3D render of night view of commercial skyrise building with glass facade - V-Ray
Ricardo Ortiz
Ricardo Ortiz
Last updated: May 28, 2026  •  16 min read
What is 3D rendering: a complete guide
Quick summary:
  • 3D rendering is the process of generating a 2D image or animation from a digital 3D scene using specialized software and hardware.
  • It is used across architecture, product design, advertising, film, TV, and video games — often replacing traditional photography and physical prototypes.
  • The guide covers how rendering works, the two main techniques (ray tracing and rasterization), real-time vs offline rendering, rendering times, and common software tools.
  • It concludes with a practical look at where V-Ray fits into professional rendering workflows.
3D rendering is the technology behind the hyper-realistic visuals in modern cinema, automotive advertising, and architectural previews. By converting digital 3D models into 2D images, it creates environments so lifelike they are often indistinguishable from traditional photography.
In this introductory piece, Chaos’ Ricardo Ortiz explains the basics of 3D rendering, from the computational methods that create imagery to the artistic techniques that create great computer-generated (CG) content and its various uses.
Table of contents
  1. What is 3D rendering?
  2. How is 3D rendering used?
  3. How is a 3D rendered image generated?
  4. What is ray tracing?
  5. What is rasterization?
  6. Real-time vs. offline rendering: when to use each
  7. How to choose the right 3D rendering approach
  8. Other rendering techniques you’ll hear about
  9. How long does 3D rendering take?
  10. Common 3D rendering software tools
  11. V-Ray and its field
It is the computational process of generating a two-dimensional image or animation from a three-dimensional model. This stage follows 3D modeling and involves simulating light, textures, and camera perspectives to produce a final visual.
To generate an image, specific methodologies and special software and hardware are used. In this process, the 3D scene is converted into a 2D image through rendering software. Therefore, we need to understand that 3D rendering is a process—the one that builds the image. Rendering is the final process of creating the actual 2D image or animation from the prepared scene, which can take from fractions of a second to minutes and even hours for a single image or frame, depending on complexity.
AI Enhanced image - large surfaces in V-Ray
3D rendering vs. 3D modeling vs. 3D visualization
It’s easy to see these terms used interchangeably, but they describe different parts of the creative process. Understanding the main benefits and use cases of 3D visualization will help you see how it fits into the bigger picture:
  • 3D modeling is building a digital model—the geometry of solid objects and environments in three dimensions using computer software (often computer-aided design tools or DCC apps). This process often begins with drawing or sketching basic shapes or wireframes, serving as a foundational step before advancing to detailed modeling and rendering.
  • 3D visualization is the broader process of using three-dimensional data to communicate a design idea and its final outcome. For example, through architectural visualization, product visuals, client presentations, or interactive media.
  • 3D rendering is the step that turns that 3D scene into a rendered image—a final image or sequence of images (frames) by simulating how light interacts with materials, camera angles, and perspective projection.
Types of 3D rendering
There are a few common ways to group 3D rendering types. These categories help you choose the right approach depending on the final output you need.
  • Photorealistic vs. stylized
Photorealistic rendering aims to create true-to-life, photorealistic images that look like real life, with realistic lighting, believable materials, and realistic shadows. Stylized rendering is intentionally non-photoreal (for example, diagram-style, toon shading, or illustrative looks). It can still be high quality, but it prioritizes style over realism.
  • Still image vs. animation
A single image is the most common deliverable for product shots, design approvals, or architectural renderings, often capturing an entire scene in one frame for maximum impact. Animation is a sequence of frames displayed sequentially to show moving objects, camera moves, or storytelling moments (often used in advertising and visual effects).
  • Interactive / real-time vs. offline
Real-time rendering is designed for speed and interaction. It’s used for walkthroughs, design reviews, virtual environments, and experiences like virtual reality, where you need real-time previews as you navigate the scene. Offline rendering (also called non real-time rendering or pre-rendering) focuses on maximum realism and higher image quality, even if processing time is longer.
If you’re wondering what is 3D rendering best used for, the answer often depends on which of these outputs you’re creating.
3D rendering is an indispensable technique for many industries, including architecture, product design, advertising, video games, and visual effects for film, TV, and animation. It is now a standard tool used to showcase and enhance the appearance of products and projects, making it crucial for visualization, marketing, and training.
In design and architecture, renders allow creative professionals to communicate their ideas in a clear and transparent way. A render gives them the chance to evaluate their proposals, experiment with materials, conduct studies, and contextualize their designs in the real world before they are built or manufactured. This ensures the intended appearance is accurately represented - this is precisely how architectural rendering workflows support better decisions early in a project.
Architectural rendering with wooden facade and white brick walls
For the media and entertainment industries, 3D rendering is fundamental to the creation of sequences and animations that tell stories, whether we’re watching an animated movie, a period drama, or an action sequence with explosions, ships from the future, exotic locales, or extraterrestrial creatures—an area where next‑generation techniques like 3D Gaussian splatting rendering are starting to play a major role.
Visit our amazing gallery to see the power of rendering.
Over the past few years, the evolution of computer graphics in these industries has replaced traditional techniques. For example, special effects are being replaced by visual effects, which means stunt people no longer risk their lives in car crashes.
In advertising, I would dare to say that 90% of automotive commercials are CG, or even more. In the architecture industry, many traditional techniques to create representations, such as scale models, have been replaced with photorealistic imagery to ensure we can see exactly how something will look once it’s built. 3D rendering is now a standard tool for visualization, marketing, and training, helping to drive sales by creating compelling visuals that enhance product presentations and promotional materials.
Automotive rendering of sport car green
Accelerating processes, reducing costs, and the demand for better quality results have helped technology evolve. Hardware is more powerful than ever, and the switch to CG was inevitable. Today, professionals can find and utilize a wide range of 3D rendering software to improve their workflows and visual output. In healthcare, for example, 3D rendering is used to create anatomical models for surgical training, further showcasing its versatility and value across industries.
Benefits of 3D rendering
The benefits of 3D rendering extend beyond aesthetics; it serves as a strategic tool for cost reduction and project acceleration. Key advantages include faster stakeholder approvals, early detection of design flaws, and the elimination of expensive physical prototypes.
  • Faster approvals and clearer feedback: A realistic image makes it easier for stakeholders to understand the final outcome and give actionable feedback during client presentations.
  • Fewer design flaws: Seeing a complete scene before production helps teams catch design flaws early, reducing rework and costly mistakes.
  • Cost savings vs. physical alternatives: Rendering can reduce reliance on physical prototypes, mockups, or photoshoots, while still delivering lifelike images in a cost-effective way.
  • Marketing flexibility: Once you have the digital model, you can produce images from new camera angles, update materials, and generate multiple visuals without starting from scratch.
  • Better collaboration across teams: 3D rendering helps improve collaboration among architects, interior designers, industrial designers, and branding agencies, allowing them to align around one shared visual reference—even when working in different tools.
  • More confident decisions in complex projects: With complex scenes and tight timelines, efficient rendering software helps teams test options (lighting, materials, context) before committing to real-world spend.
  • Increased conversions and reduced return rates in e-commerce: Investing in 3D rendering can lead to higher conversion rates and fewer returns, as accurate images help customers make more informed purchasing decisions.
The 3D rendering process (workflow)
Most 3D projects follow a similar rendering process, whether you’re creating photorealistic images for real estate development or producing visual effects for feature films:
  1. Model the scene: Create detailed models (or import three-dimensional data stored in CAD/BIM files) to build a complete scene.
  2. Apply materials and textures: Assign surfaces (wood, glass, metal) so rendering software can calculate how each material responds when light hits it, including light refraction and reflections.
  3. Set up realistic lighting: Add a light source (sun/sky, HDRIs, studio lights) to create a believable real-life look, including realistic shadows.
  4. Choose camera angles and framing: Set the view using camera angles and perspective projection to match the story you want the final result to tell.
  5. Render the final output: The rendering engine calculates how light behaves across the scene, turning 3D models and data into the final visual output (or a sequence of frames for animation). This is where computer processing power, scene complexity, and rendering times matter most. especially with complex scenes.
  6. Post-process and deliver: Refine the final product (color, contrast, motion blur, depth of field) and export the correct format for web, print, or playback (frames displayed sequentially for video). Post-processing includes final adjustments such as color correction and atmospheric effects.
Two pieces of software, with different characteristics, are commonly used to generate images and animations: rendering engines and game engines. Render engines use a technique called ray tracing, while game engines use a technique called rasterization—and some engines mix both techniques, but we will talk about that later on.
First, let's talk about the ray tracing process. V-Ray uses this technique.
3D render of beauty salon with soft textures and lighting using V-Ray
Ray tracing is a rendering technique that simulates the physical behavior of light. By tracing the path of light rays as they interact with virtual objects, it accurately calculates reflections, refractions, and shadows to produce photorealistic results.
This technique is used to create photorealistic images. If we have to calculate a large number of lights and objects in our scene it can dramatically increase the time it takes to render an image. 3D artists must consider the implications of everything in a scene, including reflections, refractions and translucencies, as well as more complex elements such as displacement, sub-surface scattering and instancing.
There is another very popular methodology that allows us to obtain images incredibly quickly, but with the absence of the realism that ray tracing offers. Rasterization is very common in game engines, and its most important advantage is that it offers real-time experience where viewers can move around in and interact with the 3D scene.
In rasterization, objects on the screen are created from a mesh of virtual triangles, which create 3D models of objects. In this virtual mesh, the corners of each triangle, known as vertices, intersect with the vertices of other triangles with different shapes and sizes. Every single vertex provides specific information and by gathering all this data, the shape of the object is created. Then, the computer converts the triangles of the 3D models into pixels on the 2D screen and we are presented with the final image.
Night render of residential standalone houses
As I said, this technique is very common in video game engines. It can become computationally intensive because there can be millions of polygons for all objects in a scene, and many millions of pixels on a screen.
When should you use real-time vs offline rendering?
Both approaches can produce a realistic image, but they optimize for different goals.
  • Real-time rendering is best when you need speed, interaction, and real-time previews. It’s ideal for design review, early-stage iteration, and client presentations where you want to walk through a complete scene, test materials, and explore lighting quickly. It’s also the foundation for immersive experiences like virtual reality inside interactive virtual environments.
  • Offline rendering (also called pre-rendering or non real-time rendering) is best when your priority is higher image quality and maximum realism. It’s commonly used for final marketing visuals, architectural visualization hero shots, product imagery, and feature films where photorealistic images and refined effects (like accurate reflections, motion blur, depth of field, and complex light behavior) matter more than interactivity.
In practice, many teams use both: real-time for fast decisions and alignment, then offline rendering to create photorealistic images for the final deliverable.
How to choose the right 3D rendering approach (quick decision guide)
If you’re deciding between offline rendering, real-time rendering, or a hybrid workflow, start with the final output you need and how much interactivity the project requires.
Goal/output Best-fit approach Why it fits Watch out for
Client design review walkthrough Real-time Fast iteration, real time previews, easy to explore camera angles and make changes live during client presentations You may need to simplify heavy geometry; complex scenes can still push computer processing power limits
Final marketing still image (photorealistic) Offline Best for higher image quality and realistic rendering where realistic lighting and shadows matter most in the final image Longer rendering times and processing time; revisions can add cost
Animation (product or architectural) Hybrid Real-time for blocking camera moves and timing; offline for the final output where motion blur and refined lighting improve realism Rendering hundreds/thousands of frames displayed sequentially can be time-consuming—plan render farms early if needed
Product configurator / interactive 3D Real-time Designed for interactive media and instant updates when the viewer changes options Requires optimization for consistent performance across devices; materials may need tuning to keep a realistic image look
VR presentation (virtual reality) Real-time (VR-ready) Virtual environments must respond instantly to user movement to feel believable and comfortable Needs strict performance targets; large datasets may require optimization
Quick takeaways:
  • Choose real-time when speed, interaction, and decision-making matter more than perfect realism.
  • Choose offline rendering when the goal is to create photorealistic images for final marketing, approvals, or film-quality visuals.
  • Use a hybrid approach when you need both: fast iteration first, then maximum quality for the final product.
  • Expect complex scenes, detailed models, and advanced effects (realistic lighting, light refraction, motion blur) to increase processing time and rendering costs.
  • For immersive experiences like virtual reality, plan your rendering method and optimization from day one.
Beyond ray tracing and rasterization, there are a few common rendering methods and terms that come up often in rendering software:
  • Global illumination (GI): A set of techniques that simulate how light bounces around a scene (indirect lighting), helping create more realistic lighting and natural-looking shadows.
  • Path tracing: A form of ray tracing that models light transport by sampling many light paths and bounces. It’s a popular approach for highly realistic rendering and photorealistic images, but it can increase processing time in complex scenes.
  • Scanline rendering: A classic technique that renders geometry efficiently (often polygon-by-polygon), historically used when speed was the priority and hardware was more limited.
  • Radiosity: A method focused on diffuse light transfer between surfaces (how light energy “bleeds” between walls, floors, and ceilings). It’s especially useful for interior design and architectural renderings where soft indirect light matters.
Night view of commercial glass skyrise - Parallax_Interiors_example created in V-Ray
Rendering times can range from near-instant (for real-time previews) to hours or even days (for offline rendering), depending on how much computer processing power is required to calculate the final image. The rendering process can be computationally expensive because it simulates complex physical processes such as lighting, materials, textures, shadows, and reflections to produce a realistic final image, which is why many studios rely on distributed solutions like V-Ray Swarm for faster rendering.
Key factors that affect processing time include:
  • Scene complexity: more objects, higher polygon counts, and more detailed models create more work for the computer.
  • Lighting and effects: realistic lighting, global illumination, reflections, light refraction, motion blur, and depth of field can increase rendering times, especially in complex scenes.
  • Output settings: higher image quality, larger resolution, and more samples generally mean longer processing time.
  • Hardware and render setup: GPU/CPU performance, memory, and whether you use local machines or render farms can significantly change turnaround time.
  • Animation vs single image: rendering a single image is usually far faster than rendering hundreds or thousands of frames that are displayed sequentially in a final output.
Common 3D rendering software tools (and what they’re used for)
Different software tools support different parts of the rendering process. Most workflows combine a few categories:
  • DCC and computer-aided design tools (scene creation): Used to build the digital model and prepare three-dimensional data—common in industrial design, architectural visualization, and scientific modeling. Autodesk Maya is a popular and versatile 3D modeling and rendering software, widely used across industries and compatible with rendering engines like V-Ray, and Corona. Blender is a leading open source 3D modeling and rendering software, favored by freelancers and studios for its robust capabilities and free, community-driven development.
  • Rendering engines (final output): Focused on realistic rendering and higher image quality, especially for offline rendering when you need photorealistic images as the final product. Popular rendering engines include V-Ray and Corona, each offering unique features and capabilities for different types of 3D rendering tasks.
  • Real-time engines (interactive experiences): Built for real-time rendering and real-time previews, often used for design review, video game development, interactive media, and virtual environments like virtual reality. Enscape is a real-time 3D visualization and rendering engine that is popular with architects and interior designers.
  • Render farms and cloud tools (scale): Used to speed up rendering times by distributing processing across multiple machines, especially for complex scenes, animation, and feature films.
With that context, let’s look at where V-Ray fits.
V-Ray and its field
V-Ray is a production-proven, high-end ray tracing 3D rendering software, offering the highest quality, power, speed and creative control. V-Ray is built to handle the largest projects and the most difficult scenes. It’s tightly integrated into the most popular 3D platforms on the market and it presents users with a simplified and creative workflow.
For years, V-Ray has allowed studios to create professional photorealistic images and animations, it has a large community of users and it is recognized for its great versatility. It has also received an Academy Sci-Tech Award in 2017 for its creation of photorealistic images for the big screen.
External rendering of modern office building using V-Ray
V-Ray for Architecture, Engineering and Construction (SketchUp and Rhino) combines ray tracing and real-time. The latest V-Ray 7, update 3, integrates Chaos Vantage technology directly into the viewport for real-time reviews, eliminating the need to switch windows or export files.
Wrapping up
The intention of writing this article is to provide basic information about some fundamentals of V-Ray. In my opinion, knowledge of these aspects is very important for any digital artist who is interested in the subject of rendering. Speaking the language and understanding its context will allow us to go one step ahead. There is an ocean of additional theory and information that you can research if you feel inspired and passionate.
Key takeaways
  • 3D rendering converts a 3D scene into a 2D image or animation by simulating how light interacts with materials, cameras, and geometry.
  • Ray tracing produces photorealistic results by tracing light paths, used by V-Ray and offline rendering engines.
  • Rasterization converts geometry to pixels in real time - faster but less physically accurate; used in game engines and real-time tools.
  • Real-time rendering is best for design reviews, walkthroughs, and interactive experiences; offline rendering is best for final marketing visuals and film-quality output.
  • Many professional workflows combine both - real-time for fast iteration, offline for the final deliverable.
  • Rendering time depends on scene complexity, lighting, output resolution, and hardware - from seconds to days per frame.
    V-Ray combines ray tracing quality with real-time preview through Vantage — supporting both photorealistic stills and interactive design workflows.
FAQs
What are the future trends in AI-assisted 3D rendering?
In 2026, Neural Rendering is revolutionizing the industry by using AI to predict light behavior. This technology enables artists to upscale low-resolution previews into 4K photorealistic images almost instantly, significantly reducing traditional computational overhead. Additionally, generative AI is now being integrated directly into rendering engines to automatically build complex textures and environmental details from simple text prompts.
What are the hardware requirements for 3D rendering in small studios?
Small studios should prioritize high-end GPU performance over CPU for the best ROI. A professional workstation requires an NVIDIA GeForce RTX 3070 Ti or an AMD RX 6800-series card with at least 8GB of VRAM to handle architectural scenes without memory errors.
As a beginner artist, what should I learn first about 3D rendering?
Before focusing on specific software buttons, a beginner should master lighting theory and composition. Understanding how light behaves in the real world, such as the difference between a hard direct sun and soft overcast light, will make your renders look professional regardless of the engine you use. Mastering how real-world materials reflect and refract light is the next crucial step.
How do enterprise marketing teams use 3D product rendering to replace traditional photography?
Enterprises use Digital Twins to eliminate the logistics of physical photoshoots and global shipping. A single master 3D model allows teams to generate infinite variations in colors and environments instantly. This ensures total brand consistency across e-commerce platforms while reducing time-to-market and production costs compared to traditional studio photography.
Which 3D rendering techniques are most effective for achieving photorealistic results?
Beyond standard ray tracing, professionals use Physically-Based Rendering (PBR) and subsurface scattering to simulate how light enters translucent materials like marble or skin. Capturing caustics—the light patterns created by glass or water—is also vital. Finalizing these simulations with AI-enhanced post-processing ensures the output is indistinguishable from a real-world photograph.
Ready to try Chaos products?
Start your free trial today and explore all features.
Share
Ricardo Ortiz
Ricardo Ortiz
As part of the Chaos team, Ricardo is responsible for growing and supporting our Spanish-speaking user community, including Hablamos Chaos, which has over 80K Facebook members. Ricardo is a V-Ray Certified Professional in V-Ray for 3ds Max, V-Ray for Maya, V-Ray for Rhino and V-Ray for SketchUp. He has worked as an instructor for over 10 years in industries including archviz, VFX ,and product design. Ricardo is also a university teacher in industrial design, architecture and digital animation.
