Enscape rendering of bird's eye view of energy-efficient building with solar panels on the roof and the surrounding streets
Kalina Prelikj
Kalina Prelikj
Last updated: April 16, 2026  •  10 min read
What is energy efficiency: Key concepts and benefits
Energy efficiency is a term that gets tossed around in countless project descriptions, sustainability reports, and industry discussions. But what does it actually mean? This article breaks down energy efficiency, its key concepts and benefits, and how architects can take the lead in building a sustainable future.
Energy efficiency is the practice of using less energy to deliver the same or better results in buildings, products, or processes—reducing waste, costs, and environmental impact.
In this article, we'll explore:
Energy efficiency is about using less energy to achieve the same or better outcomes. It's a key concept that helps us reduce waste, lower energy costs, and minimize our environmental footprint, all while maintaining the necessary level of performance.
With that in mind, understanding energy efficiency is essential for any architect looking to make informed, sustainable choices.
What is energy efficiency in the AEC industry?
Energy efficiency in the AEC industry involves designing and constructing sustainable buildings that use less resources for heating, cooling, lighting, and operations without compromising comfort or functionality. For example, using smart HVAC systems and efficient insulation can significantly cut energy use in a building.
Energy efficiency vs energy conservation
Energy efficiency is often mistaken for energy conservation, but they are distinct concepts. Energy efficiency focuses on using technology or design to achieve the same results with less energy—for instance, installing energy-efficient light bulbs that use less power while providing the same amount of light.
Energy conservation, on the other hand, involves saving energy through behavioral changes, like turning off lights when they’re not needed. While efficiency focuses on maintaining performance with less energy, conservation is about actively reducing energy consumption.
What are the key concepts for maximum energy efficiency?
Enscape rendering of solar panels on the rooftop of a building
To make an informed decision about your next design's level of energy efficiency, you first need to understand some key concepts. With this knowledge, you will be able to identify where improvements can be made to reduce energy consumption and lower greenhouse gas emissions.
  • Energy intensity: This measures how much energy is used to produce a certain amount of economic output, such as GDP. High energy intensity means more energy is required for the same results, leading to inefficiency and higher costs. Understanding this is essential for designing buildings with lower carbon dioxide emissions.
  • Efficiency vs. effectiveness: Effectiveness ensures desired outcomes are met with minimal waste. For example, an efficient building might use advanced insulation to reduce heating costs while maintaining indoor comfort.
  • Types of energy efficiency: Operational efficiency optimizes building systems like HVAC, lighting, and appliances, while structural efficiency designs buildings to use less energy by integrating energy-efficient materials, passive solar design, and renewable energy technologies. Both types are key to industrial decarbonization and cutting carbon dioxide emissions.
  • Technological improvements: Advances in technology, such as LED lighting, smart thermostats, and energy-efficient appliances, are crucial if you want to improve energy efficiency. For instance, according to the DOE, switching to LED lighting in commercial buildings can reduce energy use by up to 75%. Efficient manufacturing facilities also use automation and smart systems to optimize energy use and reduce emissions.
  • Behavioral changes: Small behavioral shifts, like turning off lights or adjusting thermostats, can make a big difference. Setting thermostats back 7-10 degrees for 8 hours a day can save up to 10% annually on heating and cooling costs. Paired with efficient building designs, these practices help reduce energy consumption across economic sectors.
  • Efficient practices: Examples include weatherizing, which improves insulation and seals gaps, and using energy management systems and efficient smart electric meters to track consumption and identify waste. These practices help reduce energy bills and minimize greenhouse gas emissions.
  • Sustainable design: Sustainability focuses on creating buildings that have a minimal environmental impact by using resources responsibly. Energy efficiency is an essential part of sustainability because it reduces the energy needed to operate buildings.
By integrating solutions like passive solar design and energy-efficient windows, architects can lower energy consumption and reduce the building’s carbon footprint. Today, architects can also use tools like Enscape Impact to incorporate energy analysis into their workflows for smoother, more efficient designs.
Architectural 3D model in Enscape Impact with a Thermal Comfort analysis overlay showing 100% comfortable rooms in teal.
Enscape Impact's thermal comfort analysis
What are the benefits of energy efficiency?
From lowering costs to improving quality of life, energy-efficient practices provide tangible benefits to both individuals and businesses. Below are some of the key benefits of adopting energy efficiency:
  • Economic benefits: Energy efficiency saves money. In fact, effipractices can lead to significant cost savings for both consumers and businesses by reducing energy bills and operational expenses. For example, an energy-efficient office building can lower monthly utility costs, improving profitability for the company.
  • Environmental impact: By reducing energy consumption, energy efficiency directly lowers greenhouse gas emissions and minimizes air pollution. Using energy-efficient appliances in homes reduces the overall carbon footprint, contributing to a healthier environment.
  • Energy security: Energy efficiency decreases reliance on imported fossil fuels by reducing overall energy demand. This enhances national energy security, making countries less vulnerable to energy supply disruptions.
  • Improved health and comfort: Energy-efficient buildings often feature better insulation and ventilation, which enhances indoor air quality and thermal comfort. Well-insulated homes maintain a consistent indoor temperature, improving comfort and reducing the risk of health issues related to poor air quality.
  • Energy equity: Energy efficiency helps make energy more affordable, especially for low-income households, by reducing energy bills and improving access to efficient technologies. Weatherization programs that provide efficient upgrades to low-income homes can significantly lower utility costs for residents.
  • Compliance and certification: Prioritizing energy efficiency ensures alignment with tightening building mandates while accelerating the path toward global standards like LEED or BREEAM. By integrating high-performance data early, firms bypass the risk of regulatory penalties and project delays.
Energy efficiency in practice
We’ve discussed the concepts of energy efficiency, but how does it work in practice? Here are three green projects that combine design, technology, and natural resources to achieve impressive energy savings.
Design meets behavior
BedZED is the UK's first major sustainable community. Completed in 2022, the project was initiated and developed by Peabody Trust in partnership with Bioregional and ZEDfactory architects. It includes 100 homes, office space, a collage, and community facilities.
Image of BedZED eco village in London
BedZED eco-village, London
Tom Chance, CC BY 2.0 via Wikimedia Commons
Efficiency is not just about building systems—it’s about how occupants interact with them. The BedZED community in London demonstrates this by combining passive solar heating, high-performance insulation, and energy-efficient appliances with resident-driven behavior changes.
Simple actions, like adjusting thermostats or conserving water, allow BedZED to maximize energy savings through both innovative design and active community participation.
Utilizing nature for efficiency
Bosco Verticale is a model of a green residential building by Boeri Studio. Located in Milan, the project consists of two residential towers and hosts 800 trees, 4,500 shrubs, and 20,000 plants.
Image of Bosco Verticale building in Milan
Bosco Verticale, Milan
Darsheni, CC BY-SA 3.0 via Wikimedia Commons
Bosco Verticale in Milan is one notable project that showcases how nature can play a direct role in reducing energy consumption. Its plant-covered façades provide natural insulation, minimizing the need for artificial heating and cooling.
Paired with passive solar design to optimize natural light, Bosco Verticale reduces energy reliance while creating a sustainable, efficient environment for residents.
Scaling efficiency with technology
Pearl River Tower is a building located in Guangzhou, China by Skidmore, Owings & Merill. Completed in 2013, the building set a benchmark for the ecological design of supertall towers.
Image of the Pearl River Tower in Guangzhou
Pearl River Tower, Guangzhou
Von IndexxRus - Eigenes Werk, CC BY-SA 3.0 via Wikimedia Commons
At a larger scale, advanced technology is crucial. A great example is the Pearl River Tower in Guangzhou, which integrates natural ventilation, solar panels, and wind turbines to produce renewable energy and significantly lower energy consumption.
This commercial skyscraper demonstrates how cutting-edge technology can drastically reduce a building's reliance on external energy sources, setting a new standard for energy-efficient high-rises.
What are the future trends in energy efficiency?
Looking ahead, several emerging trends are set to transform how we approach energy efficiency, reshaping both residential and commercial sectors.
Key trends:
  • Technological advancements: The integration of smart grids and IoT devices optimizes building performance by enabling real-time energy monitoring and automated, data-driven system adjustments.
  • Policy developments and energy efficiency incentives: Evolving government regulations and financial tax incentives drive the adoption of sustainable practices by rewarding firms that exceed baseline energy standards.
  • Efficient products and systems: Implementing high-performance HVAC, lighting, and insulation systems reduces the total energy load of a structure while maintaining superior occupant comfort.
Smart grids, IoT integration, and advanced efficiency-related technologies are revolutionizing how energy is managed in real time. These innovations enable buildings to dynamically respond to changing energy demands, reducing waste and enhancing resilience. As these technologies evolve, buildings will be able to optimize energy usage more effectively, contributing to reduced operational costs and environmental impact across various sectors.
Policy developments
Governments and industries play a crucial to promote energy efficiency through incentives, rebates, and regulatory measures. For instance, Germany’s KfW energy-efficient home loan program provides low-interest loans and grants for homeowners to invest in energy-efficient upgrades.
These policies not only cut emissions but also make energy efficiency more accessible and affordable for consumers and businesses.
Looking forward, efforts to achieve zero emissions will require further collaboration between industries and policymakers, especially to promote industrial efficiency and decarbonization at scale.
Market trends
As awareness of environmental issues grows, so does the demand for energy-efficient products. From appliances to smart lighting and efficient manufacturing systems, these products are becoming standard as consumers and businesses seek to reduce both costs and carbon footprints.
As this market expands, these products will play a crucial role in building a sustainable future, helping drive the shift toward a clean energy economy.
AI and simulation tools
AI and simulation tools are transitioning buildings from passive structures into active, intelligent participants in the energy grid. In the commercial sector, AI-powered platforms act as an integrated operating layer that autonomously optimizes HVAC systems, precools spaces based on occupancy forecasts, and manages load shifting to eliminate peak utility charges.
In the residential sector, predictive simulation tools allow homeowners to move from reactive awareness to proactive management, leveraging real-time data and weather forecasting to automate energy savings without sacrificing comfort.
How can architects lead in building a sustainable future?
  • Conduct early-stage energy modeling: Performing simulations during the conceptual phase can help identify impactful efficiency measures before decisions become too costly to alter.
  • Prioritize passive design strategies: Leveraging natural light and ventilation reduces a building's reliance on systems, as it uses the local climate to maintain thermal comfort.
  • Integrate smart building systems: Using sensors and automated controls ensures that energy-consuming systems, such as lighting and HVAC, operate only when and where needed.
  • Choose energy-efficient materials: Selecting products with high thermal mass can minimize heat transfer, significantly lowering the long-term energy required for climate control.
  • Encourage occupant behavior change: Educating users on energy-saving habits can bridge the gap between a building's designed efficiency and its actual performance.
It's clear that energy efficiency is a vital component in achieving net zero emissions of carbon dioxide. With that in mind, it’s our responsibility as architects to prioritize energy efficiency in every project.
By promoting sustainable practices, conducting building performance analysis, adopting the latest technological advancements, and encouraging responsible behaviors, we can reduce energy consumption, support clean energy initiatives, and help combat climate change through resilience and reliability.
Frequently asked questions
How is energy efficiency measured?
Energy efficiency is primarily measured using the Energy Use Intensity (EU I) metric, which is calculated as the total energy consumed by a building over one year divided by its total gross floor area. Another way it can be measured is through Energy Efficiency Ratios (EER) for specific appliances, comparing the cooling or heating output to the electrical power input.
How can I improve energy efficiency in my home?
You can improve energy efficiency in your home with tips such as sealing air leaks around windows and doors while adding insulation to attics and walls to prevent thermal loss, upgrading lighting to LED bulbs and appliances with high Energy Star ratings, and installing smart thermostats to optimize heating and cooling schedules based on your actual presence.
What are the different types of energy efficiency technologies?
The different types of energy efficiency technologies span three primary categories: the building envelope, mechanical systems, and digital management. A high-performance envelope utilizes thermal insulation and high-performance glazing to minimize heat transfer, while mechanical upgrades like heat pumps and automated demand-controlled ventilation reduce the energy required for HVAC and water heating. These physical improvements are further optimized by smart systems and AI-driven management platforms to provide real-time monitoring and automated energy savings.
What are the government policies and incentives related to energy efficiency?
Government policies and incentives related to energy efficiency include mandatory building energy codes and certificates to set baseline standards for properties. To encourage adoption, they provide financial incentives such as tax credits, rebates for efficient appliance purchases, and low-interest loans for retrofitting projects.
How to improve energy efficiency in residential buildings?
Improving energy efficiency in residential buildings requires a whole-house approach that combines passive design strategies, like optimizing natural ventilation, with active technology upgrades. You should focus your efforts on reducing the heating and cooling load through high-quality insulation and by integrating renewable energy sources such as rooftop solar panels.
Ready to try Chaos products?
Start your free trial today and explore all features.
Share
Kalina Prelikj
Kalina Prelikj
A jack of all trades and a Master of Architecture, Kalina enjoys embracing her creative side and has dabbled in everything from marketing to design to communications. Now, as an Editorial Assistant at Architizer, she channels her passion for architecture, helping celebrate the world's best designs and the people behind them.
Tom Chance,
Darsheni,
