Architectural animation has always meant a separate pipeline. Take your renders, hand them off to an animator, wait days for camera path setup and render time, and pay premium studio rates per minute of finished video. For most architects, that process sits outside the normal design workflow, something you commission for final presentations, not something you do during the design process itself.
Veras changes that. The image-to-video feature lets you animate your architectural renders with Enscape, V-Ray, or Corona, no separate application, no powerful hardware, and no animation expertise required. Generate a static render, add cinematic motion, and download an animated video in just a few minutes, without leaving your design environment.
Key takeaways:
- Veras animates from Enscape, V-Ray, or Corona. No separate application, no render farm, and no animation expertise required
- Static render to downloadable video in minutes, not the 2–4 weeks typical of traditional studio animation pipelines
- First & Last Frame lets you define both the start and end state, giving controlled transitions for design evolution, before/after comparisons, and day/night shifts
- Video Combine stitches multiple clips into a single walkthrough directly inside Veras, without external editing software
- Camera movement should match spatial type. Pan for facades, dolly/flythrough for corridors and masterplans, zoom-in for material detail, since the wrong choice works against the design rather than communicating it
This guide covers:
- → What Veras image-to-video does differently
- → How to create your first animation in Veras
- → Camera movement types and when to use them
- → First & Last Frame: animating between two states
- → Video Combine: assembling a full walkthrough
- → Use cases by project type
- → Tips for better architectural animations in Veras
- → FAQs
Most AI tools for animation work the same way: upload a static image, select a camera movement, and generate a video. The source image could come from anywhere: a screenshot, a still render exported from another application, a photograph. The animation tool has no connection to your design software or 3D model.
Veras works differently. Because it launches from the Enscape toolbar or the V-Ray VFB, image-to-video is a direct next step in your existing architectural workflow. You generate a render, add cinematic motion, and download the animated video—all within the same session, without uploading to a separate platform or switching applications. The original render stays connected to your model, which means you can adjust the design, re-render, and re-animate without rebuilding your pipeline from scratch each time.
The practical difference in time and cost is significant:
Traditional studio animation |
Veras |
Cost |
Starting from $1,000 per minute |
Included in your subscription |
Turnaround |
2–4 weeks |
Just a few minutes |
Hardware required |
Render farm or powerful hardware |
Cloud-based — any machine |
Expertise required |
Animator/specialist |
None |
For architects and designers, where animation has historically been reserved for final client presentations because of render time and cost, Veras makes it practical at every stage, from early concept to final delivery. The result is a faster, more creative workflow that lets you bring architectural space to life without the traditional barriers of time, budget, or specialist expertise.
Creating architectural animations in Veras requires no prior animation experience. From any completed render, the process takes just a few minutes to turn a static image into a downloadable video.
- Start from a completed render in Veras. Open Veras from Enscape, V-Ray, or Corona and generate your render as normal. Image-to-video works from any Veras output, interior or exterior, photorealistic or stylized. For best results, use a high-resolution render with clear spatial depth and a well-defined focal point. The quality of your source image directly affects the quality of the animation output.
- Click the video tab. Select the render you want to animate. You can use a render generated in the current session or pull from a previously generated Veras output.
- Write a prompt or select a motion preset. Choose from Veras's built-in motion presets for common camera movements—pan, zoom, tilt, and flythrough—or write a text prompt for more creative control over the camera path. Specific prompts produce better results than general ones: "slow pan left across the glazed facade in morning light" gives the AI clearer direction than "pan left." For prompting guidance, see our AI Architecture Prompts (add the link here) guide.
- Set animation length and quality; some AI engines, including Veo 3.1 and Grok Imagine, support length control. Select your preferred output length and quality setting. Higher quality settings consume more Chaos Credits but produce smoother transitions and sharper detail in the final video. For early concept presentations, standard quality is sufficient; use high quality for final client presentations and marketing visuals.
- Generate and preview. Hit generate. Veras processes the animation in the cloud, with no local render time and no powerful hardware required. Preview the output before downloading to check camera movement, pacing, and overall presentation quality.
- Download as MP4. Once satisfied, download the finished animation as a high-resolution MP4, ready to use directly in client presentations, project portfolios, or marketing materials without further post-production.
Choosing the right camera movement is as important as the render itself. Each movement type communicates architectural space differently; the wrong choice can undercut a strong design. Here's how to match camera motion to your project and presentation context.
Pan
A horizontal camera sweep across the scene. Best suited to wide facades, open-plan interiors, and landscape design sequences where the spatial extent of the design is the main story. Prompt example: "slow pan left across the open-plan living space, warm afternoon lighting."
Zoom in
The camera moves toward a specific point in the scene. Use it to draw attention to entryways, material close-ups, or focal architectural details where you want clients to focus on a specific design decision. Effective for highlighting craftsmanship and texture in high-resolution renders.
Zoom out
Reveals the full exterior or site context by pulling the camera back from the structure. Useful for establishing scale, communicating the relationship between building and landscape, or transitioning from a detail shot to a wider view of the same project.
Tilt
A vertical camera movement up or down the scene. The natural choice for tall structures, multi-story facades, and vertical interior spaces where a horizontal pan would miss the full height of the design. Combine with a zoom out for a dramatic exterior reveal.
Dolly/flythrough
The camera moves through architectural space rather than across it. Best for corridors, gallery sequences, and masterplan flythroughs where the experience of moving through the space is the point. This is the most immersive camera movement type for client presentations and the most effective for communicating spatial flow and design intent.
Weather and time-of-day effects
Prompt Veras to add atmospheric elements: rain, fog, snow, sunset light, seasonal shifts, directly into the animation. These effects add depth and mood to static visuals without any additional rendering work. Use them selectively: a sunset exterior animation reinforces atmosphere, but heavy weather effects can distract from the architecture itself. Prompt example: "golden hour light shifting across the south facade, soft shadows."
Adding people and movement
Prompt for occupants, moving water, light through curtains, or other life elements to make architectural animations feel inhabited rather than empty. This is particularly effective for hospitality and residential projects where clients need to imagine the space in use. Prompt example: "a person walks through the glazed entrance, natural light across the floor."
First & Last Frame - animating between two states
Most animation tools generate motion from a single starting image. Veras' First & Last Frame feature lets you define both the start and end of the animation, and it generates the transition between them, giving you direct control over where the animation begins and ends, rather than letting the AI determine both.
The result is a purposeful animation that tells a specific visual story, not just a camera movement applied to a static image.
When to use it
First & Last Frame is most effective when the change between two states is the point: design evolution sequences, before/after material comparisons, phased project storytelling, or seasonal shifts across the same view. For architectural presentations where you need to communicate transformation rather than just space, it produces more controlled and intentional output than standard image-to-video.
Workflow
- Generate or select your start frame. This can be any image or completed Veras render, an early design option, a base material scheme, or an exterior view at a specific time of day.
- Generate or select your end frame. The end frame should share the same camera angle and general composition as the start frame for smooth transitions. Change the material, lighting, season, or design option between the two.
- Set as First & Last Frame in Veras. Designate each render in the First & Last Frame panel within the Veras interface.
- Generate the transition. Veras produces a smooth animated sequence between the two frames. Preview before downloading to check pacing and visual continuity.
Use cases
- Design evolution: animate from an early massing option to a developed scheme, showing design progression in a single clip
- Before/after presentations: show material or landscape changes across the same view for client decision-making
- Phased project storytelling: communicate construction phases or seasonal context shifts across the same architectural space
- Day/night transitions: start from a daytime exterior render and end at a night-lit facade to demonstrate lighting design intent
Individual animation clips tell part of the story. Video Combine stitches them together into a single continuous sequence, giving you a complete architectural walkthrough without external video editing software. For client presentations where a single camera movement isn't enough to communicate the full project, Video Combine turns individual renders into a cohesive narrative directly inside Veras.
When to use it
Any presentation that requires more than one viewpoint. Full project walkthroughs, multi-room interior tours, site-to-building approach sequences, and phased design storytelling all benefit from a combined video rather than a series of separate clips sent to clients individually.
Workflow
- Generate individual animation clips from different viewpoints or scenes within the same project. Each clip can use a different camera movement type — a site flythrough followed by an exterior zoom, then an interior pan, for example.
- Multi-select your clips using Shift or Ctrl-click in the Veras panel to select the sequence you want to combine.
- Hit Combine. Veras assembles the selected clips into a single video in the order selected, with smooth transitions between each segment.
- Download the assembled sequence as a high-resolution MP4, ready for client presentations, marketing visuals, or project portfolios.
Use cases
- Full project walkthroughs: combine exterior approach, entrance, and interior clips into a single presentation video for client sign-off
- Multi-room interior tours: sequence individual room animations into a continuous tour that communicates spatial flow and design intent across the whole project
- Site-to-building sequences: open with a masterplan flythrough establishing context, then move to exterior and interior detail clips for a complete project narrative
- Design variation comparisons: combine clips of different material or design options into a single video, allowing clients to compare alternatives in one viewing rather than across separate files
Architectural animation isn't one-size-fits-all; the right camera movement and animation approach depends on the project type, the audience, and what the presentation needs to communicate. The table below maps each project type to the most effective Veras animation approach, followed by a practical breakdown of each.
Project type |
Recommended camera movement |
Best used for |
Residential |
Pan, zoom in, First & Last Frame |
Exterior reveal, interior mood, material sign-off |
Commercial |
Zoom out, dolly/flythrough |
Facade, entrance sequence, lobby atmosphere |
Masterplan / urban design |
Flythrough, zoom out |
Scale, context, site-to-building sequence |
Interior design |
Pan, dolly, zoom in |
Room flow, furniture layout, lighting detail |
Residential
Residential projects live or die on the client's ability to imagine themselves in the space. AI architecture animation makes that easier at every stage. Use an exterior reveal animation to communicate approach and massing before the design is finalized, an interior pan to establish mood and lighting across key rooms, and material variation clips to help clients choose finishes without commissioning multiple full renders. For final client presentations, combine all three into a single walkthrough using Video Combine.
Commercial
Commercial clients and investors need to understand the project at scale, how the building presents from the street, how the entrance sequence feels, and how the lobby communicates brand and quality. Use a zoom-out exterior animation to establish the facade and site context, a dolly shot through the entrance sequence to communicate spatial flow, and an interior pan across the lobby to convey design intent and atmosphere. These animations work directly in investor presentations and marketing visuals without additional post-production.
Masterplan/urban design
Scale and context are the primary communication challenges in masterplan and urban design projects. In broader architectural workflows, some AI workloads can quickly convert 2D floor plans into animated 3D walkthroughs for early context studies. A flythrough animation that establishes the relationship between buildings, public space, and landscape communicates what static visuals cannot: the experience of moving through the designed environment. Use Veras to generate a site-to-building sequence that opens at masterplan scale and moves progressively into street level and building detail, giving clients and stakeholders a spatially coherent understanding of the project.
Interior design
Interior animation communicates how a space feels to move through, not just how it looks in a single frame. Use a pan to show room flow and furniture layout in context, a zoom-in to highlight material details and lighting design, and a dolly shot through connected spaces to communicate the relationship between rooms. For residential interior projects, adding subtle movement like people, light through curtains, and soft shadows shifting makes the space feel inhabited and helps clients connect emotionally with the design during presentations.
- Start from a high-quality render - Animation quality is directly limited by the quality of your source image. A low-resolution or poorly lit render will produce a low-quality animation regardless of the camera movement or prompt. Before animating, make sure your original render has clear spatial depth, good lighting, and a well-defined focal point. High-resolution renders produce sharper detail and smoother transitions in the final video output.
- Match camera movement to spatial type - Each camera movement suits a specific type of architectural space. A dolly or flythrough communicates a corridor; a pan communicates a wide facade or open-plan interior; a zoom in isolates a detail. Using the wrong movement for the space—a zoom for a corridor, a pan for a tall facade—produces an animation that works against the design intent rather than communicating it. Use the camera movement table in the previous section as a quick reference.
- Use weather and time-of-day effects sparingly - Atmospheric effects (rain, fog, sunset light, seasonal shifts) add depth and mood to architectural animations but can easily overwhelm the design if overused. Apply them when atmosphere is the point of the presentation, not as a default. A clean daytime exterior animation often communicates design intent more clearly than a dramatic sunset with weather overlays.
- Prompt specifically - The more specific your prompt, the more controlled the output. "Slow pan left across the glazed facade in morning light" gives Veras clear direction on movement speed, direction, and atmosphere. "Pan left" leaves too many variables open. Treat the prompt as a camera direction, not a general instruction.
- Use Video Combine for presentations - Rather than downloading individual clips and assembling them in external video editing software, use Video Combine to sequence your animation clips directly inside Veras. It produces a clean, high-resolution MP4 ready for client presentations without additional post-production, saving time and keeping the workflow inside your design environment.
- Keep animations short - For client presentations, 8–12 seconds per clip is enough. Longer animations rarely add communication value and can lose the client's attention before the key design moments land. Short, purposeful clips, each focused on a single spatial experience or design decision, are more effective than a single long video trying to cover the entire project.
To summarize
Veras brings architectural animation into the same workflow as rendering—no separate pipeline, no specialist expertise, no render farm. For architects and designers who need to communicate design intent through motion, it removes the cost and time barriers that have historically made animation a final-deliverable-only tool.
FAQ
How is artificial intelligence used in architectural animation?
AI analyzes the spatial depth and composition of a static render and automatically generates realistic camera motion and transitions. In Veras, it also interprets text prompts to add atmospheric effects—weather, lighting shifts, movement—without manual keyframing or a 3D animation pipeline. The result is a video generated directly from a single render in minutes.
Can AI generate architectural animations from 2D floor plans?
Yes. With Veras, you can generate a render from a sketch, 2D plan, or any image, and then create an animation with it.
What are the hardware requirements for AI architectural animation with Veras?
None beyond a standard machine. Veras processes animations in the cloud, so local GPU or render farm hardware isn't required. Generation speed can vary somewhat with server load. It runs on both Mac and Windows. An active internet connection and sufficient Chaos Credits are the only technical requirements.
How can a small architecture firm use AI to produce affordable animated walkthroughs?
Veras is included in existing Chaos subscriptions; there's no separate animation license. A monthly Chaos Credits allowance covers regular animation output, with additional credits available to purchase. For a small firm, this replaces the need for freelance animators or studio commissions, making animation viable at every project stage rather than only for final deliverables.
How will generative AI change architectural animation over the next few years?
The direction is toward greater automation and real-time output, smarter camera path generation, voice-prompted animations, and tighter integration between design tools and animation engines. For architects, the practical shift is already underway: animation is moving from a specialist post-production task to a standard part of the design and presentation workflow.
What is the difference between AI-based animation and traditional renderers like V-Ray or Corona for architectural visualization?
V-Ray and Corona are production renderers; they calculate light, materials, and geometry with precision for final deliverable quality. Veras image-to-video is an animation layer that works on top of those renders, adding motion without recalculating the scene. They're complementary: render in V-Ray or Corona, animate in Veras. One doesn't replace the other.
How do enterprise architecture firms implement AI video into client pitches?
The most effective approach is to integrate animation at the concept stage rather than treating it as a final-deliverable step. Firms can absolutely export AI-generated clips and refine them further in professional editing tools before using them in pitches or on YouTube. Generating animated design variations early, before significant modeling investment, allows firms to present multiple directions to clients in a single meeting, reducing revision cycles and accelerating sign-off. Video Combine then assembles those clips into a polished pitch sequence without external editing.
