Fabric textures for SketchUp - sofa with throw on top in modern living room with wooden flooring
Ina Iontcheva
Ina Iontcheva
Last updated: May 20, 2026  •  18 min read
Free SketchUp textures for your models
Quick summary:
  • SketchUp includes default textures in the Materials panel, but most architectural models need more. This guide covers where to find them and how to use them.
  • It lists 12 free texture sources, including Chaos Cosmos, Poly Haven, ambientCG, SketchUp Texture Club, Architextures, and more.
  • It explains the three texture types (seamless, full-cover, and procedural) and breaks down the most useful finishes across stone, concrete, metal, wood, and fabric.
  • It covers the full SketchUp texture workflow: downloading, importing, applying, extracting, editing with V-Ray, and rendering best practices.
SketchUp includes several default textures in the Materials panel, but for most architectural models, you will quickly need more.
The right SketchUp textures can enhance a furniture piece, add realism to surfaces, and bring your visual story to life. High-quality textures capture minute imperfections—wood grain, marble veining, concrete pores—that make a model feel life-like rather than computer-generated. Applied early in the design process, they also help clients visualize how specific materials will look in a space, which speeds up approvals and reduces revision cycles.
This guide covers where to find the best free seamless textures for SketchUp, how to download and import them into your models, and best practices for applying and customizing them using the Paint Bucket tool, the Materials panel, and V-Ray for SketchUp.
Table of contents:
Textured-gradient-mapping of red brick wall
Where to find free SketchUp textures
The sites below are some of the most reliable sources for free SketchUp textures— covering seamless PBR materials, photo-scanned surfaces, and parametric architectural finishes. Most require no registration and allow commercial use under CC0 or similar licenses.
  • Chaos Cosmos - The native asset library built directly into Enscape, V-Ray, and Corona. Cosmos provides ready-to-use, renderer-optimized materials that load directly into your SketchUp scene without any manual import or material setup. The fastest starting point if you are already working inside Enscape or V-Ray.
  • 3D Warehouse - SketchUp's own model repository is also one of the most underused texture sources. When viewing any model on the 3D Warehouse that contains materials you want, you can extract those materials directly without downloading the entire model. Search using keywords like 'materials,' 'textures,' or a specific finish type (flooring textures, brick textures, wood materials). Manufacturer collections are also available - companies like Formica and Certainteed publish official material packs on the 3D Warehouse with accurate product finishes.
  • Poly Haven - A curated public asset library offering 700+ high-quality free textures, 3D models, and HDRIs. No registration required. All assets are CC0. Categories include wood, floor, plaster, roofing, and terrain. One of the strongest free sources for photo-scanned PBR materials.
  • ambientCG - One of the most comprehensive free platforms for seamless PBR materials, updated regularly with new assets. Every texture comes with a full set of PBR maps — albedo, normal, roughness, AO, displacement — making it particularly well-suited for use with both Enscape and V-Ray for SketchUp.
  • Architextures - A library of parametric architectural materials - brick, concrete, wood, tile, stone, that can be customized directly in the browser (scale, color, pattern, grout width) before downloading. Available as a SketchUp extension via the Extension Warehouse, allowing you to import and apply materials directly inside SketchUp without leaving the application.
  • SketchUp Texture Club - One of the largest SketchUp-specific texture libraries available, with thousands of textures across architecture, materials, nature, and backgrounds. Free members can download 15 textures per day. A paid membership unlocks up to 50 high-resolution textures per day.
  • Share Textures - Over 1,700 textures available under CC0 license, curated by a team of architects working on archviz projects. The selection is well-suited to architectural visualization workflows.
  • CG Bookcase - 500+ PBR textures, all 100% free with no restrictions, created by Dorian Zgraggen. No registration required. Clean interface with filtering by color and resolution.
  • 3DTextures.me - Over 1,000 free seamless PBR textures with full map sets — diffuse, normal, displacement, occlusion, and roughness. Covers standard categories like fabric, wood, metal, and dirt, alongside more unusual options like lava, ice, and gems.
  • CADHatch - A smaller but well-organized collection of seamless tileable textures. Brick, stone, gravel, concrete, wood, metal, and roofing. Direct image download, no login required. A reliable source for straightforward architectural surface textures.
  • mtextur - A texture library with a dedicated SketchUp extension available via the Extension Warehouse, allowing you to browse and import textures directly inside SketchUp without downloading files manually first.
  • 3DAssets.one - Not a texture library itself, but a search engine that queries 13 of the largest free texture sites simultaneously. Useful when you need a specific finish and don't want to search each site individually.
Texture examples
When free textures aren't enough
Free libraries cover the majority of use cases, but for hero materials in close-up views, specialist finishes, or branded product surfaces, paid options are worth considering. Textures.com operates on a freemium credit system — 15 free credits per day for lower-resolution downloads, with a paid membership for higher-resolution access. Poliigon offers around 55 free textures and a paid subscription giving access to over 3,000 high-quality PBR materials. Chaos Cosmos also has an expanding number of premium assets optimized specifically for V-Ray, Corona, and Enscape workflows.
Texture categories covered
The texture sites listed above cover all major material categories used in architectural modeling and rendering. The sections below break down what to look for in each category and which types are most useful for SketchUp projects:
  • Seamless
  • Stone
  • Concrete
  • Metal
  • Wood
  • Fabric
Most sites allow you to download textures without registering for an account, typically as a JPEG or PNG image file, and sometimes compressed in a ZIP file.
V-Ray_Displacement_Material example of stone
Seamless textures
Before downloading, it is worth understanding the two types of textures you will encounter:
  • Seamless textures (also called tileable textures) repeat across a surface without visible edges or seams. Because they tile automatically, a single small image file can cover any size face, like a floor, a wall, or an entire facade. They are the standard choice for most SketchUp models and the format used by most free texture sites.
  • Full-cover textures are large image files that span an entire face without repeating. They look more custom and avoid any repetition artifacts, but require more work to apply correctly and come with larger file sizes.
For most SketchUp modeling workflows, seamless textures are the right choice — they are optimized for performance, easy to scale and rotate via the Materials panel, and work directly with the Paint Bucket tool without any additional setup.
To find free seamless textures, visit resources like Poly Haven and 3DTextures. These websites offer high-quality textures available to download individually or as ZIP files. They cover all major material categories, including stone, concrete, metal, wood, and fabric.
Procedural textures
Beyond seamless and full-cover textures, there is a third type increasingly used in architectural workflows — procedural or parametric textures.
Unlike standard image files, procedural textures are generated algorithmically rather than photographed or painted. This means they can be adjusted, things like the scale, color, pattern, grout width, joint spacing, without any loss of quality at any resolution. Because they are not tied to a fixed image file, they never pixelate, never tile visibly, and can be customized to match exact real-world material specifications.
Architextures is the most practical example for SketchUp users — it offers a library of parametric architectural materials (brick, concrete, wood, tile, stone) that can be customized directly in the browser and imported into SketchUp via the Architextures extension, available in the SketchUp Extension Warehouse. Each material can be adjusted for scale, color, and pattern before importing, making it particularly useful when you need a texture to match a specific product or specification rather than a generic finish.
Stone textures
Stone is one of the most widely used material categories in architectural models — from marble flooring and granite worktops to limestone facades and sandstone cladding. Free seamless stone textures are available across most major texture sites and cover the full range of architectural applications.
Common types to look for:
  • Marble: smooth surface with intricate veining; ranges from white to gray, beige, or vibrant colors; ideal for floors, walls, and high-end interior surfaces.
  • Granite: granular appearance with mixed mineral grains; available in black, gray, pink, or brown; used for worktops, paving, and exterior cladding.
  • Limestone: porous and sedimentary appearance in light beige to gray tones; commonly used for facades, cliffs, and heritage structures.
  • Sandstone: grainy, compacted surface in yellow, red, brown, or gray; frequently used for desert landscapes, canyon environments, and historical buildings.
Concrete textures
Concrete is a staple of architectural and industrial modeling — from raw exposed walls and brutalist facades to polished floors and stamped driveways. Free seamless concrete textures are widely available and cover a broad range of finishes suited to both interior and exterior SketchUp models.
  • Smooth concrete: sleek, uniform surface associated with modern architecture; no visible imperfections or texture variation.
  • Rough concrete: coarse, uneven surface with visible aggregate or small cracks; adds realism and character to weathered or aged structures.
  • Exposed aggregate: stones or pebbles embedded in the surface; textured finish commonly used for sidewalks, driveways, and outdoor applications.
  • Stamped concrete: patterns imprinted onto the surface to mimic brick, tile, or wood; versatile and customizable for a range of aesthetic effects.
Metal textures
Metal textures are essential for both architectural and furniture modeling, covering everything from structural steel and industrial facades to sleek interior fixtures and decorative elements. Free seamless metal textures are widely available and work well across a broad range of SketchUp models.
  • Brushed metal: fine parallel lines or scratches giving a distinctive linear pattern and matte appearance; associated with modern and industrial aesthetics.
  • Polished metal: smooth, mirror-like reflective surface; commonly used to depict stainless steel or chrome finishes in high-end interiors.
  • Rustic metal: weathered and aged look with rust, patina, or corrosion; adds character and history to vintage or industrial design styles.
  • Perforated metal: pattern of small holes across the surface; used for architectural screens, facades, and decorative elements where light and shadow effects matter.
Metal nut cracker
Wood textures
Wood is one of the most versatile material categories in SketchUp. It's often used for floors, ceilings, furniture, cladding, and structural elements across a wide range of interior and exterior architectural models. Free seamless wood textures are available across most major texture sites, with Poly Haven offering a particularly strong selection.
  • Oak: prominent grain pattern with distinctive rays and knots; ranges from light to dark shades; versatile across traditional and contemporary design styles.
  • Mahogany: rich reddish-brown color with straight or interlocking grain; associated with high-end furniture and architectural elements.
  • Walnut: brown tones from light to dark chocolate with straight or wavy grain and occasional knots; commonly used for furniture and cabinetry.
  • Pine: lighter color with straight grain ranging from pale yellow to light brown; suits country, cottage, and rustic architectural styles.
Fabric textures
Fabric textures are essential for interior modeling, adding warmth, depth, and tactile realism to upholstery, curtains, cushions, and soft furnishings in SketchUp models. For higher-quality downloads, visit Poly Haven or SketchUp Texture Club, both of which offer fabric textures in multiple resolutions compatible with SketchUp.
  • Cotton: soft, breathable appearance; commonly used for upholstery, curtains, and bedding; brings a cosy and inviting feel to interior spaces.
  • Velvet: rich, smooth surface with a distinctive sheen; used for upholstery, draperies, and cushions; adds sophistication and glamour to interior designs.
  • Linen: relaxed, natural look with a distinctive weave pattern; ideal for curtains, tablecloths, and casual upholstery; suits airy and informal interiors.
  • Silk: lustrous, smooth surface associated with luxury and refinement; adds elegance and visual impact to high-end interior spaces.
Fabric texture examples with grey sofa and beige throw and light wooden floors
How to download and import the textures into SketchUp
Once you have found a texture you want to use, download the image file (it will typically be in JPEG or PNG format, sometimes compressed in a ZIP file). Save it to a location on your hard drive that is easy to find.
To import and apply the texture in SketchUp:
  1. Go to Window > Materials in the menu bar to open the Materials panel.
  2. Click the Create Material button. A dialog box will appear.
  3. Click the folder icon next to the Color option to open a file browser.
  4. Navigate to the folder where you saved the downloaded image file, select it, and click Open to import it as a new material.
  5. Select the Paint Bucket tool from the toolbar - the Materials panel will appear with your new material selected. To sample an existing material already applied in your model, hold Alt (Windows) or Command (Mac) while the Paint Bucket is active to switch to the Eyedropper tool, then click on any face to pick up that material.
  6. Click on any face in your SketchUp model to apply the material.
  7. Adjust scale, rotation, or other properties as needed directly in the Materials panel.
Alternatively, the quick 3-step method:
  1. Open the Colors panel and select the Textures Palette tab (the brick icon).
  2. Choose the collection where you want the texture stored from the drop-down menu.
  3. Select Color > New Texture, browse to your image file, and apply it directly.
A note on PBR maps
Many texture sites provide multiple map files per texture rather than a single image. For basic SketchUp use, you only need the albedo / diffuse map. This is the base color image that defines how the surface looks. If you are using V-Ray for SketchUp, you can assign the additional PBR maps in the V-Ray Asset Editor to achieve more realistic results:
  • Normal map: simulates surface depth and detail without adding geometry.
  • Roughness map: controls how sharp or blurred reflections appear.
  • Metalness map: defines which parts of a surface behave as metal vs non-metal, affecting how reflections and light interact with the material.
  • Ambient Occlusion (AO) map: adds subtle shadowing in crevices and contact areas.
  • Displacement map: creates actual geometric depth (use sparingly in real-time workflows).
Stone floor, leather armhair, blue rug, wooden side unit - examples of textures
How to extract and export textures from a SketchUp model
If you find a material already applied in a SketchUp model, whether from the 3D Warehouse or a project file a colleague shared, you can extract and save it as an image file to reuse in other projects.
To export a texture from SketchUp:
  2. Click the Home icon or select In Model from the drop-down menu to view all the materials currently applied in your model.
  3. Right-click on the texture you want to export using the Select tool.
  4. Select Export Texture Image from the context menu.
  5. Choose a folder on your hard drive to save the image file and click Save.
The exported image file can then be imported into any other SketchUp model as a new material, or opened in Photoshop for further editing before reimporting.
Generating textures with AI inside SketchUp
SketchUp now includes a built-in AI texture generation feature, Generate Textures, that can transform a basic material into a more detailed, photoreal surface without leaving the application. Rather than downloading and importing an external image file, you describe the material you need, and the AI generates a texture directly inside SketchUp. This is particularly useful for bespoke or unusual finishes that are difficult to find on standard texture sites. The feature is available in SketchUp's Materials panel. Look for the Generate Textures option when creating or editing a material.
Licensing information
Always check the license before using any free texture in a client project. The most common license types you will encounter are:
  • CC0 (Creative Commons Zero): no restrictions; free to download, modify, and use commercially without attribution.
  • CC BY (Attribution): free to use commercially, but requires you to credit the original creator.
  • Royalty-free: free to use in projects without ongoing fees, but may restrict redistribution or resale of the texture files themselves.
  • Non-commercial only: free for personal use but not for client or commercial projects.
Licensing terms can change, so always check the specific information on the download page before using any image file in your projects.
Best practices for applying and using textures in SketchUp
Applying textures accurately
  • Scale: adjust the texture scale in the Materials panel to match real-world surface dimensions. A floor tile that is 60×60cm in reality should be set to those dimensions in the material settings.
  • Rotation: experiment with rotating the texture to achieve the right look, particularly useful for diagonal or irregular patterns.
  • Material opacity: use the material's opacity setting to blend textures with underlying surfaces for more natural-looking results.
  • Texture mapping plugins: explore extensions available in the SketchUp Extension Warehouse for advanced texture mapping and precise UV control.
  • Right-click to edit: to reposition a texture already applied to a face, right-click on the face using the Select tool and choose Texture > Position from the context menu.
Apply materials inside groups
Applying a material to the outside of a group or component makes it difficult to adjust the position or orientation of the grain later. Always enter the group before applying the material to maintain full control over texture positioning.
Global material updates
Any changes made to a material in SketchUp automatically update all faces painted with that material across the entire model. This makes it efficient to experiment with different finishes — change the material once, and the entire model updates instantly.
min-How_to_edit_and_customize_your_textures_in_SketchUp
Keeping your model performing at its best
  • Resolution: use 2K textures for real-time workflows and most SketchUp modeling. Reserve 4K for close-up hero materials. Avoid 8K unless absolutely necessary as it significantly impacts performance.
  • UV mapping: ensure UV mapping is done correctly to avoid texture stretching or distortion. Use UV mapping tools to adjust and optimize the UV layout.
  • Avoid tiling artifacts: when using seamless textures, check seams carefully where the texture repeats. Adjust UV mapping or use texture blending to minimize visible repetition.
  • Manage materials: use the Materials panel regularly to clear out unused materials from your model. Keeping all the materials organized reduces file size and improves performance.
  • Save regularly: save your SketchUp model regularly to preserve applied textures and avoid losing material assignments.
How to edit and customize your textures in SketchUp
Once a texture is applied to your SketchUp model, the V-Ray Asset Editor gives you precise control over how it looks and behaves — going well beyond what the standard Materials panel offers.
To access it:
  1. In the menu bar go to Extensions > V-Ray to open the V-Ray toolbar.
  2. Click the Asset Editor button.
  3. Navigate to the Materials tab and select the material you want to edit.
From the Material Editor section, you can adjust the following texture properties:
  • Color corrections: use the Mix Color option to blend a color on top of the texture or mix two textures together for layered material effects.
  • Value (transparency) blend: adjust the material's opacity using the Value Blend option to control how transparent or opaque the texture appears.
  • Pattern randomness: adjust UVW placement to add randomness to texture tiling, creating a more natural and varied appearance across large surfaces.
  • Curve modifier: adjust brightness, contrast, and other properties using a curve graph for precise tonal control over the texture.
Once you have made your adjustments, click Apply to update the material in your SketchUp model.
Rendering of a minimalist bedroom with blue bedding and large window.
Chaos 3D Team
Showcasing your SketchUp models with V-Ray
Once your textures are applied, V-Ray for SketchUp gives you the tools to present them at their best. A few things to focus on:
  • Lighting: use V-Ray's area lights, HDRI maps, and light portals to create the right mood and bring out texture detail. The more materials in your scene, the more important the lighting setup becomes.
  • Material properties: in the V-Ray Asset Editor, experiment with glossiness, roughness, reflection, and bump maps to push textures toward photorealism. PBR maps included with your downloaded textures plug directly into these slots.
  • UVW randomizer: use V-Ray's UVW randomizer to add variation across repeated texture tiles, preventing the uniform repetition that makes large surfaces look artificial.
  • Post-processing: after rendering, use Photoshop or a similar image editing tool to adjust colors, contrast, and compositing. Blending multiple V-Ray render passes together gives a more polished final result.
Conclusion
From free seamless textures and PBR maps to V-Ray material editing and rendering best practices, you now have everything you need to find, import, and get the most out of SketchUp textures in your projects. Start with the texture banks listed in this guide, check the license before downloading, and use the Paint Bucket tool and Materials panel to apply and adjust textures directly in your model.
Key takeaways
  • Seamless textures are the standard choice for most SketchUp models — they tile automatically across any surface without visible seams.
  • Procedural textures (like Architextures) can be customized for scale, color, and pattern before importing — useful when you need to match a specific product or specification.
  • For basic SketchUp use, you only need the albedo/diffuse map. Additional PBR maps (normal, roughness, AO, displacement) unlock more realism when using V-Ray.
  • Always check the license before using any texture in a client project. CC0 allows commercial use freely, while CC BY requires attribution.
  • Use 2K textures for real-time workflows; reserve 4K for close-up hero materials; avoid 8K unless absolutely necessary.
  • The V-Ray Asset Editor gives you precise control over color, opacity, pattern randomness, and tonal curves — going well beyond what the standard Materials panel offers.
  • SketchUp's built-in Generate Textures AI feature can create photoreal materials directly inside the application for finishes that are hard to find online.
FAQs
What is the difference between a SketchUp material and a V-Ray material?
A standard SketchUp material is a basic image file — color and texture — applied through the Materials panel. It controls how a surface looks in SketchUp's native viewport. A V-Ray material goes further, using PBR maps to simulate how a surface physically responds to light — reflections, roughness, bumps, translucency. For design reviews, SketchUp materials are sufficient. For photorealistic renders, V-Ray materials give you the control and quality you need.
Why do my textures look stretched or blurry in SketchUp?
Stretching is almost always a UV mapping problem — the texture scale doesn't match the real-world dimensions of the surface. Fix it by right-clicking the face, selecting Texture > Position, and adjusting the scale to match reality (for example, a 60×60cm tile should be set to those dimensions). Blurriness is usually caused by a low-resolution texture — switch to a 2K or 4K image file for sharper results.
How do I optimize texture resolution in SketchUp without losing visual quality?
Use 2K textures for most SketchUp modeling and real-time workflows - they deliver good visual quality with minimal performance impact. Reserve 4K for close-up hero materials where fine detail matters. Avoid 8K unless absolutely necessary, as it significantly impacts performance. Also, clear unused materials regularly via the Materials panel. Orphaned textures consume memory even when not visible in the scene.
What impact do 8K textures have on SketchUp model performance and file size?
8K textures contain 16 times more pixel data than 2K, significantly increasing RAM usage, file size, and rendering times. In complex scenes with multiple 8K textures, SketchUp navigation slows noticeably. Unless producing extreme close-up hero shots where fine surface detail is critical, 2K delivers comparable visual quality with a fraction of the performance cost.
How do I fix texture stretching on curved or organic surfaces in SketchUp?
Curved surfaces stretch textures because SketchUp maps them differently than flat faces. Right-click the face, select Texture > Position, and switch to Projected mapping mode — this wraps the texture more accurately around the curve. For complex organic geometry, a UV mapping extension from the SketchUp Extension Warehouse gives you precise control over how the texture follows the surface.
Are there any legal requirements for using CC0 textures in commercial architectural renderings?
CC0 textures carry no legal restrictions — no attribution, no commercial use limitations, no restrictions on modification. You can use them freely in client deliverables, planning submissions, and published renders without additional permissions. Always verify the license on the specific asset's download page, as some sites incorrectly label textures as CC0 when the actual terms differ.
How should I optimize SketchUp textures for real-time rendering in Enscape?
Use 2K textures for most surfaces to keep performance smooth. Assign PBR maps via the Enscape Material Editor rather than relying on SketchUp's native material settings — Enscape renders these with full physical accuracy. Use the Material Editor's roughness and reflectance sliders to fine-tune how each surface responds to light in the real-time view.
Ready to try Chaos products?
Start your free trial today and explore all features.
Share
Ina Iontcheva
Ina Iontcheva
Ina is a Content Marketing Manager at Chaos with a great passion for writing and the visual arts. She finds inspiration in exploring the way textures and shapes interact with each other in space.
Texture examples
Metal nut cracker
Chaos 3D Team
