V-Ray render of woven striped and geometric-pattern cushions on a tufted leather sofa, showing realistic fabric texture.
Ana Savova
Ana Savova
Published: November 23, 2026  •  13 min read
Why Rendered Materials Look Fake and What PBR Does About It
Physically based rendering (PBR) helps create realistic materials by describing how surfaces respond to light. But incorrect material settings can still make concrete look like plastic, glass appear overly reflective, or metal surfaces look unnatural. This article explains what each PBR parameter controls, why certain combinations produce unrealistic results, and how to correct common material problems in architectural visualization.
Key takeaways:
  • PBR material failures are often combinations of small errors — inaccurate albedo, uniform roughness, incorrectly scaled normal maps, or unsuitable reflection settings — rather than one wrong parameter.
  • Metalness is a material classification. Painted and powder-coated metals generally behave as dielectrics, while exposed metals require metallic shading. Anodized aluminum needs additional consideration depending on its finish.
  • Albedo should contain no unwanted baked lighting. Using photographs with existing shadows and highlights can produce muddy or inconsistent results.
  • Roughness controls the spread of reflections, while F0 and IOR influence reflectance. Glass with an IOR of approximately 1.5 reflects around 4% of incident light at normal incidence and considerably more at oblique angles.
  • Understand whether your renderer uses a metalness or specular workflow. Transferring texture maps between workflows without the correct interpretation can produce unrealistic material appearances.
Flat concrete that reads as grey plastic. Glass that mirrors like polished steel no matter the angle. Metal that looks chalky or wrong-colored. This article breaks down what each physically based rendering (PBR) parameter actually controls, which parameter combinations produce these failures, and how to correct them on the architectural surfaces you render every day.
When the problem is in the material, not the lighting
You render a glazed facade. The light is right. The sun angle is right. The glass still reads like a sheet of chrome. You tune the HDRI. You move the sun. Nothing seems to correct the surface.
The problem may lie in the material. Concrete that looks like injection-molded plastic, aluminum window frames with highlights that shift the wrong color, stone floors with no depth at the pores — these can all be material parameter problems. The surface is not responding to light in the way the real material would.
PBR governs that relationship. Get the parameters wrong, and the material misrepresents the light it receives. By the end of this article, you will know what each parameter controls, what incorrect values produce, and how to correct them for concrete, glazing, and metal specifically.
What physically based rendering actually means
PBR is a shading approach built on physical laws: reflection, refraction, and energy conservation. It is not a style setting or a quality preset. It describes how a surface responds to light based on measurable properties.
One distinction matters here. PBR is physically plausible, not necessarily physically exact. It uses practical approximations that produce convincing results without simulating every aspect of light transport at the microscopic level. That trade-off is deliberate, and it holds up on building-scale surfaces.
At the center sits the BRDF, the bidirectional reflectance distribution function. The BRDF describes how a surface reflects light based on incoming and outgoing directions. Modern PBR commonly uses microfacet BRDFs, including the GGX model, to simulate how surface roughness controls the shape and distribution of highlights. V-Ray supports GGX through its material shading controls.
Energy conservation is the rule that stops materials from misreporting light
A surface cannot reflect more light than it receives. In physically based shading, diffuse and specular reflection must be balanced so that the total reflected energy does not exceed the incoming energy.
PBR shading models account for this constraint. Some older, non-physically based shaders allowed diffuse and specular contributions to be combined in ways that produced unrealistically bright surfaces.
Physically based shading helps avoid these inconsistencies, but switching to a PBR material does not automatically remove the plastic look. The material still needs correctly configured properties and textures.
V-Ray render of draped fabric samples in gray, brown, white and pale blue, showing knit, weave and lace textures.
The parameter set: what each channel actually controls
Each PBR channel maps to a physical property. Learn what the property is, not just what the slider is named.
Albedo is the base color with no light baked in
For opaque non-metallic materials, albedo is the diffuse, unlit base color. Picture the surface under even white illumination, without directional highlights or shadows. That underlying color is what the albedo map should represent.
The albedo map should contain no unwanted baked shadows, painted highlights, or darkened edges caused by lighting. Those effects belong in the rendering process.
Pull a photo of concrete directly into your albedo channel, and you may introduce existing lighting information into a system that adds its own lighting on top. The result can look muddy or inconsistently lit.
This is a common mistake with texture in architectural visualization.
Roughness controls the spread of the highlight, not its strength
Roughness controls the microfacet distribution on the surface. It describes how varied the microscopic surface orientations are.
High roughness spreads reflected light into broad, soft highlights. Low roughness produces tight, sharp specular reflections.
In common PBR workflows, glossiness equals 1 minus roughness. Both describe related surface properties using inverted scales. Some renderers expose one, some the other. V-Ray lets you switch between them through its roughness and glossiness controls. Treat them as two ways of describing the same surface behavior.
Roughness primarily controls the distribution of reflected light, not the underlying reflectance at normal incidence. That depends on properties such as F0 and index of refraction (IOR) for dielectric materials.
Polished wood can be very smooth and still reflect much less light at normal incidence than a metal. Brushed metal can be rough and still reflect strongly overall.
Metalness is a classification, not a slider
Metalness is a material classification in the metalness and roughness workflow. It is not a continuous aesthetic control.
Conductors — metals — generally have no diffuse reflection component and produce colored specular reflections.
Dielectrics — concrete, wood, stone, paint, and glass — produce largely neutral specular reflections. Opaque dielectrics also have a diffuse component, while transparent dielectrics such as glass transmit light.
Set metalness to 0.0 for non-metals and 1.0 for exposed metals. Intermediate values do not generally represent homogeneous physical materials, although they can appear in texture maps at transitions between metallic and non-metallic regions.
A common architectural visualization mistake is using metallic shading for painted or powder-coated metal surfaces. These coatings generally behave as dielectrics because light interacts primarily with the coating rather than the metal beneath it.
Anodized aluminum is more complex. Its appearance depends on the oxide layer, the coloring process, the surface finish, and the underlying aluminum. It should not automatically be treated as identical to painted metal.
V-Ray render of metallic objects including silver, copper and gunmetal bottles, a brass grinder and engraved tray and lantern.
F0 and IOR decide how much light reflects
F0 is specular reflectance at normal incidence. It describes how much light a surface reflects when viewed directly along its normal.
For many common non-metallic architectural materials, F0 falls between approximately 0.02 and 0.08. That means around 2% to 8% of incident light is reflected at normal incidence, depending on the material.
For dielectric materials, IOR determines F0 mathematically. Typical clear glass has an IOR around 1.5, corresponding to F0 of approximately 0.04 at an air–glass interface.
IOR is especially important for transparent materials. Glazing and water get their refraction behavior and Fresnel reflection characteristics from it.
Set IOR incorrectly on architectural glass, and its reflections can appear physically inconsistent, particularly at oblique viewing angles.
V-Ray normally ties Fresnel IOR to refraction IOR, although these controls can be separated where supported for additional artistic control.
For metallic materials, reflectance is represented differently, and the dielectric IOR relationship does not apply in the same way.
Why architectural materials fail: a diagnostic breakdown
Material failures in architectural visualization are rarely caused by one wrong parameter. They are often combinations of small errors.
Slightly inaccurate albedo. Uniform low roughness. A normal map scaled incorrectly. Reflection settings that do not match the actual material.
Each looks minor. Together they make a surface read as fake.
Working artists encounter this pattern constantly. Understanding how the parameters interact is the difference between knowing the theory of PBR and being able to apply it effectively.
Here is how it plays out on three surfaces you render every day.
Concrete
Wrong output: A flat grey panel with no surface variation that reads as smooth plastic, not a cast mineral surface.
The causes stack. Albedo is a single flat grey instead of a spatially varied value. Roughness is one low number instead of a textured map. The normal map is absent, scaled too small, or scaled so large that it reads as structural damage rather than microstructure.
Correct direction: Albedo should reflect the natural color variation of the concrete surface. Roughness should generally be high for unfinished concrete — around 0.7 to 0.9 can be a useful starting range on a conventional 0–1 scale, with lower values for polished finishes.
These ranges are practical starting points, not calibrated measurements. Adjust them according to the actual material and renderer.
Use a roughness map rather than a flat value where the finish has visible variation.
Calibrate normal-map intensity and texture scale so that pore detail reads at a believable physical size. Use displacement when more pronounced geometric depth is required.
Ambient occlusion (AO) can reinforce contact shading in certain workflows, but it is not a required PBR material property or a substitute for accurate surface detail and lighting.
One more trap: mix maps from different texture sources, and they may no longer describe the same microstructure. The result will fight itself.
Structural glazing
Wrong output: Glass that mirrors like solid metal at every angle, or glass that is uniformly transparent with no visible surface reflection.
These problems can result from incorrect IOR, reflection, refraction, or material geometry.
View a pane straight on and real glass reflects about 4% of incident light at an air–glass interface. Turn toward an oblique angle and Fresnel behavior becomes increasingly visible. Reflectance climbs sharply as the viewing angle approaches grazing incidence.
Set IOR incorrectly and that Fresnel relationship changes. The pane may stop behaving like the glass you are trying to represent.
However, IOR is not the only consideration. Glass thickness, tint, transmission settings, and the surrounding environment also affect its appearance.
Frosted glass requires control over how light is transmitted through the material, not simply a change to its albedo.
In V-Ray, refraction glossiness can be adjusted to blur objects seen through the glass, while reflection roughness or glossiness controls the appearance of surface reflections.
Laminated glazing may require additional material considerations depending on its construction and finish. It should not automatically be treated as frosted glass.
Faking frosted glass with a light-colored albedo on an opaque surface is a quick shortcut, but it will not reproduce the correct transmission behavior.
Anodized aluminum and painted metal
Wrong output: A metallic-looking surface with color-shifted reflections, odd highlights that fight the surface color, or a washed-out, chalky finish.
One possible cause is an incorrect metalness setting.
Painted and powder-coated steel has dielectric coatings on a metal substrate. Light interacts primarily with the paint or coating, not the steel underneath.
Set metalness to 1.0 for an opaque painted surface, and you remove the diffuse component expected from the coating. The result can produce colored specular reflections that do not match the intended finish.
Anodized aluminum requires more careful treatment. Although its oxide layer is non-metallic, the underlying aluminum can still contribute to the optical appearance. The correct material setup depends on the finish and may require layered shading.
Correct approach: For painted or powder-coated metals, begin with metalness at 0 and adjust roughness to match the intended finish.
For exposed metals, use metallic shading with appropriate reflection colors.
For anodized aluminum, work from reference images or measured material properties where possible, taking the oxide layer and metallic substrate into account.
In every case, match roughness to the specific finish — brushed, polished, or matte — rather than treating all metal surfaces identically.
Metalness workflow versus specular workflow: which one are you in?
Different renderers implement PBR differently. The workflow you are in changes how you build materials.
The metalness and roughness workflow, common in real-time engines and many offline renderers, uses a base color map, a metalness map, and a roughness map.
The specular and glossiness workflow uses a diffuse map, a specular map, and a glossiness map.
Configured correctly, the two can produce equivalent results. They demand different maps and different ways of representing reflectance.
Mix assumptions across them, and the material may behave incorrectly.
Drop a roughness map into a glossiness-based setup without the appropriate conversion and the surface can appear much shinier or rougher than intended. Similarly, a metalness map cannot simply replace a specular map because the two describe different properties.
V-Ray supports physically based material creation through its material controls, including metalness, roughness, glossiness, and Fresnel settings.
When transferring PBR texture maps between applications, check which workflow the source material uses and whether the maps need conversion.
Real-time versus offline PBR: where the implementations diverge
The same core concepts — roughness, metalness, albedo, and F0 — govern both real-time and offline PBR. What differs is how rendering engines calculate lighting and material interactions while balancing visual quality, complexity, and performance.
Offline rendering with V-Ray provides detailed control over global illumination, reflections, refraction, and advanced material effects such as clearcoat and subsurface scattering.
Chaos Vantage brings fully ray-traced rendering into real-time workflows, allowing artists to explore complex scenes, materials, and lighting interactively without the need for lengthy render iterations. Unlike real-time engines that rely heavily on approximations, Vantage uses ray tracing to produce physically based lighting and material responses.
These workflows are increasingly connected. V-Ray now integrates real-time rendering powered by Vantage directly into the viewport in supported applications, allowing artists to explore materials and lighting interactively while retaining V-Ray's extensive controls for final-quality rendering.
A material that reads correctly in one rendering mode may still need adjustment in another, particularly when using complex effects or renderer-specific features. The underlying PBR principles remain the same, but the available controls and implementations can differ.
Vantage render of a glass-walled pool house with a curved metal frame, indoor pool, lounge furniture and autumn trees.
Building a material setup that holds up: practical starting points
The decisions that matter are fewer than the parameter count suggests.
Use scanned or physically calibrated texture sources where you can. They provide a more reliable foundation for PBR materials, with albedo free from unwanted baked lighting and roughness values that correspond to the intended surface.
When you work from photographic textures, remove baked lighting from the albedo before it enters a PBR material.
Drive roughness with a map, not a flat value, for any surface with visible variation at render scale.
Use normal or displacement maps where necessary, keeping their scale consistent with the actual material.
Calibrate IOR using appropriate reference values for transparent materials and other dielectrics. Treat metalness as a classification decision, not a quality dial.
For a faster starting point, the Chaos AI Material Generator can turn a reference image into a PBR material, generating albedo, normal, and roughness maps that can be refined further.
V-Ray's material controls give artists and designers detailed control over base color, roughness, metalness, reflection, and refraction properties in supported applications including SketchUp, Revit, and Rhino. Additional material layers and options depend on the host integration.
A 30-day V-Ray free trial is available for exploring these material workflows, subject to the current trial terms.
Get started with V-Ray
FAQs
What is the difference between roughness and glossiness in PBR?
They describe the same general surface property using inverted scales. In common PBR workflows, glossiness equals 1 minus roughness. Both describe microfacet distribution, which controls how tight or broad a highlight appears. Some renderers expose one, some the other. V-Ray supports both roughness and glossiness controls.
What does metalness actually control and why should it be binary?
Metalness classifies a surface as a conductor or a dielectric. Exposed metals generally have no diffuse component and produce colored specular reflections. Non-metallic materials produce largely neutral specular reflections, with opaque dielectrics also having a diffuse component. For homogeneous materials, values between 0 and 1 do not generally represent real material properties. Use 0.0 for non-metallic surfaces and 1.0 for exposed metals in the metalness workflow. Layered or coated surfaces may require more detailed material setups.
Why do my rendered materials look plastic even when I am using PBR?
PBR enforces physical constraints. It does not fix incorrect values. Inaccurate albedo, uniform low roughness, incorrectly scaled normal maps, or unsuitable reflection settings can still make a surface look artificial. The plastic look is often a combination of small parameter errors rather than a single flaw. Lighting, geometry, and color management can also contribute.
What is energy conservation and why does it matter for material realism?
Energy conservation means a surface cannot reflect more energy than it receives. Physically based shading models account for this when balancing diffuse and specular reflection, helping prevent unrealistically bright material responses. However, energy conservation alone does not guarantee that a material will look realistic. Its parameters and textures still need to represent the intended surface.
What is IOR and how does it affect glass in architectural renders?
IOR is the index of refraction. It influences how light bends when passing between materials and determines the Fresnel reflection behavior of dielectric surfaces. Typical clear glass has an IOR around 1.5, giving approximately 4% reflectance at normal incidence at an air–glass interface, increasing at oblique angles. Incorrect IOR settings can produce unnatural reflections and refraction, although glass thickness, tint, lighting, and geometry also affect the final result.
Do all rendering engines handle PBR materials the same way?
No. They share the same physical principles, but each engine differs in which effects it calculates and how it balances performance and quality. Some real-time engines use approximations, while fully ray-traced tools such as Chaos Vantage calculate more complex lighting interactively. As a result, a material set up in one engine may need adjusting when you move it to another.
Ready to try Chaos products?
Start your free trial today and explore all features.
Share
Ana Savova
Ana Savova
Ana is the Team Lead for Product Marketing at Chaos, where she oversees the positioning and marketing strategy for the company's visualization software portfolio.
