, who has documented everything you need to know to help you use the Custom Asset Library.
Yes you can. With Enscape 3.4 and above, it is possible to add your own categories to help you manage and organize your custom assets.
For further details on Enscape 2.9’s newest features, read our announcement post. As well as the Custom Asset Library, we also launched:
  • Video (animated) textures
  • Displacement maps
  • 175 new assets
  • 119 fitness-based assets
  • Vectorworks 2021 support
  • Offline asset library
Start creating your unique design experiences
To start creating your own unique design experiences with the new Custom Asset Library and the many other features and product enhancements that are now available with Enscape 2.9, download the latest version of Enscape today.
And if you're not yet using Enscape, try it out for free with our 14-day trial.
Try Enscape For Free
chaos logo
AI in architecture: trends, risks, & what comes next
AI in Architecture new White Paper from Chaos
Share
Gemma Da Silva
Gemma Da Silva
Gemma is part of the Content team at Chaos and loves to provide architects, designers, and 3D artists with practical tips to improve their workflows and visualizations. If you have something you'd like to share with the wider Chaos community, email blog-editor@chaos.com.
