Global illumination (GI), also known as indirect illumination in rendering, describes the effect of light bouncing from one surface to another. Understanding it helps explain why a scene can look flat even when the model and materials are well developed. For architecture students exploring architectural visualization, it is a useful foundation for evaluating lighting in both real-time and production renders.
Key takeaways:
Global illumination concerns bounced, indirect light; GI algorithms are the methods used to calculate or approximate it.
Look for reflected color, illumination in shaded areas, and the distribution of light through deeper spaces—but also evaluate exposure, materials, and direct lighting.
In V-Ray, relevant GI engines include Brute Force and Light Cache. In Corona, the main solvers include Path Tracing and UHD Cache.
Real-time visualization is not necessarily limited to approximate lighting: Enscape supports rapid design feedback, Envision supports presentation storytelling, and Vantage offers ray-traced real-time visualization alongside production rendering workflows in V-Ray and Corona.
The render that looks right but feels wrong
You have built the room, applied materials, set the lighting, and framed the camera. Yet the image feels less convincing than expected. A shaded corner may appear too dark, the walls may look uniformly lit, or materials may seem disconnected from their surroundings.
These are useful clues, but they do not automatically point to a problem with GI. Before changing materials or adding lights, consider how direct and indirect illumination, exposure, and material reflectance are working together.
What global illumination actually is
When light reaches a surface directly from the sun, a lamp, or another source, it is direct illumination. Some of that light is reflected onto nearby surfaces. This bounced light is indirect illumination, often referred to as global illumination (GI) in rendering.
For example, sunlight falls onto a wooden floor. The floor reflects a portion of that light onto a nearby white wall, adding a subtle warm tint. That change is a lighting effect. GI algorithms are the methods renderers use to calculate or approximate those indirect light interactions.
Direct and indirect illumination work together to create the overall lighting of a scene. Controls labeled “GI” in render settings generally focus on the indirect contribution rather than the direct light arriving from the original source.
GI is also different from a simple ambient-light approximation. Ambient illumination can brighten a scene or soften dark areas, but a uniform ambient fill does not reproduce how bounced light changes with the geometry and materials. Some renderers also offer ambient-light tools that can be used to simulate aspects of GI.
Direct lighting versus indirect lighting
Direct lighting comes straight from a light source onto a surface. Indirect lighting is simply bounced light. When sunlight hits a floor and reflects onto a nearby wall, it can soften contrast in shaded areas and carry some of the floor’s color with it. This interaction helps surfaces feel part of the same space.
Rendered with V-Ray
What GI changes in the image
Three visual cues can help you assess the contribution of indirect illumination. They are diagnostic clues, not a guarantee that a particular GI setting is correct.
Color bleeding. A warm wooden floor may reflect some of its color onto a nearby white wall. The resulting tint is subtle, but it helps connect adjacent surfaces through reflected light.
Light in shaded areas. Even surfaces that do not receive direct sunlight can be illuminated by light reflected from walls, floors, or ceilings. This reduces excessive contrast and reveals more detail in shaded areas. The sharpness of a shadow edge, however, also depends on the light source and geometry; it is not determined by GI alone.
Light distribution in deeper spaces. In a corridor or interior with limited direct light, multiple bounces can carry illumination farther into the space. How much light reaches these areas depends on the layout, surface properties, and lighting setup.
In each case, the renderer evaluates how light interacts with the scene. Recognizing these effects helps you decide whether to investigate indirect lighting or another part of the setup.
Why GI alone does not fix a flat render
Global illumination contributes to believable lighting, but enabling it does not automatically produce a convincing image. Materials, exposure, light sources, and the intended visual style all influence the result.
A material with reflectance that does not suit the desired appearance can make a surface look too bright or too dull. Exposure can wash out a scene or hide detail in shadows. A lighting setup without a clear direction or hierarchy may also produce an overly even image, even when indirect illumination is calculated accurately.
If a render appears flat, check these elements together before changing GI settings. Often, adjusting exposure or the material and lighting setup will have a greater effect than increasing the number of light bounces.
GI methods: understanding the controls in V-Ray and Corona
Different renderers use different algorithms, often called GI engines or solvers. Rather than treating “precomputed” and “dynamic” GI as a simple either-or choice, it is more useful to understand the controls you will encounter in the software.
V-Ray: Brute Force and Light Cache
V-Ray offers detailed control over GI calculations. Brute Force calculates indirect illumination directly, while Light Cache reuses calculated lighting information to make secondary bounces more efficient. A common setup uses Brute Force for primary bounces and Light Cache for secondary bounces, although available options can differ by host application and rendering mode. V-Ray is a versatile, industry-standard option for artists who want detailed control across workflows in applications such as SketchUp, Rhino, and 3ds Max.
Explore the V-Ray GI settings for 3ds Max and V-Ray for SketchUp global illumination settings.
Corona: Path Tracing and UHD Cache
Corona is designed to make architectural visualization approachable, with streamlined controls and high-quality results using its defaults. Its primary GI solver uses Path Tracing; for secondary bounces, artists can use Path Tracing or UHD Cache. UHD Cache is useful in many interiors with substantial indirect lighting, while Path Tracing may be more suitable for other scenes. In most cases, Corona recommends keeping the default GI settings unless there is a specific reason to change them.
See the Corona Performance tab documentation for GI solver options and guidance.
Both V-Ray and Corona are suitable for high-quality architectural visualization. The choice depends on the application you use, the amount of control you want, and the demands of the project. A still image and an animation can both require repeated lighting adjustments; the type of final output alone does not determine which GI method is best.
How many light bounces are enough?
There is no single ideal number for every scene. Additional bounces can affect how much indirect light reaches enclosed or shaded areas, but their impact depends on the renderer and the GI method. More bounces do not always produce a noticeably better image, and the performance cost is not the same in every engine.
Start with the renderer’s recommended defaults. If the scene still has a lighting issue that appears related to indirect illumination, compare controlled test renders before adjusting bounce limits. In Corona, for example, the default maximum ray depth is generally recommended for normal use.
© CR.3D Studio.
Rendered with Corona
GI in real-time versus production rendering
Real-time and production rendering serve different needs, but the distinction is not simply “fast approximations” versus “accurate final images.” Some real-time solutions favor responsiveness through approximations; others use ray tracing to calculate physically based illumination interactively.
Enscape for design feedback. Enscape works directly with CAD/BIM applications and provides immediate visual feedback as a design evolves. It includes real-time global illumination and helps architecture students explore materials, lighting, and spatial decisions without a separate visualization workflow.
Envision for high-end presentations. Enscape Envision extends the design workflow into a standalone, real-time visualization and animation environment. Connected workflows make it possible to develop more detailed scenes, camera movements, and presentations while benefiting from ray-traced lighting.
Vantage for ray-traced real-time visualization. Vantage uses real-time ray tracing and physically based global illumination. It can support both interactive look development and high-quality final imagery or animation. Vantage rendering is also available within V-Ray workflows for SketchUp, Rhino, and 3ds Max, providing ray-traced feedback while artists work on their scenes.
V-Ray and Corona for production control. For artists developing high-end architectural imagery, V-Ray and Corona provide established production workflows with control over lighting, materials, and rendering quality. Vantage can complement these workflows rather than replacing the need for a production renderer in every project.
The most appropriate workflow depends on whether your priority is live design feedback, presentation storytelling, real-time ray-traced quality, or a carefully controlled production render. Real-time output can also be used as a final deliverable.
How to evaluate GI in your own renders
When an image looks flat, use a consistent camera view and ask:
Is reflected light reaching surfaces that are outside the direct light, such as shaded walls or corners?
Is there subtle color bleeding where nearby materials could reflect colored light onto one another?
Are darker areas lacking indirect fill, or is the problem related to the light source, geometry, or exposure?
Do material reflectance and exposure support the visual result you want?
Have GI settings been changed from the renderer’s recommended defaults?
If your renderer allows it, compare a test image with GI disabled and enabled, keeping the camera, materials, exposure, and direct lighting unchanged. This will make the contribution of indirect illumination easier to identify. Then restore the appropriate GI settings for your final scene.
For hands-on practice, explore the V-Ray Collection trial, the Corona Collection trial (both include Vantage), or the Enscape Collection trial for design and presentation workflows with Enscape and Envision. Review the trial terms before signing up.
💡 For more information, see the Chaos blog’s lighting resources.
FAQs
What is global illumination and how does it work?
Global illumination describes how light reflects between surfaces and contributes indirect illumination to a scene. GI algorithms calculate or approximate that bounced-light effect, helping the renderer account for light that does not travel directly from a source to the visible surface.
What is the difference between global illumination and direct lighting?
Direct lighting reaches a surface straight from a source. Indirect illumination reaches it after reflecting from other surfaces. Together, they shape the overall light distribution, while GI controls in rendering software commonly handle the indirect contribution.
Does global illumination make renders slower?
Calculating indirect light requires processing, but the impact on render speed depends on the method, the scene, the hardware, and the renderer. Cached methods and real-time ray-tracing systems can make GI more efficient; a higher bounce limit does not always lead to a proportional increase in rendering time.
Why do my renders look flat even with good materials?
A flat appearance may result from insufficient indirect light, unsuitable exposure, lighting without enough direction or contrast, or material settings that do not produce the intended look. Review the complete lighting and material setup before assuming GI is the cause.
Is global illumination the same as ray tracing?
No. Global illumination describes a lighting effect and the goal of accounting for indirect light in an image. Ray tracing is a broad family of techniques that follow rays through a scene and can be used to calculate direct lighting, reflections, and indirect illumination. Not every GI solution relies on the same ray-tracing approach.
How many GI bounces should I use?
Start with your renderer’s defaults. Increase bounce depth only when the scene requires it, and evaluate the change in a controlled comparison. The useful setting depends on the algorithm and the scene rather than a universal target.
