Matteo Schiavone
Matteo Schiavone
Last updated: September 09, 2026  •  4 min read
How the 2026 Luxury Real Estate Market is Shaping Workflows for 3D Artists and Studios
The luxury real estate visualization workflow has undergone a shift, moving 3D artists and studios from the very end of the development pipeline to the very beginning. Architect, 3D Artist, and CTO Matteo Schiavone shares how this elevates 3D artists from mere production hands to invaluable, strategic design partners.
Key takeaways:
  • The visualization brief has moved up the timeline, requiring 3D artists to engage with projects during early-stage conceptualization rather than after the design is finalized.
  • 3D rendering is no longer treated as a marketing afterthought; instead, it is actively utilized as an essential tool throughout the collaborative design process.
  • Visualizers who adapt to this collaborative reality transition from commodity image makers to indispensable strategic partners, significantly increasing their market value.
A few years ago, a visualization brief for a luxury real-estate project looked quite predictable.
The architectural BIM file was provided. The materials were all specified. Our team's job was to take a finished design and make it look amazing. The renders came at the end of the process, images for the marketing team to sell the property.
That's no longer where the brief starts nowadays. At the high-end of the real estate market, the brief now arrives earlier and way differently than it used to be.
Chaos rendering of a luxury atrium restaurant with skylight, mature tree, and cascading greenery.
Courtesy of Render Atelier
The new scenario
Open a typical brief from a developer today, and you'll find things that, a few years ago, would have been settled by the architect or the interior designer's internal visual team long before a high-end visualization studio got involved, just a few examples:
  • Material specs that aren't fully specified, a request to explore how several finishes feel in the same space, with the understanding that the chosen direction will inform what will actually be selected.
  • Lighting specs referenced against other projects entirely, "something like the lobby of [another completely different project], but warmer and brighter," where the lighting design itself is still being worked out.
Why is this happening?
Two things are driving it.
First, developers in this segment have realized that the cost of getting a project wrong late is much higher than the cost of exploring it early. A render that looks good, done in-house, but unrealistic when built and being approved by their client, in context, that's an expensive mistake to discover after construction. Running it through an expert visualization studio first, while it's still a decision rather than a commitment, is way cheaper.
Then there is another point. Buyers at this level have a frame of reference that didn't exist for most markets a decade ago. They've experienced ultra-luxury developments in Dubai, London, New York, and the growing luxury markets like India. They expect the properties they're considering to meet the same standard before a single wall is built, and the pressure is on the developers, who can’t possibly have the in-house resources to provide those visuals.
Chaos rendering of a modern residential tower among Dubai skyline skyscrapers at dusk.
What does it mean for your workflow?
If you're used to building a workflow around a specific locked-down set of files, this kind of brief will break that workflow unless you restructure it around iteration from the start. Here are a few points that have helped us over the past years:
1. Build scenes in layers that can be easily edited
If a client wants to compare three lighting moods or four material directions in the same space, you don't want to rebuild the scene each time. Set up your base scene and composition first, and treat lighting and material sets as swappable layers.
In V-Ray or Corona, this means also thinking early about how your scene is organized: lightmix layers, render elements, and material IDs that let you adjust specific sections of the image quickly in post.
2. Front-load cost exploration
Early in such a low-brief-led project, the goal isn't a final quality image; it's a fast output that lets the client and their team make a call. Lower the samples, set smaller resolutions with higher denoiser values, and simplify the placeholder geometry. Save the full render budget for the direction that survives this round.
3. Treat the brief as a conversation
When the brief includes references to other projects and is very generic, the most important thing you can do at this stage is push back gently and ask for more directions, not because the openness is a problem, you would think for a 3D artist there is nothing more exciting than exploring a blank canvas of course, but you need to realize that this is not about your idea but translating the client vision.
Chaos rendering of a luxury classical living room with crystal chandelier, marble floor, and city view.
4. Keep the versions traceable
When a client is using renders to make design decisions, they will come back to earlier options sometimes weeks later, after internal discussions you weren't part of. A clear versioning system for scenes, incremental saves, or material variants stored to material libraries can all save significant time when "can we go back to option two, but with the lighting from option four" inevitably comes up.
5. Evolve to real time
Consider Vantage in your pipeline, which is now well integrated and solid for production work and can drastically reduce render time with almost no effort. Being able to cut down rendering time without thinking of how to export and convert the file was really a big change for us, especially in animations, but also for simpler projects due to the advantage the interactivity gave us.
The takeaway
This shift is, on balance, good news for visualization artists working at the high end of the real estate market. It means the work is being taken as part of the design process, not treated as a marketing afterthought. But it does mean rethinking how a project is structured from day one, building for iteration rather than for a single final output, and budgeting time for the brief itself to evolve.
The studios that adapt their workflows to this reality won't just produce better images; they'll become part of how their clients design, which is a very different and considerably more valuable.
Ready to try Chaos products?
Start your free trial today and explore all features.
Share
Matteo Schiavone
Matteo Schiavone
Matteo is an Architect and 3D Artist with over 15 years of experience in the visualization industry, specializing in large-scale exteriors and animations. Since 2017, he has been CTO and Partner at Render Atelier Ltd, an international archviz studio based in the UK and Dubai, coordinating a team of more than 20 artists while working directly on the studio's key projects.
