Ramsha Noaman
Ramsha Noaman
Published: May 18, 2026  •  4 min read
Designing small spaces with big impact: Lighting and material tricks in V-Ray
Designing small spaces is one of the most challenging yet rewarding aspects of interior design. Limited square footage demands smarter decisions: every material, every light source, and every detail must work harder to create a sense of openness, depth, and luxury.
As an interior designer with 12 years of experience working on residential apartments, compact studios, and hospitality spaces, I’ve learned that the difference between a cramped space and a visually expansive one isn’t always about layout, it’s about how you use light and materials effectively, especially in rendering.
With tools like V-Ray, I’m able to push these elements to create spaces that feel much larger and more immersive than they actually are.
Guest Expert
Ramsha Noaman Interior Designer & Founder, "Atelier Design by Ramsha"
  • Specializes in: Residential interiors, compact spaces, hospitality design
  • Expertise: Photorealistic rendering, spatial optimization, material detailing
  • Software: V-Ray, SketchUp, D5 Render, Unreal Engine
  • Experience: Global freelance projects across USA, Canada, and Middle East
Ramsha Noaman
Tips in this article:
→ 1. Layered lighting creates cepth
→ 2. Material realism over complexity
→ 3. Use reflection to expand space
→ 4. Controlled contrast and shadows
→ 5. Color temperature as a spatial tool
→ 6. Composition matters as much as design
→ 7. Subtle imperfections bring life
1. Layered lighting creates depth
In small spaces, relying on a single light source often makes the room feel flat. Instead, I approach lighting in layers:
  • Ambient lighting for overall illumination
  • Accent lighting to highlight textures and focal points
  • Task lighting to add realism and function
In one of my compact living room projects, I combined soft ceiling lighting with warm accent lights integrated into shelving and wall panels:
V-Ray rendering by Ramsha Noaman of a small bathroom sink round with a large illuminated mirror over the sink to make the space appear bigger
Rendering by: Ramsha Noaman
In this project, the space was limited in size, but layering warm accent lighting with neutral ambient light helped create depth and made the room feel more open and inviting.
In V-Ray, I use Rectangle Lights, IES lights, and HDRI environments to simulate natural light behavior. Subtle variations in intensity and temperature (3000K–4000K) help avoid a flat look. A key trick is to slightly reduce overall brightness and let contrast do the work, this enhances spatial perception without overexposing the scene.
In compact interiors, materials are more noticeable because they’re closer to the viewer. Instead of adding too many finishes, I focus on refining fewer materials to a high level of realism.
In a small kitchen project, I limited the palette to wood, stone, and brushed metal, but focused heavily on their surface detailing:
V-Ray rendering by Ramsha Noaman of a kitchen that uses wood, stone, and brushed metal materials that look realistic with correct roughness and glossiness
By refining just three core materials stone, brass and pvc with realistic roughness and reflections, the kitchen felt more premium without becoming visually cluttered.
Key considerations:
  • Micro-roughness variation
  • Accurate reflection glossiness
  • Subtle bump/normal mapping.
Reflective surfaces are powerful in visually expanding small spaces:
  • Mirrors double perceived space
  • Glossy finishes increase light bounce
  • Glass reduces visual heaviness
In a compact bedroom design, I introduced a full-height mirror panel behind the bed:
V-Ray rendering by Ramsha Noaman of a bedroom design with the full length mirror behind the bed to create an illusion of depth to make the space feel bigger
Although the room footprint was small, the mirror created the illusion of depth, making the space feel almost twice as large.
In V-Ray, controlling Fresnel and reflection falloff ensures reflections feel natural rather than artificial.
Perfectly even lighting often makes spaces feel smaller. I intentionally introduce contrast:
  • Soft contact shadows
  • Directional light focus
  • Subtle brightness variation
In a studio apartment project, I kept the seating zone slightly brighter while allowing surrounding areas to fall into softer shadow:
V-Ray rendering by Ramsha Noaman of a living room with a sectional couch, wooden floor, and overheadl lamp. Ramsha used different lighting to define zones despite the room being small
This contrast helped define zones within a small space, making it feel more layered and spacious.
Color temperature plays a psychological role in how we perceive space:
  • Warm tones (3000K–3500K) = cozy
  • Neutral tones (4000K–4500K) = open
In smaller spaces, I often combine both, warm accent lighting with neutral ambient light to maintain comfort without making the space feel enclosed.
V-Ray rendering by Ramsha Noaman of a small dark bathroom. The use of warm lighting makes the space still feel comfortable despite the space being small.
Using warm lighting in feature areas and neutral ambient light helped maintain both comfort and openness in a compact interior.
Even a well-designed space can feel small with the wrong camera setup.
My approach:
In one apartment render, simply adjusting the camera height completely changed the spatial perception:
V-Ray rendering by Ramsha Noaman of a living area in an apartment. The low, eye-level camera shows a spacious room with two white couches and one seat surrounding a low coffee table.
A lower, eye-level perspective made the room feel more natural and significantly more spacious.
Perfect surfaces feel artificial, especially in small spaces where everything is visible up close.
I always introduce:
  • Slight roughness variation
  • Minor texture irregularities
  • Gentle light falloff
V-Ray rendering by Ramsha Noaman of dining area with stone seating and wooden cabinets
These subtle imperfections added realism and depth, making the render feel more natural and believable.
→ Read more about Ramsha's work: Ramsha Noaman on how she uses V-Ray to bring emotion and realism to designs
Conclusion
Designing small spaces isn’t about limitation, it’s about precision. With the right combination of lighting, materials, and composition, even the most compact interiors can feel open, luxurious, and inviting.
For me, V-Ray has been essential in achieving this, allowing full control over detail, light, and realism. And in small spaces, that level of control makes all the difference.
Follow Ramsha for more tips and tricks on Behance and Instagram, or connect on LinkedIn and Upwork.
Try V-Ray free now
Ready to try Chaos products?
Start your free trial today and explore all features.
Share
Ramsha Noaman
Ramsha Noaman
Ramsha is an interior designer and founder of Atelier Design by Ramsha. She has used her expertise in creating photorealistic renderings, spatial optimization, and material detailing, across residential and commercial design, particularly specializing in compact spaces and hospitality venues. She has worked on projects across the globe, including those in the US, Canada, and Middle East. Find her on LinkedIn or Behance, below:
