The new, unified Chaos Forum is now live.
Join the conversation!
Han Shilin
Han Shilin
Last updated: December 19, 2025  •  4 min read
How to render an architectural scale model in V-Ray for SketchUp
Summary:
  • Photo compositing in V-Ray for SketchUp allows seamless integration of SketchUp models with real-life site photos, enhancing realism and flexibility for architectural renderings.
  • Matching the camera and light in SketchUp with a backplate photo is crucial for achieving realistic renderings, requiring careful attention to light direction, color, and perspective.
  • Using V-Ray's Material Library and effects like Depth of Field and Lens Effects can significantly enhance the realism and visual appeal of architectural renderings.
  • Han Shilin, a V-Ray expert, provides tutorials and tips on using V-Ray for SketchUp, sharing his knowledge with a large audience through various platforms.
With V-Ray for SketchUp, it’s easy to match your designs to a backplate and create realistic architectural renderings. V-Ray expert Han Shilin shows you how.
There’s something about a scale model that makes it easy to communicate an architectural concept. And the trick is: it can be a real-world physical model, a 3D architectural rendering, or a combination of both.
In this tutorial, I will show you how to use photo compositing in V-Ray for SketchUp to seamlessly integrate your SketchUp model with a photo of a real-life site study model. The resulting image looks just as good as the real thing, with the advantage that you can quickly tweak and re-render the shot if you need to make changes.
You can also use these techniques elsewhere: For instance, to add a full-scale architectural model to an on-site photograph or to integrate an object with a real-world setting.
About Han Shilin
Han is a long-time user of V-Ray for SketchUp and a blog writer based in Tianjin, China. He has been sharing his experiences along with best-practice tips and tricks for V-Ray for SketchUp since 2012. He regularly updates his Bilibili channel with video tutorials and has over 60,000 subscribers following his lessons. Han joined Chaos Group in 2019, where he continues to share his knowledge and information about V-Ray with Chinese users.
1. Take a backplate photo and match the camera
Take a picture of your handmade site study model. Make sure you note the color and direction of the on-site light source.
Architectural scale model with small buildings, pathways, and trees arranged around an open central space, illuminated by soft lighting
Han's original photo
Create a new file in SketchUp. In the Camera menu, choose “Match new photo...” then select the backplate photo.
Drag the origin point (yellow square) to one corner of the site model. The red and green parallel lines control the direction of the perspective line. Just remember that the red, green, and blue axes are perpendicular to one other.
Click the “Done” button after photo matching.
Do not forget to set the output aspect ratio to match the backplate photo (This example is 4:3):
2. Match the light
First, we need to draw a large plane surface to form the ground. To do this, we can simply put an infinite plane at the origin point of the scene. Make sure the normal direction of the infinite plane (the blue arrow) is facing upwards.
SketchUp Pro 2017 interface showing an architectural model with the Infinite Plane tool highlighted in the toolbar and the Default Tray options open on the right.
The next step is important. Try to recreate the digital light to match the direction, color and brightness of the real light source.
Don’t forget to turn off the default sunlight and the sky texture:
V-Ray Asset Editor interface showing lighting settings with SunLight selected on the left and render environment options on the right, including background, GI, reflection, and refraction controls.
In this scene, the key light is obviously coming from the upper right corner — you can tell this by observing the shadow of the tree or the buildings around the site.
So just draw a block for reference, then put a V-Ray light on top right of the block.
SketchUp Pro 2017 interface showing a matched photo view with a rectangular 3D model aligned to the scene on the left, and a parallel view of the same object with axis guides on the right.
Go back to the render camera and test. Adjust the Camera EV and light color:
V-Ray Asset Editor interface showing camera exposure settings with Exposure Value (EV) highlighted on the left, and light settings with a rectangle light and color picker window open on the right.
The result should look like the image below:
SketchUp Pro 2017 interface showing a matched photo view with a rectangular 3D model, alongside the V-Ray frame buffer window displaying a rendered image of the same model with lighting and shadows.
We can fine-tune the V-Ray light in the next step.
How to use Cryptomatte render elements in V-Ray for SketchUp
Follow my other step-by-step tutorial to find out how to use Cryptomatte Render Elements in V-Ray Next for SketchUp, plus how to composite and color-correct your render layers.
3. Shadow catcher
In the Material Library > Diagrammatic, we can find a "Matte Shadow Receiver". Apply this material to the infinite plane.
V-Ray Asset Editor interface showing the materials library with the Diagrammatic category highlighted and the Matte Shadow Receiver material selected for application.
In the V-Ray frame buffer, choose Color correction> Background, check “Background image” and load the backplate photo. Now you can see the final composition and fine-tune the light and exposure values. You can even add more fill lights to match the backplate, depending on your scene:
V-Ray Asset Editor interface showing render settings with background image options, displayed alongside a 3D architectural model preview.
Note: If using the GPU engine, make sure the shadows are based on a Dome Light or other direct light sources instead of the Environment illumination.
4. Discover the preset Material library
Now, we can delete the reference block and replace it with our designed model.
If the size does not match the background, click the gear icon and drag the axis to match the photo:
SketchUp Pro 2017 interface showing a matched photo background with an overlaid 3D model of a detailed house structure, including roof framing and human figures for scale.
V-Ray Next for SketchUp has a very user-friendly Material Library.
In the Diagrammatic and Plastic categories you can find many material presets that are suitable for physical model renders.
Applying a sub-surface scattering material to the wall and putting a light source behind can achieve particularly good-looking effects:
V-Ray render of a modern glass-walled building with interior lighting, outdoor seating area, and structural roof framing visible.
5. Depth of field and lens effects
These two effects are critical in conveying the look of a physical model.
Depth of field gives the correct sense of scale. Turn on the depth of field switch then pick a focal point on the model. Now, set the Defocus amount depending on your scene.
SketchUp Pro 2017 interface with a house model overlay, showing V-Ray Asset Editor camera settings on the right, where Depth of Field is enabled and focus point selected on the model.
Similarly, Lens Effects will increase the realism of the picture.
Click the lens effect icon at the bottom of the VFB and enable the Bloom/Glare effect.
I use a threshold to control which pixel can produce the glare effect. In this example, it is the highlight on the tree.
Then I boost up the intensity to make this effect more prominent.
V-Ray frame buffer showing a rendered scene of a modern glass-walled building with warm interior lighting, surrounded by outdoor elements, while bloom and glare effect settings are displayed on the left panel
If you are satisfied with the result, do not forget to check the “Save in image” in the Background panel and save the image.
V-Ray frame buffer showing a rendered scene of a modern glass-walled building with interior lighting, alongside render settings panel where the option to save the background image in the output is selected
chaos logo
Report: How AI is reshaping design & visualization in 2026
How AI is reshaping architectural design and visualization in 2026 new report from Chaos and Architizer
Share
Han Shilin
Han Shilin
